[Geoserver-devel] Proposal: allow configuring services available for a given layer
here is a proposal to allow configuring OGC services available for a given layer (as an alternative to installing and configuring GeoFence):
https://github.com/geoserver/geoserver/wiki/GSIP-172—Allow-configuring-services-on-a-per-layer-basis
Please discuss, or if you’re happy about it, vote? :slight_smile:
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
A few quick observations:
-1- I understand the default behavior should be allow all service but it would be also useful to have some sort of startup config to have a default controlled by a string that can be NONE|WMS-ONLY (just an idea).
This would allow admin to be more cautious and cover most useful use case (by experience)
-2- How do you load the available services in the lists. As an instance WPS might not be installed or I can create my own service that would not show up in this list hence I would not be able to control it.
Apart from this, this config makes a lot of sense to me from an admin perspective so I am in favour of this proposal.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
Well, I guess we could have a system variable that sets the default denied services (see backwards compatibility section, everything on by default) or the default enabled services (this would be new, but also possible)
that the catalog filter would take into account if a layer does not have an explicit list.
The list comes from a application context scan, all services are registered there.
The service access page already lists the existing services using this code:
https://github.com/geoserver/geoserver/blob/6e9e25c0c7cdda9ada9f33f8255130d3afc76801/src/web/security/core/src/main/java/org/geoserver/security/web/service/AbstractServiceAccessRulePage.java#L90
Cool, thanks!
Simone Giannecchini
@simogeo
Founder/Director
Hi Andrea,
looks good to me and an useful improvement.
+1 on the concept.
Is there a plan for a REST API for this?
For the backwards compatibility problem, I concur with the default approach for an existing data dir (preserve existing behaviour).
For the new service part of the problem (“Users plugging-in a new service while selective service configurations are already in place”), you could add a second interface that says whether the new service is enabled or disabled on layers by default. It seems unlikely that most developers would want opt-in for their shiny new service, so its probably not worth the effort.
Brad
Sent: Wednesday, 14 November 2018 1:05 AM
To: Geoserver-devel geoserver-devel@lists.sourceforge.net
Subject: [Geoserver-devel] Proposal: allow configuring services available for a given layer
On Tue, Nov 13, 2018 at 10:28 PM <bradh@anonymised.com> wrote:
+1 on the concept.
The proposal highlights two new properties for LayerInfo. As LayerInfo is serialized to XML by reflection, they will automatically
end up showing on the REST API outputs. I’ve added a bit of of text in the proposal.
I also had to move the flags from layer to resource, because the wfs/wcs service go directly for the resource skipping the layer configuration.
Agreed, I believe an admin is in a better position to deal with this. Adding a service should be a matter of planning, the admin should be
able to use the REST API, go through the layers, and change the configuration accordingly.
That said, I’ve modified the proposal to clarify that.
Modified the proposal and added the new variable to control the UI
Added my +1 to the proposal, it is good functionality that will be very much appreciated.
In terms of user interface change, I was wondering if the “WMS Settings” would be disabled (or hidden) if the WMS service was not turned on? If so it may be more consistent to use a checkbox (as with enabling/disabling tile services, enabling/disabling workspace WMS, enabling/disabling global WMS.
I know user interface consistently is far down the list of priorities :stuck_out_tongue:
Jody Garnett
