[Geoserver-devel] Problem with many Polygon
Hmmm... Is this with PostGIS? It looks like one of the Geometries in
your table is not formed right. How did you get the data into Postgis?
Is there a 'E-19' in the geometry column of one of the rows of your
table where there should be a ) or a , ? I've never seen this problem
before. If you can find a row that has E-19 you might try to just
delete that row...
Chris
----- Original Message -----
To: <geoserver-devel@lists.sourceforge.net>
Sent: Friday, May 14, 2004 2:55 AM
Subject: [Geoserver-devel] Problem with many Polygon
I have a worldmap with political division and WMS only show a few
Polygons
this is the log file of Tomcat 4.1.3
#59207
[ADVERTENCIA] org.geotools.renderer.lite.LiteRenderer - Exception
org.geotools.data.DataSourceException: could not parse
wktcom.vividsolutions.jts.io.ParseException: Expected ')' or ',' but
encountered 'E-19' rendering layer
org.geotools.map.DefaultMapLayer@anonymised.com
encountered 'E-19'
at org.geotools.data.jdbc.WKTAttributeIO.read(WKTAttributeIO.java:115)
at
org.geotools.data.JoiningAttributeReader.read(JoiningAttributeReader.java:11
7)
at
org.geotools.data.FIDFeatureReader.readFeature(FIDFeatureReader.java:117)
at org.geotools.data.FIDFeatureReader.next(FIDFeatureReader.java:89)
at
org.geotools.renderer.lite.LiteRenderer.processStylers(LiteRenderer.java:898
at
org.geotools.renderer.lite.LiteRenderer.paint(LiteRenderer.java:496)
at
org.vfny.geoserver.responses.wms.map.JAIMapResponse.execute(JAIMapResponse.j
ava:294)
at
org.vfny.geoserver.responses.wms.map.GetMapDelegate.execute(GetMapDelegate.j
ava:135)
at
ava:95)
at
org.vfny.geoserver.responses.wms.GetMapResponse.execute(GetMapResponse.java:
73)
at
org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:3
65)
at
org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:233)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at
org.vfny.geoserver.servlets.wms.WmsDispatcher.doResponse(WmsDispatcher.java:
135)
at
org.vfny.geoserver.servlets.wms.WmsDispatcher.doGet(WmsDispatcher.java:106)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Application
FilterChain.java:247)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterCh
ain.java:193)
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.ja
va:256)
at
org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invok
eNext(StandardPipeline.java:643)
at
org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:480)
at
org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.ja
va:191)
at
at
at
at
org.apache.catalina.core.StandardContext.invoke(StandardContext.java:2422)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:180
at
at
org.apache.catalina.valves.ErrorDispatcherValve.invoke(ErrorDispatcherValve.
java:171)
at
eNext(StandardPipeline.java:641)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:163
at
at
at
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java
:174)
at
at
at
at
org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:199)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:828)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConne
ction(Http11Protocol.java:700)
at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:584)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.jav
a:683)
at java.lang.Thread.run(Thread.java:534)
#59212 [FINA] org.vfny.geoserver.responses.wms.map.JAIMapResponse -
called
renderer
#59213 [M&#65533;S FINA]
org.vfny.geoserver.responses.wms.GetMapResponse -
ENTRY org.vfny.geoserver.requests.wms.GetMapRequest@anonymised.com
#59214 [FINA] org.vfny.geoserver.servlets.AbstractService - execution
succeed
#59216 [M&#65533;S FINA] org.vfny.geoserver.servlets.AbstractService -
stratagy output is: java.io.BufferedOutputStream
#59218 [FINA] org.vfny.geoserver.servlets.AbstractService - mime type
is:
image/png
#59219 [M&#65533;S FINA]
returning content encoding null
#59220 [M&#65533;S FINA]
asking delegate for write to java.io.BufferedOutputStream@anonymised.com
#59916 [INFO] org.vfny.geoserver.servlets.AbstractService - Service
handled
This mail sent through IMP: https://webmail.limegroup.com/
