[Geoserver-devel] Promoting SLDservice community module to extension
If you need more votes,
+1
-Jukka Rahkonen-
Lähettäjä: Mauro Bartolomeoli [mailto:mauro.bartolomeoli@…1268…]
Lähetetty: 23. elokuuta 2018 12:03
Vastaanottaja: Mauro Bartolomeoli <mauro.bartolomeoli@…1268…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] Promoting SLDservice community module to extension
If there are no objections, I would merge it, I think we have enough votes to go.
Mauro
Il giorno mar 21 ago 2018 alle ore 10:53 Mauro Bartolomeoli <mauro.bartolomeoli@…1268…> ha scritto:
the PR for this one is ready: https://github.com/geoserver/geoserver/pull/3062
Il giorno mar 7 ago 2018 alle ore 18:43 Kevin Smith <smithkm@…3859…> ha scritto:
+1
On 2018-08-01 10:13 PM, Andrea Aime wrote:
Yep, it’s a GSIP vote :slight_smile:
Ah, +1 here too
On Thu, Aug 2, 2018 at 6:16 AM <bradh@…4091…> wrote:
I’m +0 on this. Are you actually looking for votes on the GSIP at this time?
Brad
From: Mauro Bartolomeoli <mauro.bartolomeoli@…1268…>
Sent: Wednesday, 1 August 2018 1:12 AM
To: Geoserver-devel <Geoserver-devel@lists.sourceforge.net>
Subject: Re: [Geoserver-devel] Promoting SLDservice community module to extension
GSIP is here: https://github.com/geoserver/geoserver/wiki/GSIP-170
Mauro
Il giorno dom 29 lug 2018 alle ore 22:05 Andrea Aime <andrea.aime@…1268…> ha scritto:
Gsssipit!
Il Ven 27 Lug 2018, 19:21 Mauro Bartolomeoli <mauro.bartolomeoli@…1268…> ha scritto:
Hi, I would like to propose SLDservice promotion to extension.
Some of the requirements for promotion:
  • The modules have at least a “handful” of users: recent interest in improvements to the module show that some people are using it.
  • The modules have a designated and active maintainer: I contributed several improvements recently, and would like to become the mantainer of the module.
  • The modules are considered “stable” by the majority of the PSC.
  • The modules maintain 40% test coverage: (about 41% with Jacoco)
  • The modules have no IP violations.
  • The module has a page in the user manual:
  • The maintainer (Mauro Bartolomeoli) has signed the GeoServer Contributor Agreement, also as a maintaner of other GeoServer features (WMTS cascading).
If no objection arise, I would proceed creating a GSIP for this.
Mauro Bartolomeoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Technical Lead
Via di Montramito 3/A
mobile: +39 393 904 1756
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
engaging tech sites, Slashdot.org! http://sdm.link/slashdot_______________________________________________
Geoserver-devel mailing list
Mauro Bartolomeoli
@mauro_bart
Technical Lead
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Kevin Michael Smith
[<smithkm@...3859...>](mailto:smithkm@...3859...)
Mauro Bartolomeoli
@mauro_bart
Technical Lead
Mauro Bartolomeoli
@mauro_bart
Technical Lead
