Hello,
I am trying to access a postgis database (linux box) from a working
geoserver 1.2.2 installation (windows box) running Tomcat 4.1.12.
Everything works just fine until I select a FeatureType and click Apply, I
get the exception below. It works fine on another machine with Tomcat 5
(unfortunately the one failing is our production server and cannot be
updated at the moment). The machine giving problems with postgis is working
OK with Oracle Spatial. I would hate to go back and configure by hand, just
got too used to the web interface (fast and very useful).
Any ideas??. Thanks in advance.
Here is the error Tomcat's spitting out:
javax.servlet.ServletException
at
org.apache.struts.action.RequestProcessor.processException(RequestProcessor.java:545)
at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:486)
at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
at
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
at
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:525)
at
javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
at
javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:247)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193)
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:260)
at
org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:643)
at
org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:480)
at
org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at
at
at
at
org.apache.catalina.core.StandardContext.invoke(StandardContext.java:2396)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:180)
at
at
org.apache.catalina.valves.ErrorDispatcherValve.invoke(ErrorDispatcherValve.java:170)
at
org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:641)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:172)
at
at
at
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:174)
at
at
at
at
org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:223)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:405)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:380)
at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:508)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:533)
at java.lang.Thread.run(Thread.java:536)
root cause
java.util.ConcurrentModificationException
at java.util.HashMap$HashIterator.nextEntry(HashMap.java:750)
at java.util.HashMap$EntryIterator.next(HashMap.java:792)
at
org.vfny.geoserver.global.DataStoreInfo.getParams(DataStoreInfo.java:141)
at
org.vfny.geoserver.global.DataStoreInfo.toString(DataStoreInfo.java:298)
at java.lang.String.valueOf(String.java:2173)
at java.lang.StringBuffer.append(StringBuffer.java:369)
at
org.vfny.geoserver.global.Data.loadFeatureTypes(Data.java:330)
at org.vfny.geoserver.global.Data.load(Data.java:161)
at
org.vfny.geoserver.action.UpdateGSAction.updateGeoserver(UpdateGSAction.java:69)
at
org.vfny.geoserver.action.UpdateGSAction.execute(UpdateGSAction.java:46)
at
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:98)
at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Juan Marín Otero
TRAGSATEC S.A.
Departamento de Cartografía
Tlf. 91 322 64 98
Este correo es sólo informativo y por lo tanto no supone obligación
contractual para TRAGSATEC ni para las sociedades a ella vinculadas. La
información incluida en el presente correo electrónico es CONFIDENCIAL,
siendo para el uso exclusivo del destinatario arriba mencionado. Si usted
lee este mensaje y no es el destinatario señalado, el empleado o el agente
responsable de entregar el mensaje al destinatario, o ha recibido esta
comunicación por error, le informamos que está totalmente prohibido
cualquier almacenamiento, divulgación, distribución o reproducción de esta
comunicación y de los archivos que pueda contener. Le rogamos que nos lo
notifique, devuelva el original al emisor del correo y destruya el mensaje.
El correo electrónico vía Internet no permite asegurar la confidencialidad
de los mensajes que se transmiten, ni su integridad o correcta recepción.
TRAGSATEC no asume responsabilidad por estas circunstancias. Si el
destinatario de este mensaje no consintiera la utilización del correo
electrónico vía Internet y la grabación de los mensajes, rogamos lo ponga
en nuestro conocimiento de forma inmediata.
