[Geoserver-devel] Problems with implementing REST service
I am a newbie and have been working with GeoServer for about 2 weeks now. I
have been asked to look into implementing a REST service to change the SLD
for the WMS images.
I am running geoserver from the source code through eclipse. I am not sure
how to check the build date but the branch file in the source code has the
following content:
afabiani * r10114 /branches/1.7.x_WCS10EMF_ND: - Preparing for branching
afabiani * r10115 /branches/1.7.x_WCS10EMF_ND/geoserver:
The geoserver build already had a rest-1.7.5-SNAPSHOT.jar file under
WEB-INF/lib folder but I also installed the REST extension from
http://downloads.sourceforge.net/geoserver/geoserver-1.7.5-restconfig-plugin.zip
here and added the restconfig-1.7.5.jar under the same folder
I followed the instructions for the REST services available
http://docs.geoserver.org/1.7.x/developer/programming-guide/rest-services/implementing.html
here . The only changes I had to make was in the pom.xml file where i
changed the org.geoserver versions to "1.7.5-SNAPSHOT" from "1.7.3-SNAPSHOT"
(i compared it with the other pom.xml files). The hello_rest module compiled
successfully. I then tried testing the rest service by going to the URL:
http://localhost:8080/geoserver/rest/hello.txt
http://localhost:8080/geoserver/rest/hello_rest/hello.txt
I was not sure which one is correct so I tried all in the browser. And all I
see is this:
Geoserver Configuration API
    * exception
What am I doing wrong here?
View this message in context: http://n2.nabble.com/Problems-with-implementing-REST-service-tp3129997p3129997.html
Sent from the GeoServer developers mailing list archive at Nabble.com.
sabman ha scritto:
  > I followed the instructions for the REST services available
see is this:
    * exception
Did you actually include your jar/project in the GeoServer application
classpath? E.g, took the hello_rest jar and drop it into geoserver/WEB-INF/lib?
Can you look in $GEOSERVER_DATA_DIR/logs/geoserver.log and see what exception (with full strack trace) is thrown when you try to access those URL's?
I did not copy the jar file in the WEB-INF/lib folder. I did that now but its
still the same.
There is no information related to the exception in the log file. There are
some errors messages in eclipse which I am listing below:
1) In the HelloResource.java file,
For this piece of code:
  protected Map<String, DataFormat> createSupportedFormats(Request request,
Response response) {
     HashMap formats = new HashMap();
     formats.put( "txt", new StringFormat( MediaType.TEXT_PLAIN ));
     return formats;
These are the errors:
@ Map<String, DataFormat> Multiple markers at this line
  - The return type is incompatible with
AbstractResource.createSupportedFormats(Request,
   Response)
  - implements org.geoserver.rest.AbstractResource.createSupportedFormats
@HashMap Multiple markers at this line
  - HashMap cannot be resolved
   to a type
   to a type
@StringFormat and @MediaType Multiple markers at this line
  - StringFormat cannot be resolved
   to a type
  - MediaType cannot be resolved
2) When i start geoserver from eclipse by running the Start.java file I see
the following warning messages in the console:
Jun 22, 2009 11:14:11 AM it.geosolutions.imageio.gdalframework.GDALUtilities
loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no
gdaljni in java.library.path
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
"1.7.3-SNAPSHOT"
compiled
all I
see is this:
    * exception
those URL's?
Are you an open source citizen? Join us for the Open Source Bridge
conference!
Portland, OR, June 17-19. Two days of sessions, one day of unconference:
$250.
Need another reason to go? 24-hour hacker lounge. Register today!
http://ad.doubleclick.net/clk;215844324;13503038;v?http://opensourcebridge.org
Geoserver-devel mailing list
View this message in context: http://n2.nabble.com/Problems-with-implementing-REST-service-tp3129997p3136913.html
Hi Andrea,
Are the above errors normal? Any particular reason why I am not able to see
the full stack exception in the log file ?
View this message in context: http://n2.nabble.com/Problems-with-implementing-REST-service-tp3129997p3138732.html
still the same.
Did you restart geoserver after you did?
Yeah, there probably won't be an exception, just nothing in the log file. It could also be that your applicationContext.xml file is in the wrong place. Is it under src/main/java in the root of your plugin source?
Can you do a "jar tvf hello_rest.jar" to give us a listing of the files. Thanks.
1) In the HelloResource.java file, For this piece of code: protected Map<String, DataFormat> createSupportedFormats(Request request,
     return formats;
AbstractResource.createSupportedFormats(Request, Response)
  - HashMap cannot be resolved to a type
  - StringFormat cannot be resolved to a type
These are because the rest module is not on the classpath of your module. Can you run a mvn eclipse:eclipse in the root of your module and then refresh the project in eclipse. I think the tutorial is lackign that step.
loadGDAL
That is normal, you can ignore that.
"1.7.3-SNAPSHOT"
compiled
all I
see is this:
    * exception
conference!
$250.
Justin Deoliveira
OpenGeo - http://opengeo.org
Thanks Justin.
Here is what I was doing wrong. I created the folders src/main/java and
src/test/java under rest/hello_rest. When I created the class files, eclipse
was creating the files under the rest/src/java folder instead of
rest/hello_rest/src/java.
So now I made sure that the HelloResource.java file is located under the
correct folder and there were no errors. (But I could see that the
StringFormat and MediaType objects were not being recognized correctly.)
Also I moved the applicationContext.xml file from the resources folder(as
mentioned in the tutorial) to the src/main/java folder (as you mentioned.).
Also made sure the HelloResourceTest.java file is under the correct folder.
Now when I run mvn install under the root module I get the following
compilation error:
[INFO] Compiling 1 source file to
/home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/target/classes
[INFO]
[ERROR] BUILD FAILURE [INFO]
[INFO] Compilation failure
/home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[9,7]
org.geoserver.hellorest.HelloResource is not abstract and does not override
abstract method
createSupportedFormats(org.restlet.data.Request,org.restlet.data.Response)
in org.geoserver.rest.AbstractResource
/home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[12,38]
in org.geoserver.hellorest.HelloResource cannot override
in org.geoserver.rest.AbstractResource; attempting to use incompatible
return type found :
java.util.Map<java.lang.String,org.geoserver.rest.format.DataFormat>
required: java.util.List<org.geoserver.rest.format.DataFormat>
/home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[14,7]
cannot find symbol symbol : class HashMap location: class
/home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[14,29]
/home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[15,31]
cannot find symbol symbol : class StringFormat location: class
/home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[15,45]
cannot find symbol symbol : variable MediaType location: class
/home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[11,4]
method does not override or implement a method from a supertype
Justin Deoliveira wrote:
its
still the same.
are
Thanks.
request,
     return formats;
   Response)
   to a type
   to a type
   to a type
that step.
see
loadGDAL
"1.7.3-SNAPSHOT"
compiled
URL:
all I
see is this:
    * exception
those URL's?
conference!
$250.
Justin Deoliveira
conference!
$250.
View this message in context: http://n2.nabble.com/Problems-with-implementing-REST-service-tp3129997p3139965.html
Hmmm... can you zip up your project and send it to me in a private email? It looks like the classpath is somehow off, and it would be nice to look at the eclipse .classpath file, along with the sources.
-Justin
sabman wrote:
Thanks Justin.
compilation error:
[INFO]
[INFO] Compilation failure /home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[9,7]
abstract method
in org.geoserver.rest.AbstractResource /home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[12,38]
return type found :
required: java.util.List<org.geoserver.rest.format.DataFormat> /home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[14,7]
org.geoserver.hellorest.HelloResource /home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[14,29]
org.geoserver.hellorest.HelloResource /home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[15,31]
org.geoserver.hellorest.HelloResource /home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[15,45]
org.geoserver.hellorest.HelloResource /home/sabman/Documents/Projects/geoserver/src/rest/hello_rest/src/main/java/HelloResource.java:[11,4]
its
still the same.
are
request,
     return formats;
see
loadGDAL
"1.7.3-SNAPSHOT"
compiled
URL:
all I
see is this:
    * exception
conference!
$250.
Justin Deoliveira
conference!
$250.
Justin Deoliveira
Hi Sebastin,
Thanks for sending me over your code. I took at a look at it and here is
what I found.
First off, there was a problem with the documentation, it was out of date.
Apologies I should have seen that right away. The createSupportedFormats()
method should return a list, rather than a map. I have updated the
documentation here:
There were also a few other issues with teh code:
* The sources and test files are not in the proper location with regard to
packaging. You need to move src/main/java/HelloResource.java to
src/main/java/org/geoserver/hellorest/HelloResource.java. And similarly for
the the HelloResourceTest.java file.
* A few imports were missing from HelloResource:
import org.geoserver.rest.format.StringFormat;
import org.restlet.data.MediaType;
You also now will need:
import java.util.ArrayList;
import java.util.List;
Let me know if that works. After making those changes I was able to
successfully run HelloResourceTest.
-Justin
On Wed, 24 Jun 2009 11:43:05 -0400, Sebastin Kolman <saby83@anonymised.com>
wrote:
Thanks Justin. Did you mean just the hello_rest module? I have attached
it
with this mail.
I am also just learning Java so yeah I could be doing a simple thing
really
wrong.
On Tue, Jun 23, 2009 at 9:51 PM, Justin Deoliveira
email?
at
-Justin
sabman wrote:
Thanks Justin.
eclipse
the
correctly.)
folder(as
mentioned.).
folder.
compilation error:
[INFO]
override
abstract method
return type found :
but
its
still the same.
There
are
file.
files.
Thanks.
request,
          return formats;
       - implements
module.
step.
file
I
see
loadGDAL
no
i
"1.7.3-SNAPSHOT"
compiled
URL:
And
all I
see is this:
   * exception
application
those
URL's?
conference!
unconference:
$250.
Justin Deoliveira
conference!
unconference:
$250.
Justin Deoliveira
Justin Deoliveira
Hi Justin,
I followed your instructions and the module installed just fine. As I mentioned earlier I am running geoserver from the source code through eclipse. I start geoserver by running the Start.java file under web/src/test/java/org/vfny/
geoserver/jetty/.
After doing the mvn install will it work if i simple stop and start the servert? Or do I need to do a mvn install on the whole geoserver project again ?
How do I test this module? I assume it is by going to this url:
On Thu, Jun 25, 2009 at 4:25 AM, Justin Deoliveira <jdeolive@anonymised.com1501…> wrote:
Hi Sebastin,
what I found.
documentation here:
  • The sources and test files are not in the proper location with regard to
  • A few imports were missing from HelloResource:
-Justin
it
with this mail.
really
wrong.
Hmmm… can you zip up your project and send it to me in a private
email?
at
-Justin
sabman wrote:
Thanks Justin.
eclipse
the
correctly.)
folder(as
mentioned.).
folder.
compilation error:
[INFO]
override
abstract method
return type found :
but
its
still the same.
There
are
Yeah, there probably won’t be an exception, just nothing in the log
file.
Can you do a “jar tvf hello_rest.jar” to give us a listing of the
files.
Thanks.
  1. In the HelloResource.java file, For this piece of code:
    request,
formats.put( “txt”, new StringFormat( MediaType.TEXT_PLAIN
return formats;
  • The return type is incompatible with
  • implements
  • HashMap cannot be resolved to a type
  • StringFormat cannot be resolved to a type
  • MediaType cannot be resolved
module.
step.
  1. When i start geoserver from eclipse by running the Start.java
    file
    I
    see
loadGDAL
no
i
changed the org.geoserver versions to “1.7.5-SNAPSHOT” from
“1.7.3-SNAPSHOT”
compiled
URL:
And
all I
see is this:
  • exception
application
those
URL’s?
conference!
unconference:
$250.
Justin Deoliveira
conference!
unconference:
$250.
Justin Deoliveira
Justin Deoliveira
Sebastin
You have a few options for getting the extension running as part of geoserver.
The first is to manually modify the classpath of the web module, and add the hello_rest module. (Right click on module in package explorer, click Properties, go to Java Build Path -> Projects)
The second is to set up a profile for the module, and run eclipse:eclipse with the profile engaged, which will set up the dependency from the web module. This is quite a bit more work, see:
http://docs.geoserver.org/1.7.x/en/developer/policies/community-modules.html#id3
(Just steps 1 - 3)
The last would be if you have a local geoserver that you use you can drop the file hello_rest/target/hello_rest-1.0-SNAPSHOT.jar into the WEB-INF/lib directory of your geoserver installation, and restart it.
Hope that helps.
-Justin
Sebastin Kolman wrote:
Hi Justin,
geoserver/jetty/.
On Thu, Jun 25, 2009 at 4:25 AM, Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    Hi Sebastin,
    what I found.
    date.
    documentation here:
    regard to
    similarly for
    -Justin
    <saby83@anonymised.com <mailto:saby83@anonymised.com>>
    wrote:
     > Thanks Justin. Did you mean just the hello_rest module? I have
    attached
    it
     > with this mail.
     > I am also just learning Java so yeah I could be doing a simple thing
    really
     > wrong.
     > On Tue, Jun 23, 2009 at 9:51 PM, Justin Deoliveira
     > <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>>wrote:
     >> Hmmm... can you zip up your project and send it to me in a private
    email?
     >> It looks like the classpath is somehow off, and it would be nice
    to look
     >> at
     >> the eclipse .classpath file, along with the sources.
     >> -Justin
     >> sabman wrote:
     >>> Thanks Justin.
     >>> Here is what I was doing wrong. I created the folders
    src/main/java and
     >>> src/test/java under rest/hello_rest. When I created the class
    files,
     >>> eclipse
     >>> was creating the files under the rest/src/java folder instead of
     >>> rest/hello_rest/src/java.
     >>> So now I made sure that the HelloResource.java file is located
    under
    the
     >>> correct folder and there were no errors. (But I could see that the
     >>> StringFormat and MediaType objects were not being recognized
    correctly.)
     >>> Also I moved the applicationContext.xml file from the resources
     >>> folder(as
     >>> mentioned in the tutorial) to the src/main/java folder (as you
     >>> mentioned.).
     >>> Also made sure the HelloResourceTest.java file is under the correct
     >>> folder.
     >>> Now when I run mvn install under the root module I get the
    following
     >>> compilation error:
     >>> [INFO] Compiling 1 source file to
     >>> [INFO]
     >>> [ERROR] BUILD FAILURE [INFO]
     >>> [INFO] Compilation failure
     >>> org.geoserver.hellorest.HelloResource is not abstract and does not
     >>> override
     >>> abstract method
     >>> in org.geoserver.rest.AbstractResource
     >>> in org.geoserver.hellorest.HelloResource cannot override
     >>> in org.geoserver.rest.AbstractResource; attempting to use
    incompatible
     >>> return type found :
     >>> required: java.util.List<org.geoserver.rest.format.DataFormat>
     >>> cannot find symbol symbol : class HashMap location: class
     >>> cannot find symbol symbol : class StringFormat location: class
     >>> cannot find symbol symbol : variable MediaType location: class
     >>> method does not override or implement a method from a supertype
     >>> Justin Deoliveira wrote:
     >>>> sabman wrote:
     >>>>> I did not copy the jar file in the WEB-INF/lib folder. I did
    that now
     >>>>> but
     >>>>> its
     >>>>> still the same.
     >>>> Did you restart geoserver after you did?
     >>>>> There is no information related to the exception in the log file.
     >>>>> There
     >>>>> are
     >>>>> some errors messages in eclipse which I am listing below:
     >>>> Yeah, there probably won't be an exception, just nothing in
    the log
     >>>> file.
     >>>> It could also be that your applicationContext.xml file is in
    the wrong
     >>>> place. Is it under src/main/java in the root of your plugin
    source?
     >>>> Can you do a "jar tvf hello_rest.jar" to give us a listing of the
     >>>> files.
     >>>> Thanks.
     >>>>> 1) In the HelloResource.java file, For this piece of code:
     >>>>> protected Map<String, DataFormat> createSupportedFormats(Request
     >>>>> request,
     >>>>> Response response) {
     >>>>> HashMap formats = new HashMap();
     >>>>> formats.put( "txt", new StringFormat(
     >>>>> return formats;
     >>>>> These are the errors:
     >>>>> @ Map<String, DataFormat> Multiple markers at this line
     >>>>> - The return type is incompatible with
     >>>>> AbstractResource.createSupportedFormats(Request, Response)
     >>>>> - implements
     >>>>> org.geoserver.rest.AbstractResource.createSupportedFormats
     >>>>> @HashMap Multiple markers at this line
     >>>>> - HashMap cannot be resolved to a type
     >>>>> @StringFormat and @MediaType Multiple markers at this line
     >>>>> - StringFormat cannot be resolved to a type
     >>>>> - MediaType cannot be resolved
     >>>> These are because the rest module is not on the classpath of your
     >>>> module.
     >>>> Can you run a mvn eclipse:eclipse in the root of your module
    and then
     >>>> refresh the project in eclipse. I think the tutorial is
    lackign that
     >>>> step.
     >>>>> 2) When i start geoserver from eclipse by running the Start.java
    file
     >>>>> I
     >>>>> see
     >>>>> the following warning messages in the console:
     >>>>> Jun 22, 2009 11:14:11 AM
     >>>>> it.geosolutions.imageio.gdalframework.GDALUtilities
     >>>>> loadGDAL
     >>>>> WARNING: Native library load
    no
     >>>>> gdaljni in java.library.path
     >>>>> log4j:WARN File option not set for appender [geoserverlogfile].
     >>>>> log4j:WARN Are you using FileAppender instead of ConsoleAppender?
     >>>> That is normal, you can ignore that.
     >>>>> aaime wrote:
     >>>>>> sabman ha scritto:
     >>>>>> > I followed the instructions for the REST services available
     >>>>>>> here . The only changes I had to make was in the pom.xml
    file where
     >>>>>>> i
     >>>>>>> changed the org.geoserver versions to "1.7.5-SNAPSHOT" from
     >>>>>>> "1.7.3-SNAPSHOT"
     >>>>>>> (i compared it with the other pom.xml files). The
    hello_rest module
     >>>>>>> compiled
     >>>>>>> successfully. I then tried testing the rest service by
    going to the
     >>>>>>> URL:
     >>>>>>> http://localhost:8080/geoserver/rest/hello.txt
     >>>>>>> http://localhost:8080/geoserver/rest/hello_rest/hello.txt
     >>>>>>> I was not sure which one is correct so I tried all in the
    browser.
     >>>>>>> And
     >>>>>>> all I
     >>>>>>> see is this:
     >>>>>>> Geoserver Configuration API
     >>>>>>> * exception
     >>>>>>> What am I doing wrong here?
     >>>>>> Did you actually include your jar/project in the GeoServer
     >>>>>> application
     >>>>>> classpath? E.g, took the hello_rest jar and drop it into
     >>>>>> geoserver/WEB-INF/lib?
     >>>>>> Can you look in $GEOSERVER_DATA_DIR/logs/geoserver.log and
    see what
     >>>>>> exception (with full strack trace) is thrown when you try to
    access
     >>>>>> those
     >>>>>> URL's?
     >>>>>> Cheers
     >>>>>> Andrea
     >>>>>> Are you an open source citizen? Join us for the Open Source
    Bridge
     >>>>>> conference!
     >>>>>> Portland, OR, June 17-19. Two days of sessions, one day of
     >>>>>> unconference:
     >>>>>> $250.
     >>>>>> Need another reason to go? 24-hour hacker lounge. Register
    today!
     >>>>>> _______________________________________________
     >>>>>> Geoserver-devel mailing list
     >>>>>> Geoserver-devel@lists.sourceforge.net
    <mailto:Geoserver-devel@lists.sourceforge.net>
     >>>>>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
     >>>> Justin Deoliveira
     >>>> OpenGeo - http://opengeo.org
     >>>> Enterprise support for open source geospatial.
     >>>> Are you an open source citizen? Join us for the Open Source Bridge
     >>>> conference!
     >>>> unconference:
     >>>> $250.
     >>>> Need another reason to go? 24-hour hacker lounge. Register today!
    Justin Deoliveira
Sebastin
Justin Deoliveira
hmm…so here is what happened.
I tried to follow your first solution of modifying the class path of the web module. But eclipse did not recognize the hello_rest module because I had not set it as a java project. So I deleted the project and started a new java project and followed the instructions again provided at
There were some errors like:
The declared package “org.geoserver.hellorest” does not match the expected package “src.main.java.org.geoserver.hellorest” HelloResource.java hello_rest/src/main/java/org/geoserver/hellorest line 1 Java Problem
The import org.geoserver cannot be resolved HelloResource.java hello_rest/src/main/java/org/geoserver/hellorest line 4 Java Problem
The import org.restlet cannot be resolved HelloResource.java hello_rest/src/main/java/org/geoserver/hellorest line 6 Java Problem
But I did the mvn install and the build was successful. I added the module to the web module’s classpath and restarted the geoserver by running the Start.java file under web/src/test/java/org/vfny/geoserver/jetty/. But the http requests,
still return the exception.
I also tried running a separate local geoserver. So I installed geoserver 1.7.6 and then added the hello_rest-1.7.5-SNAPSHOT.jar file in the WEB-INF/lib folder. I sensed it would not work becasue the versions are different. When I sent the http requests it returned no exceptions. All that the page returned was “Geoserver Configuration API”. I checked the log and it seems that the request was successful:
0:0:0:0:0:0:0:1 - - [17/Aug/2009:14:49:20 +0000] “GET /geoserver/rest/hello_rest/hello.txt HTTP/1.1” 200 138
0:0:0:0:0:0:0:1 - - [17/Aug/2009:15:01:38 +0000] “GET /geoserver/rest/hello_rest HTTP/1.1” 200 138
Does this mean the module was integreated successfully? I thought the request was supposed to return the test “Hello World”
On Fri, Aug 14, 2009 at 12:00 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
The first is to manually modify the classpath of the web module, and add the hello_rest module. (Right click on module in package explorer, click Properties, go to Java Build Path → Projects)
(Just steps 1 - 3)
Hope that helps.
-Justin
Hi Justin,
geoserver/jetty/.
On Thu, Jun 25, 2009 at 4:25 AM, Justin Deoliveira <jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)> wrote:
Hi Sebastin,
what I found.
date.
documentation here:
    regard to
    similarly for
-Justin
<saby83@anonymised.com.403… mailto:[saby83@anonymised.com](mailto:saby83@anonymised.com)>
attached
it
with this mail.
really
wrong.
<jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)>wrote:
email?
to look
at
-Justin
sabman wrote:
Thanks Justin.
src/main/java and
files,
eclipse
under
the
correctly.)
folder(as
mentioned.).
folder.
following
compilation error:
[INFO]
override
abstract method
incompatible
return type found :
that now
but
its
still the same.
There
are
the log
file.
the wrong
source?
files.
Thanks.
    request,
return formats;
  • implements
module.
and then
lackign that
step.
    file
    I
    see
loadGDAL
no
file where
i
“1.7.3-SNAPSHOT”
hello_rest module
compiled
going to the
URL:
browser.
And
all I
see is this:
  • exception
application
see what
access
those
URL’s?
Bridge
conference!
unconference:
$250.
today!
mailto:[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Justin Deoliveira
conference!
unconference:
$250.
Justin Deoliveira
Justin Deoliveira
Sebastin
Justin Deoliveira
Sebastin
Its confusing and annoying and I don’t really understand whats happening. Like I mentioned earlier that the module installed successfully. I went through the code (instead of just blindly running the commands) to understand whats really happening. So the test checks to see if “Hello World” is returned. It creates the build only if the tests run successful.
I did an mvn install again and it installed successfully. Now this folder was located outside of geoserver/src (I am running geoserver from source code).
So i created a copy of the folder inside of geoserver/src and I also did an mvn eclipse:eclipse so that the module has the rest classpath. I then did a mvn install but it gave a build failure because the tests failed. The surefire test report said it was getting “Geoserver Configuration API” whereas it was expecting “Hello World”.
I went back to the original folder and did a mvn install and it installed succesfully. So I deleted the copy, imported this original folder to eclipse, did the "mvn eclipse:eclipse" and then did the mvn install but the tests failed. :frowning:
I re-build the module from scratch and skipped the mvn eclipse:eclipse part (because I felt it was probably the cause of the error) But all I get now is the test failure. I do not understand how it was installing successfully earlier (I did not look at the surefire report then). It obviously was getting “Hello World” in return…how is it that it was working then and not now.
On Mon, Aug 17, 2009 at 12:44 PM, Sebastin Kolman <saby83@anonymised.com03…> wrote:
(Just steps 1 - 3)
Hope that helps.
-Justin
Hi Justin,
geoserver/jetty/.
Hi Sebastin,
what I found.
date.
documentation here:
    regard to
    similarly for
-Justin
attached
it
with this mail.
really
wrong.
email?
to look
at
-Justin
sabman wrote:
Thanks Justin.
src/main/java and
files,
eclipse
under
the
correctly.)
folder(as
mentioned.).
folder.
following
compilation error:
[INFO]
override
abstract method
incompatible
return type found :
that now
but
its
still the same.
There
are
the log
file.
the wrong
source?
files.
Thanks.
    request,
return formats;
  • implements
module.
and then
lackign that
step.
    file
    I
    see
loadGDAL
no
file where
i
“1.7.3-SNAPSHOT”
hello_rest module
compiled
going to the
URL:
browser.
And
all I
see is this:
  • exception
application
see what
access
those
URL’s?
Bridge
conference!
unconference:
$250.
today!
Justin Deoliveira
conference!
unconference:
$250.
Justin Deoliveira
Justin Deoliveira
Sebastin
Justin Deoliveira
Sebastin
Sebastin
Its confusing and annoying and I don't really understand whats happening.
understand whats really happening. So the test checks to see if "Hello
World" is returned. It creates the build only if the tests run successful.
code).
surefire test report said it was getting "Geoserver Configuration API"
whereas it was expecting "Hello World".
getting "Hello World" in return...how is it that it was working then and not
now.
sabman wrote:
hmm....so here is what happened.
web
*The declared package "org.geoserver.hellorest" does not match the
expected package "src.main.java.org.geoserver.hellorest"
line 1 Java Problem
*The import org.geoserver cannot be resolved HelloResource.java
Problem
*The import org.restlet cannot be resolved HelloResource.java
Problem
to the web module's classpath and restarted the geoserver by running the
http requests,
that
the page returned was "Geoserver Configuration API". I checked the log and
*0:0:0:0:0:0:0:1 - - [17/Aug/2009:14:49:20 +0000] "GET
/geoserver/rest/hello_rest/hello.txt HTTP/1.1" 200 138
0:0:0:0:0:0:0:1 - - [17/Aug/2009:15:01:38 +0000] "GET
/geoserver/rest/hello_rest HTTP/1.1" 200 138*
request was supposed to return the test "Hello World"
geoserver.
(Just steps 1 - 3)
WEB-INF/lib
Hope that helps.
-Justin
Hi Justin,
geoserver/jetty/.
project
again ?
<jdeolive@anonymised.com<mailto:
   Hi Sebastin,
is
   what I found.
   date.
   documentation here:
   regard to
   similarly for
   -Justin
   attached
   it
    > with this mail.
thing
   really
    > wrong.
private
   email?
   to look
    >> at
    >> -Justin
    >> sabman wrote:
    >>> Thanks Justin.
   src/main/java and
   files,
    >>> eclipse
   under
   the
the
   correctly.)
    >>> folder(as
    >>> mentioned.).
correct
    >>> folder.
   following
    >>> [INFO]
not
    >>> override
    >>> abstract method
   incompatible
   that now
    >>>>> but
    >>>>> its
file.
    >>>>> There
    >>>>> are
   the log
    >>>> file.
   the wrong
   source?
the
    >>>> files.
    >>>> Thanks.
    >>>>> request,
Response)
    >>>>> - implements
your
    >>>> module.
   and then
   lackign that
    >>>> step.
Start.java
   file
    >>>>> I
    >>>>> see
    >>>>> loadGDAL
   no
[geoserverlogfile].
ConsoleAppender?
available
   file where
    >>>>>>> i
   hello_rest module
    >>>>>>> compiled
   going to the
    >>>>>>> URL:
   browser.
    >>>>>>> And
    >>>>>>> all I
    >>>>>>> * exception
    >>>>>> application
   see what
   access
    >>>>>> those
    >>>>>> URL's?
    >>>>>> Cheers
    >>>>>> Andrea
   Bridge
    >>>>>> conference!
    >>>>>> $250.
   today!
Bridge
    >>>> conference!
    >>>> unconference:
    >>>> $250.
today!
   Justin Deoliveira
Sebastin
Justin Deoliveira
Sebastin
Let Crystal Reports handle the reporting - Free Crystal Reports 2008
30-Day
trial. Simplify your report design, integration and deployment - and focus
on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
View this message in context: http://www.nabble.com/Problems-with-implementing-REST-service-tp24138984p25051711.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Hi Sebastin,
Not exactly sure what the problem is. If you want to send me over the module you did, i can take a look at it, and send you back a patch of any changes needed to get it to run.
-Justin
Its confusing and annoying and I don't really understand whats happening. Like I mentioned earlier that the module installed successfully. I went through the code (instead of just blindly running the commands) to understand whats really happening. So the test checks to see if "Hello World" is returned. It creates the build only if the tests run successful.
I did an /mvn install/ again and it installed successfully. Now this folder was located outside of geoserver/src (I am running geoserver from source code).
So i created a copy of the folder inside of geoserver/src and I also did an mvn eclipse:eclipse so that the module has the rest classpath. I then did a /mvn install/ but it gave a build failure because the tests failed. The surefire test report said it was getting "Geoserver Configuration API" whereas it was expecting "Hello World".
I went back to the original folder and did a mvn install and it installed succesfully. So I deleted the copy, imported this original folder to eclipse, did the /"mvn eclipse:eclipse/" and then did the mvn install but the tests failed. :frowning:
I re-build the module from scratch and skipped the /mvn eclipse:eclipse/ part (because I felt it was probably the cause of the error) But all I get now is the test failure. I do not understand how it was installing successfully earlier (I did not look at the surefire report then). It obviously was getting "Hello World" in return...how is it that it was working then and not now.
On Mon, Aug 17, 2009 at 12:44 PM, Sebastin Kolman <saby83@anonymised.com <mailto:saby83@anonymised.com>> wrote:
    provided at
        /The declared package "org.geoserver.hellorest" does not match
        the expected package "src.main.java.org.geoserver.hellorest" HelloResource.java hello_rest/src/main/java/org/geoserver/hellorest line 1 Java Problem
        /The import org.geoserver cannot be resolved HelloResource.java hello_rest/src/main/java/org/geoserver/hellorest line 4 Java Problem/
        /The import org.restlet cannot be resolved HelloResource.java hello_rest/src/main/java/org/geoserver/hellorest line 6 Java Problem/
    module to the web module's classpath and restarted the geoserver by
    returned no exceptions. All that the page returned was "Geoserver
    Configuration API". I checked the log and it seems that the request
    was successful:
        /0:0:0:0:0:0:0:1 - - [17/Aug/2009:14:49:20 +0000] "GET
        /geoserver/rest/hello_rest HTTP/1.1" 200 138/
    the request was supposed to return the test "Hello World"
        of geoserver.
        (Just steps 1 - 3)
        and restart it.
        Hope that helps.
        -Justin
            Hi Justin,
            geoserver/jetty/.
            wrote:
               Hi Sebastin,
            it and here is
               what I found.
            was out of
               date.
            updated the
               documentation here:
            location with
               regard to
               similarly for
            was able to
               -Justin
            module? I have
               attached
               it
                > with this mail.
            a simple thing
               really
                > wrong.
            in a private
               email?
            would be nice
               to look
                >> at
                >> -Justin
                >> sabman wrote:
                >>> Thanks Justin.
               src/main/java and
            the class
               files,
                >>> eclipse
            folder instead of
            is located
               under
               the
            could see that the
            recognized
               correctly.)
            the resources
                >>> folder(as
            folder (as you
                >>> mentioned.).
            under the correct
                >>> folder.
            get the
               following
                >>> [INFO]
                >>> override
                >>> abstract method
            to use
               incompatible
                >>> required:
            class
            class
            a supertype
            folder. I did
               that now
                >>>>> but
                >>>>> its
            in the log file.
                >>>>> There
                >>>>> are
            below:
            nothing in
               the log
                >>>> file.
            file is in
               the wrong
            your plugin
               source?
            listing of the
                >>>> files.
                >>>> Thanks.
            of code:
                >>>>> request,
            line
                >>>>> - implements
            this line
            classpath of your
                >>>> module.
            your module
               and then
               lackign that
                >>>> step.
            the Start.java
               file
                >>>>> I
                >>>>> see
                >>>>> loadGDAL
               no
            [geoserverlogfile].
            ConsoleAppender?
            services available
            pom.xml
               file where
                >>>>>>> i
               hello_rest module
                >>>>>>> compiled
            service by
               going to the
                >>>>>>> URL:
            all in the
               browser.
                >>>>>>> And
                >>>>>>> all I
                >>>>>>> * exception
                >>>>>> application
            it into
               see what
            you try to
               access
                >>>>>> those
                >>>>>> URL's?
                >>>>>> Cheers
                >>>>>> Andrea
            Open Source
               Bridge
                >>>>>> conference!
            one day of
                >>>>>> $250.
            Register
               today!
            <mailto:Geoserver-devel@lists.sourceforge.net>>
            Open Source Bridge
                >>>> conference!
            day of
                >>>> unconference:
                >>>> $250.
            Register today!
               Justin Deoliveira
            -- Regards,
            Sebastin
        -- Justin Deoliveira
    -- Regards,
    Sebastin
Sebastin
Justin Deoliveira
