Hi, I would like to ask for promotion of the authkey module to extension status.
Some of the requirements for promotion:
The module have at least a “handful” of users: since we added the ability to use an external validation service, the module has been used to integrate security between geoserver and external application in a lot of cases.
The module have a designated and active maintainer: I contributed several improvements in the last years, and would like to become the mantainer of the module.
The module is considered “stable” by the majority of the PSC.
The module maintain 40% test coverage: (about 55% with Jacoco)
The modules have no IP violations.
The module has a page in the user manual: https://docs.geoserver.org/stable/en/user/community/authkey/index.html
The maintainer (Mauro Bartolomeoli) has signed the GeoServer Contributor Agreement, also as a maintaner of other GeoServer features (WMTS cascading).
If no objection arise, I would proceed creating a GSIP for this.
Mauro Bartolomeoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Technical Lead
Via di Montramito 3/A
mobile: +39 393 904 1756
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
