+1
-Jukka Rahkonen-
Mauro Bartolomeoli wrote:
any more votes on this? If not I'm going to proceed with the current +3.
Also: any blockers to promote to extension also on the 2.4.x branch?
Mauro Bartolomeoli
2013/12/18 Alessio Fabiani <alessio.fabiani@anonymised.com<mailto:alessio.fabiani@anonymised.com>>
Hi guys,
sorry for the delay. Just read the proposal.
I would say +1 ... I know that module code, did some work on integration of it in the past with the Download Process and it works quite well.
-A.
== GeoSolutions will be closed for seasonal holidays from 23/12/2013 to 06/01/2014 ==
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
phone: +39 0584 962313<tel:%2B39%200584%20962313>
fax: +39 0584 1660272<tel:%2B39%200584%201660272>
mob: +39 331 6233686<tel:%2B39%20%C2%A0331%206233686>
On Mon, Dec 16, 2013 at 10:07 AM, Jody Garnett <jody.garnett@anonymised.com<mailto:jody.garnett@anonymised.com>> wrote:
+1 from me.
Does the wps format need to be mentioned in docs? Or can people just figure it out.
Jody Garnett
On Wed, Dec 11, 2013 at 7:56 PM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com1268...<mailto:mauro.bartolomeoli@anonymised.com>> wrote:
I would like to ask for promotion of the dxf community module to extension.
About the promotion requirements:
1) the module is currently in use by some of our customers and recently some people showed interest to use the module in the users mailing list
2) the module has a mantainer (here I am)
3) recently I made some work to add it to the nightly builds and split it in two submodules for core (wfs output format) and wps functionality, and it seems to build and work correctly
4) test coverage is over 90%
5) no IP violations that I am aware of
6) there is already a doc page: http://docs.geoserver.org/stable/en/user/community/dxf/index.html
7) I sent a contributor agreement
Do I need to create a GSIP for this?
Thanks
Mauro
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don't have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349831&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net<mailto:Geoserver-devel@anonymised.comrge.net>
@mauro_bart
