Yep, it's a GSIP vote
Ah, +1 here too
On Thu, Aug 2, 2018 at 6:16 AM <bradh@anonymised.com
<mailto:bradh@anonymised.com>> wrote:
I’m +0 on this. Are you actually looking for votes on the GSIP at
this time?
Brad
*From:*Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com
<mailto:mauro.bartolomeoli@anonymised.com>>
*Sent:* Wednesday, 1 August 2018 1:12 AM
*To:* Geoserver-devel <Geoserver-devel@lists.sourceforge.net
<mailto:Geoserver-devel@lists.sourceforge.net>>
*Subject:* Re: [Geoserver-devel] Promoting SLDservice community
module to extension
GSIP is here: https://github.com/geoserver/geoserver/wiki/GSIP-170
Mauro
Il giorno dom 29 lug 2018 alle ore 22:05 Andrea Aime
<andrea.aime@anonymised.com
<mailto:andrea.aime@anonymised.com>> ha scritto:
Gsssipit!
Il Ven 27 Lug 2018, 19:21 Mauro Bartolomeoli
<mailto:mauro.bartolomeoli@anonymised.com>> ha scritto:
Hi, I would like to propose SLDservice promotion to extension.
Some of the requirements for promotion:
- The modules have at least a "handful" of users:
recent interest in improvements to the module show that
some people are using it.
- The modules have a designated and active maintainer:
I contributed several improvements recently, and would
like to become the mantainer of the module.
- The modules are considered "stable" by the majority
of the PSC.
- The modules maintain 40% test coverage: (about 41%
with Jacoco)
- The modules have no IP violations.
- The module has a page in the user manual:
- The maintainer (Mauro Bartolomeoli) has signed the
GeoServer Contributor Agreement, also as a maintaner of
other GeoServer features (WMTS cascading).
If no objection arise, I would proceed creating a GSIP for
this.
Mauro Bartolomeoli
Dott. Mauro Bartolomeoli
@mauro_bart
Technical Lead
Via di Montramito 3/A
mobile: +39 393 904 1756
/Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui
conoscenza è riservata al/i solo/i destinatario/i indicati
dallo scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that is
privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or use
of this e-mail or the information herein by anyone other
than the intended recipient is prohibited. If you have
received this email by mistake, please notify us
immediately by telephone or e-mail./
Check out the vibrant tech community on one of the world's
most
engaging tech sites, Slashdot.org!
http://sdm.link/slashdot_______________________________________________
Geoserver-devel mailing list
Mauro Bartolomeoli
@mauro_bart
Technical Lead
/Con riferimento alla normativa sul trattamento dei dati personali
(Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
“GDPR”), si precisa che ogni circostanza inerente alla presente
email (il suo contenuto, gli eventuali allegati, etc.) è un dato
la cui conoscenza è riservata al/i solo/i destinatario/i indicati
tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei
This email is intended only for the person or entity to which it
is addressed and may contain information that is privileged,
confidential or otherwise protected from disclosure. We remind
that - as provided by European Regulation 2016/679 “GDPR” -
copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited.
If you have received this email by mistake, please notify us
Check out the vibrant tech community on one of the world's most
Regards, Andrea Aime == GeoServer Professional Services from the
experts! Visit http://goo.gl/it488V for more information. == Ing.
Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di
Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39
0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it
------------------------------------------------------- /Con
riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene
notizia. This email is intended only for the person or entity to which
it is addressed and may contain information that is privileged,
confidential or otherwise protected from disclosure. We remind that -
as provided by European Regulation 2016/679 “GDPR” - copying,
dissemination or use of this e-mail or the information herein by
anyone other than the intended recipient is prohibited. If you have
received this email by mistake, please notify us immediately by
