[Geoserver-devel] Problem updating shapefile with REST API
HI
I’m trying to upload a shapefile with REST API several times (to update the data of the feature type):
curl -u admin:geoserver -XPUT -H ‘Content-type: application/zip’ --data-binary @buildings.zip http://localhost:8080/geoserver/rest/workspaces/acme/datastores/buildings/file.shp
The first time works ok, but next time I get this exception:
19 ene 13:10:38 ERROR [geoserver.rest] -
org.geoserver.rest.RestletException: java.util.zip.ZipException: error in openin
g zip file
at org.geoserver.catalog.rest.StoreFileResource.handleFileUpload(StoreFi
leResource.java:99)
at org.geoserver.catalog.rest.DataStoreFileResource.handlePut(DataStoreF
ileResource.java:112)
at org.restlet.Finder.handle(Finder.java:298)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet
.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
I tried to delete the datastore, removing first the layer and the featuretype so later trying to upload the shapefile again. In this case sometimes it’s working but others getting the before error.
The problem seem that in the data directory the shapefile files are not deleted after the featuretype or datastore are deleted. If the files are deleted manually from the directory then works ok.
Not sure if I’m doing something wrong or it’s a bug of the REST API.
I’m using Windows Vista and Geoserver it’s not installed in Program Files folder.
Jose Garcia
Hi Jose,
Sorry for the reply. I know this functionality works on "regular" setup so I assume it is something specific to the vista setup.
I recently acquired a vista virtual machine so I can try this out. To do so can you tell me about the setup. Where is gs installed? And where does the data directory reside. Thanks.
-Justin
jose garcia wrote:
HI
I'm trying to upload a shapefile with REST API several times (to update the data of the feature type):
curl -u admin:geoserver -XPUT -H 'Content-type: application/zip' --data-binary @buildings.zip http://localhost:8080/geoserver/rest/workspaces/acme/datastores/buildings/file.shp
g zip file
leResource.java:99)
.java:38)
I tried to delete the datastore, removing first the layer and the featuretype so later trying to upload the shapefile again. In this case sometimes it's working but others getting the before error.
Not sure if I'm doing something wrong or it's a bug of the REST API.
I'm using Windows Vista and Geoserver it's not installed in Program Files folder.
Jose Garcia
Throughout its 18-year history, RSA Conference consistently attracts the
world's best and brightest in the field, creating opportunities for Conference
attendees to learn about information security's most important issues through
interactions with peers, luminaries and emerging and established companies.
http://p.sf.net/sfu/rsaconf-dev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin
GeoServer it’s installed in C:\programs\geoserver-2.0.0 and the shapefiles are stored in C:\programs\geoserver-2.0.0\data_dir\data
I tried to delete the files manually with the Windows Explorer and there’s no problem, so seem not blocked. Seem more that GeoServer have problems when unziping the file, if the files already exists in the folder.
Thanks and regards,
Jose Garcia
On Wed, Jan 20, 2010 at 4:22 PM, Justin Deoliveira <jdeolive@anonymised.com…> wrote:
Hi Jose,
Sorry for the reply. I know this functionality works on “regular” setup so I assume it is something specific to the vista setup.
-Justin
jose garcia wrote:
HI
g zip file
leResource.java:99)
.java:38)
Jose Garcia
world’s best and brightest in the field, creating opportunities for Conference
attendees to learn about information security’s most important issues through
Justin Deoliveira
Hi Jose,
Thanks for supplying all the information for this. I spent a couple of hours today looking at this and I don't have a great explanation. Here is what I found.
There is a bug in the code where the uploaded zip file can overwrite the original files. This will happen when the store name is equal to the file name. And in this case it is. One thing to try would be to try it with the file names different. For instance, create a store named "buildings" but rename the shapefile to buildings_foo.shp or something. See if that works.
As for being able to replicate the issue I could not with any repeatability. My current guess is that there is some file locking going on. Ie a datastore is holding onto the shapefiles you are trying to overwrite. Again I was not able to affirm this was any repeatability. We could have the code dispose the existing datastore manually before updating. This should ensure nothing else is holding onto the files when overwriting them.
However can you try the renaming thing first since that one is much easier to fix.
Thanks.
-Justin
On 1/20/10 11:09 AM, jose garcia wrote:
Hi Justin
GeoServer it's installed in C:\programs\geoserver-2.0.0 and the
there's no problem, so seem not blocked. Seem more that GeoServer have
Thanks and regards,
Jose Garcia
<mailto:jdeolive@anonymised.com>> wrote:
    Hi Jose,
    -Justin
    jose garcia wrote:
        HI
        error in openin
        g zip file
                at
        leResource.java:99)
                at
                at
        .java:38)
        before error.
        Jose Garcia
        attracts the
        for Conference
        issues through
        companies.
        <mailto:Geoserver-devel@lists.sourceforge.net>
    Justin Deoliveira
Justin Deoliveira
