hello!
i just installed geoserver 0.98 as a webapplication in tomcat 4.1.24 (jsdk 1.4.2) on win xp. the example in the "topp--road"-directory with the shapefile works perfectly. to get some experience i tried to modify the example so that it works with postgis 0.7.5. i applied shp2sql to road.shp and loaded the data in a table called 'road''. i didn't change the schema.xml but modified the info.xml:
<featureType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Name>road</Name>
<Title>Random Road Centerlines</Title>
<Abstract>This is some random road features</Abstract>
<Keywords>road, New York City, TOPP</Keywords>
<SRS>-1</SRS>
<LatLonBoundingBox minx="-74.27000" miny="40.50000" maxx="-73.80000" maxy="40.94000"/>
<Host>localhost</Host>
<Port>5432</Port>
<DatabaseName>test</DatabaseName>
<User>Jean-Pierre</User>
<Password/>
<Dbtype>postgis</Dbtype>
<Table>road</Table>
</featureType>
now i receive the following exception when i execute a request ( http://127.0.0.1:8081/geoserver/Dispatcher?request=GetFeature&typename=road ):
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Searching system properties
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Key 'org.geotools.feature.AttributeTypeFactory' not found
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Searching for service: META-INF/services/org.geotools.feature.AttributeTypeFactory
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Reading Factory , has stream : false
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Service 'META-INF/services/org.geotools.feature.AttributeTypeFactory' not found
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Resorting to default
46016 [AM FEINSTEN] org.geotools.factory.FactoryFinder - Creating instance from 'org.geotools.feature.DefaultAttributeTypeFactory'
46016 [FEIN] org.geotools.data.jdbc.ConnectionPool$ConnectionListManager - Connection closed - adding to available connections.
46026 [FEIN] org.vfny.geoserver.responses.WfsException - > [null]:
UNCAUGHT EXCEPTION: java.lang.NullPointerException
46026 [FEIN] org.vfny.geoserver.responses.WfsException - return wfs exception is <?xml version="1.0" ?>
<ServiceExceptionReport
version="1.2.0"
xmlns="http://www.opengis.net/ogc"
xsi:schemaLocation="http://www.opengis.net/ogc ../wfs/1.0.0/OGC-exception.xsd">
<ServiceException>
at java.lang.Class.isAssignableFrom(Native Method)
at org.geotools.feature.DefaultAttributeTypeFactory.createAttributeType(DefaultAttributeTypeFactory.java:37)
at org.geotools.feature.AttributeTypeFactory.newAttributeType(AttributeTypeFactory.java:73)
at org.geotools.feature.AttributeTypeFactory.newAttributeType(AttributeTypeFactory.java:86)
at org.geotools.data.postgis.PostgisDataSource.makeSchema(PostgisDataSource.java:274)
with LoggingLevel on FINEST i can see, that all connection-parameters from info.xml are read correctly.
do you have an idea what i could do to avoid this exception?
thanks
jpp
