Dear GeoServer developers,
Thanks for your efforts in creating and maintaining GeoServer. I am trying to define my own coordinate system (CRS/SRS) in a Windows 2000 installation of version 1.3.0: I have tried to follow the steps on the FAQ page ‘Custom projection definition in GeoServer’, http://docs.codehaus.org/display/GEOSDOC/Custom+projection+definition+in+Geoserver, but nowhere within either the installed server files or the source tree could I find any file by the names ‘EPSG.sql’ or ‘gt2-epsg-h.jar’, or matching the pattern HSQL. In desperation I tried editing epsg.properties, but its contents (as warned somewhere in the documentation) seem to be entirely ignored by GeoServer.
Does GeoServer 1.3.0 still use gt2-epsg-h.jar, and if so where is it located?
Thanks very much for any help you can give.
Stephen Taylor
This email, and any attachments, may be confidential and also privileged.
If you are not the intended recipient:
Please notify the sender and delete all copies of this transmission along with any attachments immediately.
You should not copy or use it for any purpose, nor disclose its contents to any other person.
