[Geoserver-devel] Progress on spring upgrade
Hey folks, thought I would send a quick update on progress. To recap the branch currently being worked on is here:
https://github.com/geoserver/geoserver/tree/spring4-upgrade
The branch currently contains:
  • Core upgrades to spring 4.2.5 and spring security 4.0.4
  • Upgrade to servlet api 3.0.1
  • Andreas work to migrate from mockrunner to spring-test
I also pushed a branch for geowebcache:
https://github.com/GeoWebCache/geowebcache/tree/spring-servlet-upgrade
Although it looks like Kevin already did the work here?:
https://github.com/GeoWebCache/geowebcache/tree/spring4-upgrade
At any rate, one of those branches will be required to build the geoserver branch.
At the moment all the core modules compile and pass tests. With the exception of one wms test that from what I can tell was some wierd osx failure. It would be nice if someone else could verify that though.
I’ve also run the server and everythign starts up ok, but I haven’t poked it much harder than a quick smoke test.
There is one interesting thing that I found with spring security. The login and logout endpoints have changed. So “/j_spring_security_check" is now “/login” and “/j_spring_security_logout” is now “/logout”. I’m still unsure what the backwards compatability repercussions will be with this. It looks like those paths are configurable in some places (like if using annotation based config) but the way we are using some of the filters it didn’t look like they were. I was going to circle back to this.
So… next steps is to start updating extensions and community modules. The big one being cas. @Christian: I think you have all you need on that branch to start looking at the CAS migration. Let me know if you have any questions.
That’s about it for now.
-Justin
Hi Justin,
had a very quick look, GeoServer wise the only thing I noticed was the lack of header upgrades (which
can be done later), all the other changes look reasonable (but mind, I haven’t used Spring 4 anywhere else).
On Sat, Mar 5, 2016 at 6:23 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Tried to build this one, I get a failure in gwc-wmts:
Tests run: 6, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 11.632 sec <<< FAILURE!
testGetTileWithStyle(org.geowebcache.service.wmts.WMTSServiceTest) Time elapsed: 0.416 sec <<< FAILURE!
java.lang.AssertionError:
Expected: map containing [“STYLES”->“Bar”]
but: map was
at org.hamcrest.MatcherAssert.assertThat(MatcherAssert.java:20)
at org.hamcrest.MatcherAssert.assertThat(MatcherAssert.java:8)
at org.geowebcache.service.wmts.WMTSServiceTest.testGetTileWithStyle(WMTSServiceTest.java:524)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at junit.framework.TestCase.runTest(TestCase.java:176)
at junit.framework.TestCase.runBare(TestCase.java:141)
at junit.framework.TestResult$1.protect(TestResult.java:122)
at junit.framework.TestResult.runProtected(TestResult.java:142)
at junit.framework.TestResult.run(TestResult.java:125)
at junit.framework.TestCase.run(TestCase.java:129)
at junit.framework.TestSuite.runTest(TestSuite.java:255)
at junit.framework.TestSuite.run(TestSuite.java:250)
at org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38ClassRunner.java:84)
It was a simple fix for a mock expectation, so I’ve fixed it. One liner change pushed to the branch.
Looks like this one misses the servlet api upgrade though.
No failures in wms here (also made a fresh build of geotools to be on the safe side), do you have details?
I’ve made a full build and I have failures in the following extensions: CAS (expected), WPS, XSLT, monitoring hibernate… not all
that many in the end.
Assuming you’re not working on it right now, I’m going to have a quick look.
Hum… thinking, don’t we have some javascript apps around using these endpoints to test authentication
when using a custom login form?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On Sun, Mar 6, 2016 at 11:00 AM, Andrea Aime <andrea.aime@anonymised.com>
I've made a full build and I have failures in the following extensions:
CAS (expected), WPS, XSLT, monitoring hibernate... not all
Assuming you're not working on it right now, I'm going to have a quick
look.
Made WPS, XSLT and monitor hibernate build, the first two needed the same
timer changes as wcs, the latter had
issues with deprecated API and generics, hopefully fixed too (well, the
test pass, don't know if it actually works at runtime).
Of course I'll leave the CAS upgrade fun to Christian.
Had a cursory look though community modules in the community-release
profile too:
* JDBCConfig fails to compile, as well as gs-jms-geoserver
* gs-rest-ext, js-rest-upload, gs-wms-eo, gs-dds, gs-web-solr,
gs-geofence-server, gs-geopgk, gs-script-js, gs-script-groovy all
   have test failures
Three of them were already known from the mockrunner removal (if memory
serves me right).
Haven't investigated them.
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Andrea. Comments inline.
Hi Justin,
Nice, thanks!
I’ve attached the failure trace I get from testCoverageViewMap(org.geoserver.wms.wms_1_1_1.GetMapIntegrationTest). I am pretty sure I have seen this failure before in my environment.
Yeah, I know of one app (geoexplorer) that uses one of the endpoints to create a session. One thought I had (if we can’t configure the endpoint paths) was to create a redirect from old to the new.
(attachments)
failure.txt (9.02 KB)
but: map was
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks to both of you for the hard work, Kevin if you are working on that branch please remember to coordinate with the email list.
I will catch up mid week.
but: map was
Ing. Andrea Aime
@geowolf
Technical Lead
On Sun, Mar 6, 2016 at 6:34 PM, Justin Deoliveira <jdeolive@anonymised.com>
look.
Aah... yeah, I know that beast. One quick solution is to remove the native
JAI for OSX, it's the only one using that
operation that is not implemented in JAITools ROIGeometry, and not used by
the native jai for windows and linux (or the pure java jai).
The other option would be to put some more effort behind this pull request,
in which I did implement the said method (although,
not sure if correctly or fast enough, I don't have a good way to test
it...):
https://github.com/mbedward/jaitools/pull/233
The main thing keeping that pull request at bay is that I've implemented it
fully in my spare time, and it would require
manual testing... I was thinking to merge it right away after the new
stable gets cut, which was supposed to be
soon enough, in order to gather feedback in the next dev cycle without
causing troubles to this release.
Now, with this delay it would be tempting to merge it and release another
version of jaitools,
but of course it also has the risk of adding more "late" changes, and thus
potentially more instability.
Hum... thinking, don't we have some javascript apps around using these
Ah, yep... not everything handles redirects seamlessly (maven anyone? :wink:
), but browsers should.
Ing. Andrea Aime
@geowolf
Technical Lead
Can we do some OS specific priority thing to avoid use of the native operations on OSX? They really are not around much anymore; very hard to find on the apple website etc…
We could document the result and add it to GeoTools init()
On 6 March 2016 at 12:10, Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-devel mailing list
Jody Garnett
On Sun, Mar 6, 2016 at 6:34 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Aah… yeah, I know that beast. One quick solution is to remove the native JAI for OSX, it’s the only one using that
operation that is not implemented in JAITools ROIGeometry, and not used by the native jai for windows and linux (or the pure java jai).
The other option would be to put some more effort behind this pull request, in which I did implement the said method (although,
not sure if correctly or fast enough, I don’t have a good way to test it…):
The main thing keeping that pull request at bay is that I’ve implemented it fully in my spare time, and it would require
manual testing… I was thinking to merge it right away after the new stable gets cut, which was supposed to be
soon enough, in order to gather feedback in the next dev cycle without causing troubles to this release.
Now, with this delay it would be tempting to merge it and release another version of jaitools,
but of course it also has the risk of adding more “late” changes, and thus potentially more instability.
Ah, yep… not everything handles redirects seamlessly (maven anyone? :wink: ), but browsers should.
Ing. Andrea Aime
@geowolf
Technical Lead
I had done the Servlet 3.0.1 update on Friday, but hadn’t committed it yet. I’ve merged spring-servlet-upgrade into spring4-upgrade to make sure we don’t loose anything. The conflicts were fairly simple to resolve and all unit tests are passing.
I’ll do some stand alone GWC testing to check if anything non-obvious has broken.
Kevin Michael Smith
smithkm@anonymised.com
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
I’ll also be on the GeoServer and GeoWebCache gitter channels while working on this in case we need realtime coordination.
Kevin Michael Smith
Kevin Michael Smith
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://makebettercode.com/inteldaal-eval
I compared a diff of the changes made to GWC to the unit test coverage and found two changes that hadn’t been covered. I’m rather pleasantly surprised given how spotty test coverage in GWC can be. One change was in the Metastore Remover which is used in upgrades from 1.3.x or earlier and the other was in the getModifiableParameters method of the TileLayer class.
I did an ad hoc test of upgrading from 1.3 to 1.9 and it worked fine, and I added a unit test to cover getModifiableParameters which is passing.
On the GWC front, that still leaves upgrading Acegi Security 1.0.7 to Spring Security 4.0.4. They do use different namespaces so I suppose we don’t need to keep in sync with GeoServer here and Acegi seems to be working with Spring 4.2.5, but if there’s one thing we really shouldn’t be using such an ancient library for, it’s security.
Kevin Michael Smith
Kevin Michael Smith
Kevin Michael Smith
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
