Hello, I wrote about GML and labels previously . Is there anyway through which I can control the placement of labels. Which algorithm is being used to place labels now? I want to write a plugin in Geoserver for optimum labeling. Could somebody please help me.
Thanks in advance.
Hello, I wrote about GML and labels previously <http://www.nabble.com/Re%3A-Labeling-in-Geoserver-td22829430.html>\. Is there anyway through which I can control the placement of labels. Which algorithm is being used to place labels now? I want to write a plugin in Geoserver for optimum labeling. Could somebody please help me.
The code for labelling in not in GeoServer, it's in GeoTools, in the
renderer module. Luckly labelling has an extension point, if you
don't like the default placement you can write your own.
Look for the org.geotools.renderer.lite.LabelCache interface and
the org.geotools.renderer.lite.LabelCacheDefault implementation
Out of curiousity, what kind of label placement algorithms are
you planning to implement?
Andrea Aime
OpenGeo - http://opengeo.org
Thanks. I read the java doc of LabelCache. I glanced at the code too. The
labeling that I want to do is for an university project based on an
algorithm by Zhang and Harrie(2004). Could you please elaborate on the
extension point.
Robin
Andrea Aime
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
extension point.
Nope. Let's play it the other way. You read the docs and the code
and if you have questions I'll be glad to answer them.
Andrea Aime
