[Geoserver-devel] problem solved
I managed to solve the problem.....got a new xalan.jar and placed it in .\lib\jetty
now it's working normally....
Thanks anyway
Daniel
PS: BTW, I'm working with java 1.5
Chris Holmes <cholmes@...13...>
, J. Daniel =?iso-8859-1?b?QWxj4W50YXJh?= M. <is112536@...608...> wrote:
Hrm. Usually that should solve the problem. Are you on 1.4 or 1.5?
Maybe you could try 1.4, and see if that works better?
Or maybe some other parameter is overriding geoserver finding it?
Actually you may try to get a new xalan jar - I feel like the normal
error might be something different than a null pointer, but I could be
wrong.
Chris
Quoting "J. Daniel Alc�ntara M." <is112536@...609...>:
hi...I have a problem with geoserver....i keep getting this error
javax.xml.transform.TransformerFactoryConfigurationError: Provider
org.apache.xalan.processor.TransformerFactoryImpl could not be
instantiated: java.lang.NullPointerException
i've got the xalan.jar, xml-apis.jar and xercesImpl.jar in the lib
folder of the server as well as addd in my classpath variable(I'm
working under windows)...I've tried to fix the problem by removing
those jars from the folder, but I still get the same error....
any ideas of what's happening and how can it be solved?? thanks
Daniel- This email was sent via mail - Checkout http://mail
This SF.Net email is sponsored by Oracle Space Sweepstakes
Want to be the first software developer in space?
Enter now for the Oracle Space Sweepstakes!
http://ads.osdn.com/?ad_id=7393&alloc_id=16281&op=click
Geoserver-devel mailing list
This mail sent through IMP: https://webmail.limegroup.com/
