I've scanned the forums on this topic and haven't found a solution to my
problem though I've seen there's been some tweaks and discussion on
GeoServer logging.
Running 1.6 Beta 3, no matter what I do, the geoserver.log file is empty.
I've installed GeoServer from scratch on XP into C:\GeoServer, using
JAVA_HOME set to C:\Program Files\Java\jdk1.5.0_07. Using Config - Server,
I've placed check marks in the Verbose and VerboseExceptions options,
selected VERBOSE_LOGGING.properties for the Logging Profile, and have left
the default Log Location set to logs/geoserver.log. No matter which Logging
Profile I select, the geoserver.log is empty.
In the console, I see the following two lines that caught my eye:
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
That 'WARN File option' bit suggests to me that there is something not
switched on to write out the file? There is such a thing (I think) in
1.5.3:
I removed 1.6 Beta 3 and installed from scratch 1.5.3. The Config - Server
options I note are slightly different. I select the 'ALL' for the Logging
Level, placed a check mark in front of Write logs to file (an option not
present in 1.6 Beta 3), and left the default log location at
logs/geoserver.log. After saving this, I can see a lot of information
stored in the C:\GeoServer\data_dir\logs\geoserver.log file.
Any help greatly appreciated.
Thanks, Bob
View this message in context: http://www.nabble.com/Problem-setting-up-logging---log-files-are-empty-tf4671333.html#a13344893
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
A note to the reader...
I am now getting information into the geoserver.log now that I've converted
from using Jetty to using Tomcat 5.5.
Thanks, Bob
Bob Nutsch wrote:
GeoServer logging.
Server, I've placed check marks in the Verbose and VerboseExceptions
options, selected VERBOSE_LOGGING.properties for the Logging Profile, and
have left the default Log Location set to logs/geoserver.log. No matter
which Logging Profile I select, the geoserver.log is empty.
1.5.3:
Server options I note are slightly different. I select the 'ALL' for the
Logging Level, placed a check mark in front of Write logs to file (an
option not present in 1.6 Beta 3), and left the default log location at
Thanks, Bob
View this message in context: http://www.nabble.com/Problem-setting-up-logging---log-files-are-empty-tf4671333.html#a13416283
Which version of Jetty were you using?
I was using the default Jetty that installs when using the
'geoserver-1.6-beta3.exe' version of GeoServer. I believe that I saw
6.02 in the console during startup of GeoServer.
Regards, Bob
-----Original Message-----
Sent: Friday, October 26, 2007 2:31 AM
To: Nutsch, Bob D.
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Problem setting up logging -
log files are empty
> converted from using Jetty to using Tomcat 5.5.
Nutsch, Bob D. ha scritto:
What you were seeing is probably:
http://jira.codehaus.org/browse/GEOS-1444
Maybe the tomcat install you have is located in a path without any
spaces whilst the exe did have at least one in the path.
Hi Andrea,
Yes, that is mostly correct. The .exe that I installed did have spaces in
the path initially, but when trying to fix the problem of the logging
options not being editable within Config->Server (they were grayed out), I
switched over to installing the .exe into c:\geoserver. The logging options
were then configurable (but still no output to geoserver.log.
When I first tried to implement GeoServer with Tomcat, I had Tomcat under
'Program Files' (I used the default install path) and in that mode when
trying to deploy, the deploy failed (but I did get a geoserver.log!) and in
the log and in the console, there appeared to be problems with paths to
classpaths and possibly other entities.
I then uninstalled Tomcat and reinstalled to C:\Tomcat55 and I could then
deploy GeoServer and the geoserver.log had content in it.
So, spaces aren't good. My Java 1.5.0_13 is however still in a spaced
out directory: C:\Program Files\Java.
Regards, Bob
Geoserver-devel mailing list
View this message in context: http://www.nabble.com/Problem-setting-up-logging---log-files-are-empty-tf4671333.html#a13427821
I should have noted that part of my "recipe" for getting GeoServer deployed
to Tomcat on XP included putting tomcat under C:\Tomcat55 and installing the
JAI files. Once I did BOTH, the install to C:\Tomcat55 AND installing the
JAI files, THEN I was good to go.
Regards, Bob
Bob Nutsch wrote:
Hi Andrea,
options were then configurable (but still no output to geoserver.log.
in the log and in the console, there appeared to be problems with paths to
spaced out directory: C:\Program Files\Java.
Regards, Bob
View this message in context: http://www.nabble.com/Problem-setting-up-logging---log-files-are-empty-tf4671333.html#a13428209
