[Geoserver-devel] Properties of the output of a rendering transform cannot be used in Filters
I am having an issue with applying the PointStacker example SLD (http://dev.horizon.opengeo.org/opengeo-docs/cartography/rt/pointstacker.html) to one of my datasources.
I have built geoserver using the oracle,oracleDriver,wps,kml and feature-aggregate profiles. It also did not work w/o feature-aggregate. Geotools was built using –Dall. I have also had this issue on the 2.2.2 stable distribution.
My datasource (INCIDENTGEOM) is an Oracle spatial database table ( Oracle Database 10g Release 10.2.0.4.0), and I am using the master cut of Geoserver and master cut of Geotools (10-SNAPSHOT). If I click on KML (plain), in the LayerPreview screen, I get the following output on console :
08 Mar 12:09:58 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/it.geosolutions/wms]
08 Mar 12:09:58 DEBUG [ows.OWSHandlerMapping] - Mapping [/it.geosolutions/wms] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
08 Mar 12:09:58 INFO [geoserver.wms] -
Request: getServiceInfo
08 Mar 12:09:58 DEBUG [geoserver.ows] - Getting layers and styles from LAYERS and STYLES
08 Mar 12:09:58 DEBUG [geoserver.ows] - establishing stacked style for it.geosolutions:INCIDENTGEOM
08 Mar 12:09:58 DEBUG [geoserver.wms] - setting up map
Request: getMap
Time =
Format = application/vnd.google-earth.kml+xml
Filter = null
Buffer = 0
Width = 24750329
Filters = null
Height = 330
Palette = null
Tiled = false
SRS = EPSG:4326
FeatureVersion = null
Styles = [StyleImpl[ name=stacked]]
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
MaxFeatures = null
Bbox = ReferencedEnvelope[54.9999 : 70.0001, 69.9999 : 70.0001]
RemoteOwsType = null
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
Crs = GEOGCS[“WGS 84”,
DATUM[“World Geodetic System 1984”,
SPHEROID[“WGS 84”, 6378137.0, 298.257223563, AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Geodetic longitude”, EAST],
AXIS[“Geodetic latitude”, NORTH],
AUTHORITY[“EPSG”,“4326”]]
BgColor = java.awt.Color[r=255,g=255,b=255]
Transparent = false
SldBody = null
ValidateSchema = false
Sld = null
SldVersion = null
TilesOrigin = null
Exceptions = SE_XML
Version = 1.1.0
Request = GetMap
RawKvp = {BBOX=54.9999,69.9999,70.0001,70.0001, VERSION=1.1.0, FORMAT=application/vnd.google-earth.kml+xml, SERVICE=WMS, HEIGHT=330, REQUEST=GetMap, LAYERS=it.geosolutions:INCIDENTGEOM, STYLES=, WIDTH=24750329, SRS=EPSG:4326}
Get = true
BaseUrl = http://localhost:9097/geoserver/
RequestCharset = UTF-8
08 Mar 12:09:58 DEBUG [geoserver.kml] - scale denominator = 240.95128850859533
08 Mar 12:09:58 ERROR [geoserver.ows] -
java.lang.IllegalArgumentException: Property ‘count’ could not be found in INCIDENTGEOM
at org.geotools.filter.visitor.PostPreProcessFilterSplittingVisitor.visit(PostPreProcessFilterSplittingVisitor.java:787)
at org.geotools.filter.AttributeExpressionImpl.accept(AttributeExpressionImpl.java:381)
at org.geotools.filter.visitor.PostPreProcessFilterSplittingVisitor.visitBinaryComparisonOperator(PostPreProcessFilterSplittingVisitor.java:445)
at org.geotools.filter.visitor.PostPreProcessFilterSplittingVisitor.visit(PostPreProcessFilterSplittingVisitor.java:419)
at org.geotools.filter.IsLessThenOrEqualToImpl.accept(IsLessThenOrEqualToImpl.java:67)
at org.geotools.filter.visitor.PostPreProcessFilterSplittingVisitor.visitLogicOperator(PostPreProcessFilterSplittingVisitor.java:635)
at org.geotools.filter.visitor.PostPreProcessFilterSplittingVisitor.visit(PostPreProcessFilterSplittingVisitor.java:612)
at org.geotools.filter.NotImpl.accept(NotImpl.java:65)
at org.geotools.filter.visitor.PostPreProcessFilterSplittingVisitor.visitLogicOperator(PostPreProcessFilterSplittingVisitor.java:677)
at org.geotools.filter.visitor.PostPreProcessFilterSplittingVisitor.visit(PostPreProcessFilterSplittingVisitor.java:608)
at org.geotools.filter.AndImpl.accept(AndImpl.java:65)
at org.geotools.filter.visitor.PostPreProcessFilterSplittingVisitor.visitLogicOperator(PostPreProcessFilterSplittingVisitor.java:656)
at org.geotools.filter.visitor.PostPreProcessFilterSplittingVisitor.visit(PostPreProcessFilterSplittingVisitor.java:616)
at org.geotools.filter.OrImpl.accept(OrImpl.java:52)
at org.geotools.jdbc.JDBCFeatureSource.splitFilter(JDBCFeatureSource.java:375)
at org.geotools.jdbc.JDBCFeatureSource.splitFilter(JDBCFeatureSource.java:358)
at org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:458)
at org.geotools.jdbc.JDBCFeatureStore.getBoundsInternal(JDBCFeatureStore.java:189)
at org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:426)
at org.geotools.data.store.ContentFeatureCollection.getBounds(ContentFeatureCollection.java:175)
at org.geoserver.kml.KMLVectorTransformer$KMLTranslator.encode(KMLVectorTransformer.java:105)
at org.geoserver.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:219)
at org.geoserver.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:141)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:977)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:300)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:112)
at org.geoserver.wms.map.XMLTransformerMapResponse.write(XMLTransformerMapResponse.java:54)
at org.geoserver.wms.map.XMLTransformerMapResponse.write(XMLTransformerMapResponse.java:44)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:920)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:46)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:103)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:228)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
08 Mar 12:09:58 DEBUG [geoserver.filters] - Compressing output for mimetype: application/vnd.ogc.se_xml; charset=UTF-8
08 Mar 12:09:58 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
The SLD I used was :
<?xml version="1.0" encoding="ISO-8859-1"?>
<StyledLayerDescriptor version=“1.0.0”
xsi:schemaLocation=“http://www.opengis.net/sld StyledLayerDescriptor.xsd”
xmlns=“http://www.opengis.net/sld
xmlns:ogc=“http://www.opengis.net/ogc
xmlns:xlink=“http://www.w3.org/1999/xlink
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”>
vol_stacked_point
Stacked Point
Styles volcanoes using stacked points
<ogc:Function name=“gs:PointStacker”>
<ogc:Function name=“parameter”>
ogc:Literaldata</ogc:Literal>
</ogc:Function>
ogc:LiteralcellSize</ogc:Literal>
ogc:Literal30</ogc:Literal>
</ogc:Function>
ogc:LiteraloutputBBOX</ogc:Literal>
<ogc:Function name=“env”>
ogc:Literalwms_bbox</ogc:Literal>
</ogc:Function>
</ogc:Function>
ogc:LiteraloutputWidth</ogc:Literal>
ogc:Literalwms_width</ogc:Literal>
</ogc:Function>
</ogc:Function>
ogc:LiteraloutputHeight</ogc:Literal>
ogc:Literalwms_height</ogc:Literal>
</ogc:Function>
</ogc:Function>
</ogc:Function>
rule1
Volcano
ogc:Filter
ogc:PropertyIsLessThanOrEqualTo
ogc:PropertyNamecount</ogc:PropertyName>
ogc:Literal1</ogc:Literal>
</ogc:PropertyIsLessThanOrEqualTo>
</ogc:Filter>
triangle
#FF0000
8
rule29
2-9 Volcanoes
ogc:Filter
ogc:PropertyIsBetween
ogc:LowerBoundary
ogc:Literal2</ogc:Literal>
</ogc:LowerBoundary>
ogc:UpperBoundary
ogc:Literal9</ogc:Literal>
</ogc:UpperBoundary>
</ogc:PropertyIsBetween>
</ogc:Filter>
circle
#AA0000
14
Arial
12
bold
0.5
0.8
2
#AA0000
0.9
#FFFFFF
1.0
rule10
> 10 Volcanoes
ogc:Filter
ogc:PropertyIsGreaterThan
</ogc:PropertyIsGreaterThan>
</ogc:Filter>
circle
#AA0000
22
Arial
12
bold
0.5
0.8
2
#AA0000
0.9
#FFFFFF
1.0
Any help greatly appreciated.
Michael Howells
Technical Application Engineer
GE Digital Energy
Australia and New Zealand
T - +61 3 8807 6847
E - Michael.Howells@anonymised.com
572 Swan Street
Richmond, VIC 3121, Australia
GE imagination at work
On Fri, Mar 8, 2013 at 2:14 AM, Howells, Michael (GE Global Operations) <Michael.Howells@anonymised.com> wrote:
Please open a bug report on jira.codeahus.org with details.
If you want to fast track the inclusion of a fix in the code base try to donate a patch yourself, or
if you prefer look into the commercial support section at geoserver.org
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
See the note on the original version of that page:
https://github.com/opengeo/suite/blob/d035509e83bb1a3c292669b2f2328dcfb4240722/docs/usermanual/source/cartography/rt/pointstacker.rst
Due to a bug in the current release of the RenderingTransformation functionality, the input dataset must contains attributes with the names count and countUnique. The contents of the fields is not significant.
  • If the input is a file store, the file must be altered to contain columns with these names.
  • If the input is a database store, one way to provide the required columns is to define a SQL View with a query which includes extra columns with dummy values.
On Thu, Mar 7, 2013 at 5:14 PM, Howells, Michael (GE Global Operations) <Michael.Howells@anonymised.com> wrote:
Request: getMap
Time =
Filter = null
Buffer = 0
Width = 24750329
Filters = null
Height = 330
Palette = null
Tiled = false
SRS = EPSG:4326
MaxFeatures = null
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = false
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Exceptions = SE_XML
Version = 1.1.0
Request = GetMap
Get = true
vol_stacked_point
Stacked Point
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
rule1
Volcano
ogc:Filter
</ogc:Filter>
triangle
#FF0000
8
rule29
2-9 Volcanoes
ogc:Filter
ogc:LowerBoundary
ogc:UpperBoundary
</ogc:Filter>
circle
#AA0000
14
Arial
12
bold
0.5
0.8
2
#AA0000
0.9
#FFFFFF
1.0
rule10
> 10 Volcanoes
ogc:Filter
</ogc:Filter>
circle
#AA0000
22
Arial
12
bold
0.5
0.8
2
#AA0000
0.9
#FFFFFF
1.0
Michael Howells
GE Digital Energy
T - +61 3 8807 6847
E - Michael.Howells@anonymised.com76…
572 Swan Street
Symantec Endpoint Protection 12 positioned as A LEADER in The Forrester
Wave™: Endpoint Security, Q1 2013 and “remains a good choice” in the
endpoint security space. For insight on selecting the right partner to
tackle endpoint security challenges, access the full report.
http://p.sf.net/sfu/symantec-dev2dev
Geoserver-devel mailing list
