hello!
i just installed geoserver 0.98 as a webapplication in tomcat 4.1.24 (jsdk 1.4.2) on win xp. the example in the "topp--road"-directory with the shapefile works perfectly. to get some experience i tried to modify the example so that it works with postgis. i applied shp2sql to road.shp and loaded the data in a table called 'road''. i didn't change the schema.xml but modified the info.xml:
<featureType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Name>road</Name>
<Title>Random Road Centerlines</Title>
<Abstract>This is some random road features</Abstract>
<Keywords>road, New York City, TOPP</Keywords>
<SRS>-1</SRS>
<LatLonBoundingBox minx="-74.27000" miny="40.50000" maxx="-73.80000" maxy="40.94000"/>
<Host>localhost</Host>
<Port>5432</Port>
<DatabaseName>test</DatabaseName>
<User>Jean-Pierre</User>
<Password/>
<Dbtype>postgis</Dbtype>
<Table>road</Table>
</featureType>
now i receive the following exception when i execute a request ( http://127.0.0.1:8081/geoserver/Dispatcher?request=GetFeature&typename=road ):
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Searching system properties
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Key 'org.geotools.feature.AttributeTypeFactory' not found
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Searching for service: META-INF/services/org.geotools.feature.AttributeTypeFactory
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Reading Factory , has stream : false
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Service 'META-INF/services/org.geotools.feature.AttributeTypeFactory' not found
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Resorting to default
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Creating instance from 'org.geotools.feature.DefaultAttributeTypeFactory'
46016 [FEIN] org.geotools.data.jdbc.ConnectionPool$ConnectionListManager - Connection closed - adding to available connections.
46026 [FEIN] org.vfny.geoserver.responses.WfsException - > [null]:
UNCAUGHT EXCEPTION: java.lang.NullPointerException
46026 [FEIN] org.vfny.geoserver.responses.WfsException - return wfs exception is <?xml version="1.0" ?>
<ServiceExceptionReport
version="1.2.0"
xmlns="http://www.opengis.net/ogc"
xsi:schemaLocation="http://www.opengis.net/ogc ../wfs/1.0.0/OGC-exception.xsd">
<ServiceException>
at java.lang.Class.isAssignableFrom(Native Method)
at org.geotools.feature.DefaultAttributeTypeFactory.createAttributeType(DefaultAttributeTypeFactory.java:37)
at org.geotools.feature.AttributeTypeFactory.newAttributeType(AttributeTypeFactory.java:73)
at org.geotools.feature.AttributeTypeFactory.newAttributeType(AttributeTypeFactory.java:86)
at org.geotools.data.postgis.PostgisDataSource.makeSchema(PostgisDataSource.java:274)
with LoggingLevel on FINEST i can see, that all connection-parameters from info.xml a read correctly.
do you have an idea what i could do to avoid this exception?
thanks
jpp
We just figured out this issue off of the list. In case anyone is
wondering, the problem was that shp2pgsql was making the gid column an
int8, which was causing problems with PostgisDataSource, as it doesn't
know how to handle int8's. So if you run into this problem, the temporary
solution is to change your table creation to use int4 instead of int8, and
we will work with the geotools team to fix the issue for the long term.
thanks,
Chris
hello!
<Name>road</Name>
<SRS>-1</SRS>
<Port>5432</Port>
<Password/>
<Table>road</Table>
</featureType>
properties
version="1.2.0"
<ServiceException>
at
at
at
at
thanks
jpp
This sf.net email is sponsored by:ThinkGeek
Welcome to geek heaven.
http://thinkgeek.com/sf
Geoserver-devel mailing list
