[Geoserver-devel] Problem obtaining an SLD from the REST API
When I try to obtain an SLD from GeoServer REST API that have an WellKnownName element that use some ogc:function I don't get the expected result.
Lets say I have following SLD:
<?xml version="1.0" encoding="utf-8"?>
<sld:StyledLayerDescriptor xmlns="http://www.opengis.net/sld&quot;
                              xmlns:sld="http://www.opengis.net/sld&quot;
                              xmlns:ogc="http://www.opengis.net/ogc&quot;
                              xmlns:gml="http://www.opengis.net/gml&quot; version="1.0.0">
   <sld:NamedLayer>
     <sld:Name>test</sld:Name>
     <sld:UserStyle>
       <sld:FeatureTypeStyle>
         <sld:Rule>
           <sld:PointSymbolizer>
             <sld:Graphic>
               <sld:Mark>
                 <sld:WellKnownName>
                   <ogc:Function name="strToUpperCase">
                     <ogc:Literal>shape</ogc:Literal>
                   </ogc:Function>
                 </sld:WellKnownName>
               </sld:Mark>
             </sld:Graphic>
           </sld:PointSymbolizer>
         </sld:Rule>
       </sld:FeatureTypeStyle>
     </sld:UserStyle>
   </sld:NamedLayer>
</sld:StyledLayerDescriptor>
The request /geoserver/rest/styles/test.sld will return:
   <sld:NamedLayer>
     <sld:UserStyle>
         <sld:Name>name</sld:Name>
         <sld:Rule>
             <sld:Graphic>
               <sld:Mark>
<sld:WellKnownName>strToUpperCase([shape])</sld:WellKnownName>
               </sld:Mark>
             </sld:Graphic>
         </sld:Rule>
     </sld:UserStyle>
   </sld:NamedLayer>
I don't know if this is a bug or the expected output, the SLDTransformer class in Geotools handles the WellKnownName element as a simple element and only do a simple toString:
         public void visit(Mark mark) {
             start("Mark");
             if (mark.getWellKnownName() != null && !"square".equals(mark.getWellKnownName().evaluate(null))) {
                 element("WellKnownName", mark.getWellKnownName().toString());
             if (mark.getFill() != null) {
                 mark.getFill().accept(this);
             if (mark.getStroke() != null) {
                 mark.getStroke().accept(this);
             end("Mark");
In my point of view the WellKnownName should have a full conversion, i.e. instead of:
we should have:
     encodeValue("WellKnownName", null, mark.getWellKnownName(), null);
If this is not the expect behavior I can make a pull request in Geotools and if this is the expected behavior can someone give-me some explanation about ?
Best regards,
Nuno Oliveira
On Tue, Mar 4, 2014 at 3:03 PM, Nuno Oliveira <
i.e. instead of:
we should have:
explanation about ?
So, the SLD spec says, that the well known name is a fixed string:
<xsd:element name="WellKnownName" type="xsd:string"/>
However we extended our own parser and machinery to deal with a generic
expression, but the same was not done for the encoding part, so this is a
bug.
A pull request would be welcomed, please remember to include a test
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I think you have just found a gap from when we extended SLD to support expressions for dynamic marks. Technically SLD should only allow a String for WellKnownName, I would expect the expression to be encoded as a String with a bit more escaping.
See:
Jody Garnett
On Wed, Mar 5, 2014 at 1:03 AM, Nuno Oliveira <nuno-miguel-oliveira@anonymised.com> wrote:
WellKnownName element that use some ogc:function I don’t get the
expected result.
<sld:StyledLayerDescriptor xmlns=“http://www.opengis.net/sld
xmlns:sld=“http://www.opengis.net/sld
xmlns:ogc=“http://www.opengis.net/ogc
xmlns:gml=“http://www.opengis.net/gml
version=“1.0.0”>
sld:NamedLayer
sld:Nametest</sld:Name>
sld:UserStyle
sld:Rule
sld:PointSymbolizer
sld:Graphic
sld:Mark
sld:WellKnownName
<ogc:Function name=“strToUpperCase”>
ogc:Literalshape</ogc:Literal>
</ogc:Function>
</sld:Mark>
</sld:Graphic>
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
version=“1.0.0”>
sld:NamedLayer
sld:UserStyle
sld:Namename</sld:Name>
sld:Rule
sld:PointSymbolizer
sld:Graphic
sld:Mark
sld:WellKnownNamestrToUpperCase([shape])</sld:WellKnownName>
</sld:Mark>
</sld:Graphic>
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
I don’t know if this is a bug or the expected output, the SLDTransformer
start(“Mark”);
!“square”.equals(mark.getWellKnownName().evaluate(null))) {
element(“WellKnownName”,
end(“Mark”);
i.e. instead of:
element(“WellKnownName”, mark.getWellKnownName().toString());
we should have:
encodeValue(“WellKnownName”, null, mark.getWellKnownName(), null);
explanation about ?
Best regards,
Nuno Oliveira
Subversion Kills Productivity. Get off Subversion & Make the Move to Perforce.
With Perforce, you get hassle-free workflows. Merge that actually works.
Faster operations. Version large binaries. Built-in WAN optimization and the
freedom to use Git, Perforce or both. Make the move to Perforce.
http://pubads.g.doubleclick.net/gampad/clk?id=122218951&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Hi Aime,
Thanks for the feedback. I will make a pull request in Geotools and provide a test for this use case.
Best regards,
Nuno Oliveira
On 03/04/2014 02:10 PM, Andrea Aime wrote:
On Tue, Mar 4, 2014 at 3:03 PM, Nuno Oliveira <nuno-miguel-oliveira@anonymised.com <mailto:nuno-miguel-oliveira@anonymised.com>> wrote:
    i.e. instead of:
    we should have:
    null);
    Geotools
    explanation about ?
expression, but the same was not done for the encoding part, so this is a bug.
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Sorry, I don't understand what you mean by: "I would expect the expression to be encoded as a String with a bit more escaping".
Do you agree in having a full encoding of the WellkownName element (i.e. its expression):
or just having a more powerful toString ?
Best regards,
Nuno Oliveira
See:
- http://blog.geoserver.org/2008/12/08/dynamic-symbolizers-part-1/
- http://blog.geoserver.org/2008/12/16/dynamic-symbolizers-part-2/
Jody Garnett
On Wed, Mar 5, 2014 at 1:03 AM, Nuno Oliveira <nuno-miguel-oliveira@anonymised.com <mailto:nuno-miguel-oliveira@anonymised.com>> wrote:
    expected result.
    version="1.0.0">
       <sld:NamedLayer>
         <sld:UserStyle>
             <sld:Rule>
                 <sld:Graphic>
                   <sld:Mark>
                     <sld:WellKnownName>
                       </ogc:Function>
                   </sld:Mark>
                 </sld:Graphic>
             </sld:Rule>
         </sld:UserStyle>
       </sld:NamedLayer>
    version="1.0.0">
       <sld:NamedLayer>
         <sld:UserStyle>
             <sld:Rule>
                 <sld:Graphic>
                   <sld:Mark>
                   </sld:Mark>
                 </sld:Graphic>
             </sld:Rule>
         </sld:UserStyle>
       </sld:NamedLayer>
    SLDTransformer
    element
                 start("Mark");
                 end("Mark");
    i.e. instead of:
    we should have:
    null);
    Geotools
    explanation about ?
    Best regards,
    Nuno Oliveira
    to Perforce.
    works.
    <mailto:Geoserver-devel@lists.sourceforge.net>
The proposal[1] documents the use of ${ cql expression} so your original example would be:
sld:WellKnownName${strToUpperCase(‘shape’)}</sld:WellKnownName>
On Wed, Mar 5, 2014 at 1:47 AM, Nuno Oliveira <nuno-miguel-oliveira@anonymised.com> wrote:
Sorry, I don’t understand what you mean by: “I would expect the expression to be encoded as a String with a bit more escaping”.
Best regards,
Nuno Oliveira
On Tue, Mar 4, 2014 at 3:59 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
example would be:
<sld:WellKnownName>${strToUpperCase('shape')}</sld:WellKnownName>
Jody, the proposal was implemented so that the syntax above is used only
for external graphics
(where we don't have space to embed a Expression) but not for
WellKnownName, where a
regular expression can be used.
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Jody and Aime for the explanations, I will proceed with the pull request.
By the way ( I know and understand the need to follow with the standards but, ) when we have a big SLD with complex "business" based on scales, request attributes , properties ... we often end up with an SLD that have a lot of boilerplate code and vendor options that makes him very difficult to maintain and is very error-prone.
The function mechanism is nice but requires implementing some Java code and the XML can become very bad ...
Does Geoserver have any intention to improve the SLD dynamics mechanisms ?
It would be nice to have some more powerful scripting support like SpEL or Groovy for example.
( http://docs.spring.io/spring/docs/4.0.3.BUILD-SNAPSHOT/spring-framework-reference/htmlsingle/#expressions)
Best regards,
Nuno Oliveira
On 03/04/2014 03:26 PM, Andrea Aime wrote:
On Tue, Mar 4, 2014 at 3:59 PM, Jody Garnett <jody.garnett@anonymised.com <mailto:jody.garnett@anonymised.com>> wrote:
Jody, the proposal was implemented so that the syntax above is used only for external graphics
(where we don't have space to embed a Expression) but not for WellKnownName, where a
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Mar 4, 2014 at 5:10 PM, Nuno Oliveira <
request.
"GeoServer" has no intentions of its own, it really depends on what funding
becomes available
(and people with funds most of the time have a very specific idea of how
they should be used)
and to a much more modest extend, to what the developers feel like doing on
a Sunday
Groovy for example.
You can look into CSS for a more compact styling language (
http://docs.geoserver.org/latest/en/user/extensions/css/index.html)
and GeoScript modules in order to implement your filter functions in a
scripting language
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Mar 4, 2014 at 4:26 PM, Andrea Aime <andrea.aime@anonymised.com>wrote:
On Tue, Mar 4, 2014 at 3:59 PM, Jody Garnett <jody.garnett@anonymised.com>wrote:
example would be:
Hum nope, checked the code, it should also actually be able to handle the
syntax you have
proposed above, I just never used it since implementing it.
So we have two possible ways to implement the translaction back to SLD,
personally I'd
still prefer the one using an OGC expression, it's more in line with the
rest of the
SLD, the ${cqlExpression} thing was created only to deal with the
impossibilty
of writing a full OGC expression in the external graphics url
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
I just made the pull request for this: https://github.com/geotools/geotools/pull/385
Since we use a lot of other functions in our SLD I keep the OGC expression syntax, it seems more "compatible".
By the way, I test the CQL syntax and all seems to work fine ... if I forgot something to make it compatible let me know.
Thanks for your feedback.
Best regards,
Nuno Oliveira
On 03/04/2014 04:58 PM, Andrea Aime wrote:
On Tue, Mar 4, 2014 at 4:26 PM, Andrea Aime <andrea.aime@anonymised.com <mailto:andrea.aime@anonymised.com>> wrote:
Hum nope, checked the code, it should also actually be able to handle the syntax you have
So we have two possible ways to implement the translaction back to SLD, personally I'd
still prefer the one using an OGC expression, it's more in line with the rest of the
SLD, the ${cqlExpression} thing was created only to deal with the impossibilty
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Nuno:
Created an Jira issue: https://jira.codehaus.org/browse/GEOT-4726
And have applied the fix to master, 11.x and 10.x
Jody Garnett
On Thu, Mar 6, 2014 at 1:28 AM, Nuno Oliveira <nuno-miguel-oliveira@anonymised.com> wrote:
Since we use a lot of other functions in our SLD I keep the OGC expression syntax, it seems more “compatible”.
By the way, I test the CQL syntax and all seems to work fine … if I forgot something to make it compatible let me know.
Best regards,
Nuno Oliveira
On Tue, Mar 4, 2014 at 4:26 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
So we have two possible ways to implement the translaction back to SLD, personally I’d
still prefer the one using an OGC expression, it’s more in line with the rest of the
Ing. Andrea Aime
@geowolf
Technical Lead
(where we don’t have space to embed a Expression) but not for WellKnownName, where a
Hi Jody,
Thanks.
Related to the contribution agreement, I have only signed the geoserver one when I contribute the W3DS module.
Since I pretend to become more active in the geoserver\geotools stack (and have other things that maybe interesting to contribute)
I definitively should sign the contribution agreement.
I found this page http://docs.codehaus.org/display/GEOTOOLS/Replace+Contribution+Agreement
Is this the right one: http://docs.geotools.org/latest/developer/procedures/contribution_license.html ?
Best regards,
Nuno Oliveira
On 03/05/2014 11:46 PM, Jody Garnett wrote:
Thanks Nuno:
Jody Garnett
On Thu, Mar 6, 2014 at 1:28 AM, Nuno Oliveira <nuno-miguel-oliveira@anonymised.com <mailto:nuno-miguel-oliveira@anonymised.com>> wrote:
    Best regards,
    Nuno Oliveira
    impossibilty
    -- == Our support, Your Success! Visit
    Ing. Andrea Aime
    @geowolf
    Technical Lead
    phone: +39 0584 962313 <tel:%2B39%200584%20962313>
    fax: +39 0584 1660272 <tel:%2B39%200584%201660272>
    mob: +39 339 8844549 <tel:%2B39%20%C2%A0339%208844549>
That is the one! It should be a lot easier to follow then last time (and you can just email it in). Do keep in mind there is one to bounce off your employer as well.
Jody Garnett
On Fri, Mar 7, 2014 at 9:28 PM, Nuno Oliveira <nuno-miguel-oliveira@anonymised.com> wrote:
Hi Jody,
Thanks.
Best regards,
Nuno Oliveira
Thanks Nuno:
Jody Garnett
Best regards,
Nuno Oliveira
On Tue, Mar 4, 2014 at 4:26 PM, Andrea Aime <andrea.aime@anonymised.com.> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Mar 4, 2014 at 3:59 PM, Jody Garnett <jody.garnett@anonymised.com…> wrote:
