I was testing GeoServer 2.0 (trunk) , I realized that by saving the configuration even without changing anything to the next reboot I get this error:
com.thoughtworks.xstream.converters.ConversionException: Could not call java.security.CodeSource.readObject() : null
---- Debugging information ----
message : Could not call java.security.CodeSource.readObject()
cause-exception : java.lang.RuntimeException
cause-message : null
class : com.thoughtworks.xstream.mapper.DynamicProxyMapper$DynamicProxy
required-type : java.security.CodeSource
path : /dynamic-proxy/handler/proxyObject/geoServer/catalog/delegate/listeners/org.geoserver.wfs.xml.v1_0_0.WFSConfiguration$1/outer-class/xsd/schemaBuilder/resourceLoader/classLoader/parent/parent/domains/java.security.ProtectionDomain/codesource/java.security.CodeSource
line number : 772
at com.thoughtworks.xstream.converters.reflection.SerializationMethodInvoker.callReadObject(SerializationMethodInvoker.java:88)
at com.thoughtworks.xstream.converters.reflection.SerializableConverter.doUnmarshal(SerializableConverter.java:402)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshal(AbstractReflectionConverter.java:162)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:82)
at com.thoughtworks.xstream.core.AbstractReferenceUnmarshaller.convert(AbstractReferenceUnmarshaller.java:63)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:76)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshallField(AbstractReflectionConverter.java:246)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.doUnmarshal(AbstractReflectionConverter.java:218)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:60)
at com.thoughtworks.xstream.converters.collections.AbstractCollectionConverter.readItem(AbstractCollectionConverter.java:71)
at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:68)
at com.thoughtworks.xstream.converters.collections.CollectionConverter.unmarshal(CollectionConverter.java:61)
at com.thoughtworks.xstream.converters.extended.DynamicProxyConverter.unmarshal(DynamicProxyConverter.java:86)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:137)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:33)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:923)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:909)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:861)
at org.geoserver.config.util.XStreamServiceLoader.load(XStreamServiceLoader.java:47)
at org.geoserver.config.GeoServerLoader.loadGeoServer(GeoServerLoader.java:198)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:95)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.geoserver.web.Start.main(Start.java:59)
Caused by: java.lang.RuntimeException
at com.thoughtworks.xstream.io.xml.AbstractPullReader.moveDown(AbstractPullReader.java:96)
at com.thoughtworks.xstream.io.ReaderWrapper.moveDown(ReaderWrapper.java:36)
at com.thoughtworks.xstream.io.path.PathTrackingReader.moveDown(PathTrackingReader.java:37)
at com.thoughtworks.xstream.converters.reflection.SerializableConverter$2.readFromStream(SerializableConverter.java:286)
at com.thoughtworks.xstream.core.util.CustomObjectInputStream.readObjectOverride(CustomObjectInputStream.java:86)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:342)
at java.security.CodeSource.readObject(CodeSource.java:562)
at com.thoughtworks.xstream.converters.reflection.SerializationMethodInvoker.callReadObject(SerializationMethodInvoker.java:84)
… 144 more
16 mar 11:04:17 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘CSVOutputFormat’ defined in URL [file:/Users/francesco/sviluppoGEOS/trunk/src/wfs/target/classes/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geoserver.wfs.response.CSVOutputFormat]: Constructor threw exception; nested exception is java.lang.IllegalArgumentException: A valid WFS object must be provided in order for this class to work
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geoserver.wfs.response.CSVOutputFormat]: Constructor threw exception; nested exception is java.lang.IllegalArgumentException: A valid WFS object must be provided in order for this class to work
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:115)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:248)
… 27 more
Caused by: java.lang.IllegalArgumentException: A valid WFS object must be provided in order for this class to work
at org.geoserver.wfs.response.CSVOutputFormat.(CSVOutputFormat.java:55)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:494)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
… 29 more
16 mar 11:04:17 ERROR [mortbay.log] - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@anonymised.com1794…{/geoserver,src/main/webapp}
… 27 more
… 29 more
16 mar 11:04:17 ERROR [mortbay.log] - Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘CSVOutputFormat’ defined in URL [file:/Users/francesco/sviluppoGEOS/trunk/src/wfs/target/classes/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geoserver.wfs.response.CSVOutputFormat]: Constructor threw exception; nested exception is java.lang.IllegalArgumentException: A valid WFS object must be provided in order for this class to work:
I set the config dir to:
- GEOSERVER_DATA_DIR: /Users/francesco/sviluppoGEOS/trunk/data/minimal
but also changing (for ex. release data dir) the same thing happens
Regard,
Francesco Izzi
CNR - IMAA
geoSDI - NSDI
Responsabile Sviluppo Software
C.da Loja
85050 Tito Scalo - POTENZA (PZ)
Italia
phone: +39 0971427305
fax: +39 0971 427271
mob: +39 3402640314
mail: francesco.izzi@anonymised.com
skype: neofx8080
