I am connecting geoserver 1.5.0 with PostGis 1.2.0. I create the store of data, but when I want to create a new dataset from my PostGis store (created OK), I don’t get it in the menu, and in the log appears
614669 [GRAVE] org.geotools.data.postgis.PostgisDBInfo - ERROR: function postgis_version() does not exist
I am connecting geoserver 1.5.0 with PostGis 1.2.0. I create the store of data, but when I want to create a new dataset from my PostGis store (created OK), I don't get it in the menu, and in the log appears
Could you help me?? Thanks
Did you enable postgis extensions in your database?
It's not sufficient to install postgis and then create a new db, you
also have to run the contents of a few files full of sql statements
to enabled it in the db.
You can find some instructions here: http://postgis.refractions.net/docs/ch02.html#templatepostgis
(if you don't have the template, just run steps 5,6,7 of the
instructions above it).
That usually means that your postgis database is not a postgis database, when you create your database in postgres make sure you create a spatial database using the postgis template
----- Original Message ----- From: "Andrea Aime" <aaime@anonymised.com>
To: "Jose Luis Garcia" <jlmonzon@anonymised.com>
Cc: <geoserver-devel@lists.sourceforge.net>
Sent: Thursday, May 24, 2007 12:19 PM
Subject: Re: [Geoserver-devel] PROBLEMS WITH POSTGIS
Jose Luis Garcia ha scritto:
Hope this helps
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now. http://sourceforge.net/powerbar/db2/
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
