[Geoserver-devel] Profiling Community Schema code in goeserver
Luca Morandini wrote:
Thanks for clarifying the issue :slight_smile:
Since we are at that: where's the source code of said WPS module?
Right now it is in the geotools code base (we are working on the parser / encoder ....). But yeah you are correct the team should of committed something into the community module by now; they have something returning a GetCapabilities document at the moment.
I was feeling like connecting it to GRASS via the JGRASS console engine... well at least trying it.
That would be cool; you can do that by implementing the "ProcessFactory" and "Process" interface we have defined over in geotools gt-process.jar - then when WPS is up and running your work can be published.
Jody
