I assigned the Jira to Mike Pumphrey for review, but feedback from anyone will be enough for me to either fix it or resolve it. http://jira.codehaus.org/browse/GEOS-3385
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
Kind regards,
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now! http://p.sf.net/sfu/devconference
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
using "|" to delimit the first line does not work. It may have worked when originally implemented, but the Properties data store now uses SimpleFeatureType createType(String, String, String) to convert the "schema" line into a SimpleTeatureType; this implementation only supports comma-separated entries.
Thanks for looking over the docs. I will resolve the Jira issue.
Kind regards,
Ben.
On 09/10/09 11:09, Jody Garnett wrote:
Looks good - viewing your example I am tempted to make the initial
header separated by "|" for consistency with the data rows.
Jody
On Fri, Oct 9, 2009 at 12:58 PM, Ben Caradoc-Davies
Kind regards,
Ben Caradoc-Davies<Ben.Caradoc-Davies@anonymised.com>
