[Geoserver-devel] problems in building GeoServer1.5 in eclipse
hello everyone:
I have tried to build GeoServer1.5 under the steps in the doucuments.
first :check out from https://svn.codehaus.org/geoserver/trunk
then :mvn install (the client terminal showed all the moudles were
successfully builded)
mvn eclipse:eclipse;
set the variarable M2_REPO
after import existing projects into the workspace there are server projects
not only one in the workspace,and there are errors like Project Issues is
missing required library: 'C:\Documents and
Settings\Administrator\.m2\repository\antlr\antlr\2.7.6\antlr-2.7.6.jar'
I tried to setup a new project first and then import all the source code but
i got more errors.
I am expecting your help thank you !
View this message in context: http://www.nabble.com/problems-in-building-GeoServer1.5-in-eclipse-tf3610882.html#a10090590
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
The Issues project you can safely ignore. It is a "community" module which means it is experimental and not really part of the core. If you want something more stable to build i suggest you check out the 1.5.x branch instead of trunk (1.6.x). The svn url is:
https://svn.codehaus.org/geoserver/branches/1.5.x
But if you want to continue on trunk then I suggest you just delete the "Issues" project from your workspace.
-Justin
cy wrote:
hello everyone: I have tried to build GeoServer1.5 under the steps in the doucuments. first :check out from https://svn.codehaus.org/geoserver/trunk then :mvn install (the client terminal showed all the moudles were
successfully builded) mvn eclipse:eclipse; set the variarable M2_REPO after import existing projects into the workspace there are server projects
Settings\Administrator\.m2\repository\antlr\antlr\2.7.6\antlr-2.7.6.jar' I tried to setup a new project first and then import all the source code but
i got more errors. I am expecting your help thank you !
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Justin Deoliveira ha scritto:
Umpf, this Issues project is there to cause issues to people trying
to develop against Geoserver. Community modules are out of build,
but I guess this module has Eclipse project files committed... we
shall remove them at once (not on my computer today, but I'll obliterate
them as soon as possible when I get back home, provided no-one else
does it before).
thank you very much for your help
I have tried to build from https://svn.codehaus.org/geoserver/branches/1.5.x
follow the Justin"s advice,i have build the geoserver by maven successfully
but I also get problems in eclipse:Cannot find the class file for
org.geotools.catalog.ResolveAdapterFactory.
It seems that some jar are needed .Please help me .thank you very much!
View this message in context: http://www.nabble.com/problems-in-building-GeoServer1.5-in-eclipse-tf3610882.html#a10102988
Do you get this error when you try to run GeoServer? Or is it another
compile error?
Justin Deoliveira
jdeolive@anonymised.com
