[Geoserver-devel] Problems getting geoserver 0.97 to build..
Greetings.
I'm having a difficult time getting geoserver to build. I'm using Debian Unstable, tomcat4.1, postgres 7.3.3 with the postgis extension, and Java 1.4.1. java -version returns:
(Java(TM) 2 Runtime Environment, Standard Edition (build blackdown-1.4.1-beta) Java HotSpot(TM) Client VM (build Blackdown-1.4.1-beta, mixed mode)
When I do an ant test-ext, I get the following. I'm quite new to tomcat and java in general, so any help at all is appreciated.
Thanks!
Jason Ruiter
jruiter@anonymised.com:~/src/geoserver$ ant test-ext
Buildfile: build.xml
init:
all:
     [javac] Compiling 74 source files to /home/jruiter/src/geoserver/build
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/WfsConfig.java:31: package org.geotools.resources does not exist
     [javac] import org.geotools.resources.Geotools;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/WfsConfig.java:32: package org.geotools.resources does not exist
     [javac] import org.geotools.resources.Log4JFormatter;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/WfsConfig.java:33: package org.geotools.resources does not exist
     [javac] import org.geotools.resources.MonolineFormatter;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/ZServerConfig.java:30: package org.geotools.resources does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/ZServerConfig.java:31: package org.geotools.resources does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/ZServerConfig.java:32: package org.geotools.resources does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:17: package org.geotools.feature does not exist
     [javac] import org.geotools.feature.Feature;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:19: package org.geotools.feature does not exist
     [javac] import org.geotools.feature.FeatureTypeFactory;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:20: package org.geotools.feature does not exist
     [javac] import org.geotools.feature.AttributeType;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:21: package org.geotools.feature does not exist
     [javac] import org.geotools.feature.SchemaException;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:22: package org.geotools.data does not exist
     [javac] import org.geotools.data.DataSource;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:23: package org.geotools.data does not exist
     [javac] import org.geotools.data.DataSourceMetaData;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:24: package org.geotools.data does not exist
     [javac] import org.geotools.data.DataSourceFinder;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:25: package org.geotools.data does not exist
     [javac] import org.geotools.data.DataSourceException;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:26: package org.geotools.data.postgis does not exist
     [javac] import org.geotools.data.postgis.PostgisConnectionFactory;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:27: package org.geotools.data.postgis does not exist
     [javac] import org.geotools.data.postgis.PostgisDataSource;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:28: package org.geotools.data.postgis does not exist
     [javac] import org.geotools.data.postgis.PostgisDataSourceFactory;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:60: cannot resolve symbol
     [javac] symbol : class DataSource
     [javac] location: class org.vfny.geoserver.config.TypeInfo
     [javac] private DataSource transactionDS;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:62: cannot resolve symbol
     [javac] private DataSource featureDSource;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:212: cannot resolve symbol
     [javac] public DataSource getTransactionDataSource() throws WfsException {
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeInfo.java:290: cannot resolve symbol
     [javac] public DataSource getDataSource()
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeRepository.java:10: package org.geotools.filter does not exist
     [javac] import org.geotools.filter.Filter;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeRepository.java:11: package org.geotools.data does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeRepository.java:12: package org.geotools.data does not exist
     [javac] import org.geotools.data.QueryImpl;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeRepository.java:13: package org.geotools.data does not exist
     [javac] import org.geotools.data.Query;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeRepository.java:14: package org.geotools.data does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeRepository.java:15: package org.geotools.feature does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeRepository.java:16: package org.geotools.feature does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeRepository.java:17: package org.geotools.feature does not exist
     [javac] import org.geotools.feature.FeatureCollection;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeRepository.java:273: cannot resolve symbol
     [javac] symbol : class Filter
     [javac] location: class org.vfny.geoserver.config.TypeRepository
     [javac] public boolean isLocked(String typeName, Filter filter, String lockId)
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeRepository.java:310: cannot resolve symbol
     [javac] private List getFidFeatures(String typeName, Filter filter)
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeRepository.java:369: cannot resolve symbol
     [javac] public synchronized String lock(String typeName, Filter filter,
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/config/TypeRepository.java:403: cannot resolve symbol
     [javac] public synchronized String addToLock(String typeName, Filter filter,
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/TransactionRequest.java:10: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/SubTransactionRequest.java:10: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/SubTransactionRequest.java:41: cannot resolve symbol
     [javac] location: class org.vfny.geoserver.requests.SubTransactionRequest
     [javac] public void setFilter(Filter filter) throws WfsException {}
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/RequestKvpReader.java:15: package org.geotools.filter does not exist
     [javac] import org.geotools.filter.FilterFactory;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/RequestKvpReader.java:16: package org.geotools.filter does not exist
     [javac] import org.geotools.filter.AbstractFilter;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/RequestKvpReader.java:17: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/RequestKvpReader.java:18: package org.geotools.filter does not exist
     [javac] import org.geotools.filter.FidFilter;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/RequestKvpReader.java:19: package org.geotools.filter does not exist
     [javac] import org.geotools.filter.FidFilterImpl;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/RequestKvpReader.java:20: package org.geotools.filter does not exist
     [javac] import org.geotools.filter.GeometryFilter;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/RequestKvpReader.java:21: package org.geotools.filter does not exist
     [javac] import org.geotools.filter.AttributeExpression;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/RequestKvpReader.java:22: package org.geotools.filter does not exist
     [javac] import org.geotools.filter.LiteralExpression;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/RequestKvpReader.java:23: package org.geotools.filter does not exist
     [javac] import org.geotools.filter.IllegalFilterException;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/RequestKvpReader.java:70: cannot resolve symbol
     [javac] symbol : class FilterFactory
     [javac] location: class org.vfny.geoserver.requests.RequestKvpReader
     [javac] private static FilterFactory factory = FilterFactory.createFilterFactory();
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/DeleteKvpReader.java:10: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/DeleteKvpReader.java:11: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/DeleteRequest.java:10: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/DeleteRequest.java:48: cannot resolve symbol
     [javac] location: class org.vfny.geoserver.requests.DeleteRequest
     [javac] protected Filter filter = null;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/DeleteRequest.java:70: cannot resolve symbol
     [javac] public Filter getFilter() { return filter; }
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/DeleteRequest.java:73: cannot resolve symbol
     [javac] public void setFilter(Filter filter) { this.filter = filter; }
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/DispatcherHandler.java:15: package org.geotools.filter does not exist [javac] import org.geotools.filter.Filter;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/DispatcherHandler.java:16: package org.geotools.filter does not exist [javac] import org.geotools.filter.FilterHandler;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FeatureHandler.java:14: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FeatureHandler.java:15: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FeatureHandler.java:32: cannot resolve symbol
     [javac] symbol : class FilterHandler
     [javac] location: class org.vfny.geoserver.requests.FeatureHandler
     [javac] implements ContentHandler, FilterHandler {
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/Query.java:9: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/Query.java:10: package org.geotools.feature does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/Query.java:11: package org.geotools.data does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/Query.java:12: package org.geotools.feature does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/Query.java:13: package org.geotools.feature does not exist
     [javac] import org.geotools.feature.FeatureType;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/Query.java:49: cannot resolve symbol
     [javac] location: class org.vfny.geoserver.requests.Query
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/Query.java:106: cannot resolve symbol
     [javac] public void addFilter (Filter filter) { this.filter = filter; }
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/Query.java:109: cannot resolve symbol
     [javac] public Filter getFilter() { return this.filter; }
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/Query.java:115: cannot resolve symbol
     [javac] symbol : class FeatureType
     [javac] public org.geotools.data.Query getDataSourceQuery(FeatureType schema,
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/Query.java:115: package org.geotools.data does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FeatureHandler.java:173: cannot resolve symbol
     [javac] public void filter(Filter filter) {
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FeatureKvpReader.java:10: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FeatureKvpReader.java:11: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FeatureKvpReader.java:157: cannot resolve symbol
     [javac] location: class org.vfny.geoserver.requests.FeatureKvpReader
     [javac] Filter filter)
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockRequest.java:12: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockRequest.java:215: cannot resolve symbol
     [javac] location: class org.vfny.geoserver.requests.LockRequest.Lock
     [javac] protected Filter filter;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockRequest.java:234: cannot resolve symbol
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockRequest.java:237: cannot resolve symbol
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockRequest.java:102: cannot resolve symbol
     [javac] public void addLock(String featureType, Filter filter, String handle){
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockRequest.java:115: cannot resolve symbol
     [javac] public void addLock(String featureType, Filter filter){
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FilterHandlerImpl.java:14: package org.geotools.filter does not exist [javac] import org.geotools.filter.Filter;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FilterHandlerImpl.java:15: package org.geotools.filter does not exist [javac] import org.geotools.filter.FilterHandler;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FilterHandlerImpl.java:26: cannot resolve symbol
     [javac] location: class org.vfny.geoserver.requests.FilterHandlerImpl
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FilterHandlerImpl.java:33: cannot resolve symbol
     [javac] private Filter currentFilter = null;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FilterHandlerImpl.java:47: cannot resolve symbol
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/FilterHandlerImpl.java:56: cannot resolve symbol
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/InsertRequest.java:12: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/InsertRequest.java:13: package org.geotools.feature does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/InsertRequest.java:68: cannot resolve symbol
     [javac] location: class org.vfny.geoserver.requests.InsertRequest
     [javac] public void addFeature(Feature feature) throws WfsException {
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/InsertRequest.java:91: cannot resolve symbol
     [javac] public void addFeatures(Feature features) throws WfsException {
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/InsertRequest.java:129: cannot resolve symbol
     [javac] public Feature getFeatures(){
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/InsertRequest.java:138: cannot resolve symbol
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockHandler.java:14: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockHandler.java:15: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockHandler.java:31: cannot resolve symbol
     [javac] location: class org.vfny.geoserver.requests.LockHandler
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockHandler.java:50: cannot resolve symbol
     [javac] private Filter curFilter;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockHandler.java:175: cannot resolve symbol
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockKvpReader.java:10: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/LockKvpReader.java:11: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/TransactionFeatureHandler.java:12: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/TransactionFeatureHandler.java:13: package org.geotools.filter does not exist
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/TransactionFeatureHandler.java:14: package org.geotools.gml does not exist
     [javac] import org.geotools.gml.GMLHandlerFeature;
     [javac] ^
     [javac] /home/jruiter/src/geoserver/src/org/vfny/geoserver/requests/TransactionFeatureHandler.java:15: package org.geotools.gml does not exist
     [javac] import org.geotools.gml.GMLFilterFeature;
     [javac] ^
     [javac] Note: Some input files use or override a deprecated API.
     [javac] Note: Recompile with -deprecation for details.
     [javac] 100 errors
BUILD FAILED
file:/home/jruiter/src/geoserver/build.xml:161: Compile failed; see the compiler error output for details.
Jason Ruiter
Research Computer Engineer, Emerging Technologies Group
Altarum Institute
Ann Arbor, Michigan, USA
(v)734.302.4724 (f)734.302.4991 (m)734.476.8299
Jason.Ruiter@anonymised.com
Hmmm... It looks like it isn't picking up the geotools.jar. Is that jar
in ~/src/geoserver/lib ? The other thing I'm curious about is the
blackdown jre, as it's in beta? Do you need to use the blackdown port?
Have you tried the official sun linux releases? They're in 1.4.1_04.
Also, it looks like blackdown's at 1.4.1-01, out of beta, so you might try
that. Though I don't see why that would prevent ant from picking up the
correct jars. What version of ant are you using?
  Chris
On Tue, 12 Aug 2003, Jason Ruiter wrote:
Greetings.
Thanks!
Jason Ruiter
init:
all:
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
WfsException {
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
String lockId)
     [javac] ^
     [javac]
     [javac] ^
     [javac]
filter,
     [javac] ^
     [javac]
Filter filter,
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
filter; }
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
filter; }
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
filter; }
     [javac] ^
     [javac]
String handle){
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
WfsException {
     [javac] ^
     [javac]
WfsException {
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac]
     [javac] ^
     [javac] 100 errors
BUILD FAILED
