[Geoserver-devel] Problems start up with the geoServer
After i put the _war file in the tomcat webapp folder, i use my broswer to open the following url:
http://localhost:8080/geoserver/wfs/GetCapabilities>>
And it appears a XML file.
Then when i try to locate: http://localhost:8080/geoserver/>>
It comes out some errors:
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.apache.jasper.JasperException: Unable to compile class for JSP org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:97) org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:346) org.apache.jasper.compiler.Compiler.generateClass(Compiler.java:414) org.apache.jasper.compiler.Compiler.compile(Compiler.java:472) org.apache.jasper.compiler.Compiler.compile(Compiler.java:451) org.apache.jasper.compiler.Compiler.compile(Compiler.java:439) org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:511) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:295) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:292) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:236) javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
root cause
Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK org.apache.tools.ant.taskdefs.compilers.CompilerAdapterFactory.getCompiler(CompilerAdapterFactory.java:106) org.apache.tools.ant.taskdefs.Javac.compile(Javac.java:935) org.apache.tools.ant.taskdefs.Javac.execute(Javac.java:764) org.apache.jasper.compiler.Compiler.generateClass(Compiler.java:382) org.apache.jasper.compiler.Compiler.compile(Compiler.java:472) org.apache.jasper.compiler.Compiler.compile(Compiler.java:451) org.apache.jasper.compiler.Compiler.compile(Compiler.java:439) org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:511) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:295) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:292) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:236) javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
note The full stack trace of the root cause is available in the Apache Tomcat/5.0.27 logs.
It says that i haven’t define JAVA_HOME, then i go to check it:
C:\Documents and Settings\installer>echo JAVA_HOME
C:\j2sdk1.4.2_05
It is correctly defined already.
Do any one know how to solve this problem??
: : : MARCELO : : :
Do you Yahoo!?
Win 1 of 4,000 free domain names from Yahoo! Enter now.
In your c:\j2sdk1.4.2_05\bin directory is there a javac file? Like
javac.exe? Is there a java.exe? If that weren't there I think that
would do it... You could try installing another jdk.
Also, have you tried any other servlet containers? Maybe the latest
tomcat4? Or resin?
Quoting Marcelo Chong <macaulinux@anonymised.com>:
http://localhost:8080/geoserver/wfs/GetCapabilities&gt;&quot;
src="http://docs.codehaus.org/images/icons/linkext7.gif&quot; width=7
align=absMiddle border=0>
Then when i try to locate: http://localhost:8080/geoserver/&gt;&quot;
HTTP Status 500 -
message
exception
root cause
It says that i haven't define JAVA_HOME, then i go to check it:
C:\j2sdk1.4.2_05
: : : MARCELO : : :
Do you Yahoo!?
This mail sent through IMP: https://webmail.limegroup.com/
