[Geoserver-devel] Problem with wkb4j-1.0-RC1.jar
Hey all,
I've successfully built an up-to-date geotools-2.2.x branch (currently RC5). Maven is very cool.
I've also successfully built an up-to-date geoserver trunk.
I then went to deploy my geoserver war file, and got the following exception when deploying it inside Tomcat:
java.lang.IllegalArgumentException: log4j,openmap,postgis,jts,junitperf,junit,postgresql-Extension-Name
I narrowed it down to the fact that the MANIFEST.MF inside the wkb4j jar file that's hosted at both maven.geotools.fr (seems to be the one pulled from gt-trunk) and at http://lists.refractions.net/m2 (seems to be the one pulled from gt-2.2.x) includes the line:
*Extension-List: log4j,openmap,postgis,jts,junitperf,junit,postgresql*
From what I understand from here:
http://java.sun.com/j2se/1.5.0/docs/guide/jar/jar.html
and here:
http://java.sun.com/j2se/1.5.0/docs/guide/extensions/versioning.html
this should instead read:
*Extension-List: log4j openmap postgis jts junitperf junit postgresql*
(spaces instead of commas).
However, when I rebuilt the jar with exactly that change to the Extension-List attribute, I got a silent error from Tomcat (even worse).
This copy of wkb4j has been around for a long time (I verified that the same problems were in the MANIFEST.MF file in the version released on sourceforge in 2003), so I can't imagine I'm the first person to run across this.
Anyone else having this problem, or is it confined to linux+tomcat+java 1.5?
--saul
The same here!!
On 7/26/06, Saul Farber <Saul.Farber@anonymised.com> wrote:
Hey all,
I’ve successfully built an up-to-date geotools-2.2.x branch (currently
I’ve also successfully built an up-to-date geoserver trunk.
file that’s hosted at both maven.geotools.fr (seems to be the one pulled
and here:
sourceforge in 2003), so I can’t imagine I’m the first person to run
across this.
–saul
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys – and earn cash
Geoserver-devel mailing list
Alessio Fabiani
Software Engineer
http://afabiani.wordpress.com
But the jar in geoserver works right? So we just need to upload that one to the appropriate repositories?
Alessio Fabiani wrote:
The same here!!
On 7/26/06, *Saul Farber* <Saul.Farber@anonymised.com <mailto:Saul.Farber@anonymised.com>> wrote:
    Hey all,
    <http://maven.geotools.fr> (seems to be the one pulled
    <http://lists.refractions.net/m2&gt; (seems to be the
    and here:
    <http://java.sun.com/j2se/1.5.0/docs/guide/extensions/versioning.html&gt;
    across this.
    --saul
    Join SourceForge.net's Techsay panel and you'll get the chance to
    share your
    opinions on IT & business topics through brief surveys -- and earn cash
    <http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV&gt;
    <mailto:Geoserver-devel@lists.sourceforge.net>
Alessio Fabiani
Software Engineer
--------------------------------------------------------- !DSPAM:1003,44c723b4295631410093335!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
No, having the jar around seems to make geoserver not deploy correctly (tomcat complains about the wkb4j.jar's MANIFEST.MF file, although figuring out which jar and which file took a bit).
It's getting weirder though. Now when I delete that jar file from the WEB-INF/lib directory completely (therefore removing the problem, right?) tomcat fails silently. Not sure what the heck's going on, but I'm upgrading JVMs, and I'm about to upgrade tomcat.
--saul
Sorry, I wasn't clear. The jar that's in the 1.3.x geoserver lib/ dir. It's never had problems with deploying, as far as I know. And it's called wkb4j-1.0-RC1-modified.jar. So it's been modified in some way, I think Andrea may have had a fix on it long ago? So if we use that one in the repositories I think things should work?
Chris
--saul
!DSPAM:1003,44c7915e5222095110867!
Chris Holmes
Hi Saul,
I ran into this problem a while back and the only way I was able to solve it was to repackage the jar with a modified manifest.
I have posted this to the wkb4j mailing list was well. Perhaps it is possible to get a version which does contain this stuff in the MANIFEST.
-Justin
--saul
!DSPAM:1004,44c792907462095110867!
Justin Deoliveira
jdeolive@anonymised.com
I'm pretty sure the wkb4j mailing list is dead. At least it was a couple of years ago when we tried to interact with it.
C
Justin Deoliveira wrote:
Hi Saul,
-Justin
--saul
Chris Holmes
I am not sure about the licencing or IP issues but we could manually modify the jar ourselves, and then post it on our maven repo servers. From what I can tell wkb4j is LGPL.
-Justin
C
Hi Saul,
-Justin
--saul
Justin Deoliveira
We ran with the same issue over here as well. We found 3 ways to fix.
  1. Copy wkb4j.jar’ under \j2sdk{version}\jre\lib\ext.
    It worked without having to change the manifest. Eclipse, Tomcat worked well for us from this point.
  2. Change the manifest as you suggested
  3. Download the source code and re-compile it.
    It is now part of my maven build process. If somebody wants to spend time to make it available on http://www.ibiblio.org/maven2/ and create a pom file version dependency, this would be cool.
Rob
Justin Deoliveira jdeolive@anonymised.com wrote:
Hi Saul,
-Justin
(tomcat complains about the wkb4j.jar’s MANIFEST.MF file, although
It’s getting weirder though. Now when I delete that jar file from the
right?) tomcat fails silently. Not sure what the heck’s going on, but
I’m upgrading JVMs, and I’m about to upgrade tomcat.
–saul
Justin Deoliveira
Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail
Hi Rob,
Thanks for the input, glad to see someone else has already solved this one :).
1) Copy wkb4j.jar' under \j2sdk{version}\jre\lib\ext.
I think this is probably the easiest solution, but I dont really like not being able to run geoserver with an out of the box jvm.
2) Change the manifest as you suggested
3) Download the source code and re-compile it.
I guess these two really amount to the same. If no IP issues ivolved then I say we go for it.
-Justin
Rob
*/Justin Deoliveira <jdeolive@anonymised.com>/* wrote:
    Hi Saul,
    -Justin
    Saul Farber wrote:
     > No, having the jar around seems to make geoserver not deploy
    correctly
     > (tomcat complains about the wkb4j.jar's MANIFEST.MF file, although
     > figuring out which jar and which file took a bit).
     > It's getting weirder though. Now when I delete that jar file from
    the
     > WEB-INF/lib directory completely (therefore removing the problem,
     > right?) tomcat fails silently. Not sure what the heck's going on,
    but
     > I'm upgrading JVMs, and I'm about to upgrade tomcat.
     > --saul
     > Chris Holmes wrote:
     >>But the jar in geoserver works right? So we just need to upload that
     >>one to the appropriate repositories?
     > Take Surveys. Earn Cash. Influence the Future of IT
     > Join SourceForge.net's Techsay panel and you'll get the chance to
    share your
     > opinions on IT & business topics through brief surveys -- and
    earn cash
     > Geoserver-devel mailing list
     > Geoserver-devel@lists.sourceforge.net
     > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
    -- Justin Deoliveira
    share your
Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the *All-new Yahoo! Mail * <http://us.rd.yahoo.com/evt=40705/*http://mrd.mail.yahoo.com/try_beta?.intl=ca&gt; !DSPAM:1004,44c7a37514441425493344!
Justin Deoliveira
Not as it stands on trunk deploying in tomcat with postgis. The dependency is dragged in transivly through geotools. I beleive on 1.3.x the jar has already been modified and hence works.
So yes, we need to modify the jar, and upload to out maven repos?
-Justin
The same here!!
    Hey all,
    and here:
    across this.
    --saul
    share your
Alessio Fabiani
Software Engineer
!DSPAM:1004,44c7ad9a18291194215290!
Justin Deoliveira
