[Geoserver-devel] Proposal and call for vote: align copyright header management policy with GeoTools one
As previously discussed, here we go with a proposal to simplify copyright header management:
https://github.com/geoserver/geoserver/wiki/GSIP-147----Align-with-GeoTools-copyright-header-management-practices
The point about existing files lacking a copyright header might be contentious, I’ve just chosen
the quickest approach, as with old files the current git history might not be sufficient anyways (one would
have to go and find files in the geoserver-history repo, and sometimes files have been moved in svn
without the proper commands, making it hard to actually track the file origin).
Please vote and/or discuss
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On Sat, Jun 25, 2016 at 4:27 PM, Andrea Aime <andrea.aime@anonymised.com>
header management:
Sorry, had to update the link:
Ing. Andrea Aime
@geowolf
Technical Lead
+1.
I suggest a small rewording in the new policy:
"that happens to miss it" -> "without one"
And a new bullet point that spells out the big change:
- Otherwise do not change the copyright header when an existing file is modified
One other question: should we change existing date ranges to single years when the file is modified?
I support removing all dates from copyright headers; I will be interested to see the legal advice on this matter obtained by OSGeo.
Kind regards,
Ben.
header management:
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
http://sdm.link/attshape
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
On Sat, Jun 25, 2016 at 10:57 PM, Ben Caradoc-Davies <ben@anonymised.com>
wrote:
+1.
modified
Good suggestions, proposal amended
In my opinion, we should not, it would partially defeat the purpose of this
proposal and GeoTools one, which is
mostly to remove copyright maintenance and pull request friction.
Btw, the GeoTools proposal does not say anything in this respect as far as
I know, or did I miss it?
Ing. Andrea Aime
@geowolf
Technical Lead
Agreed. We can just leave existing date ranges alone.
No, I do not think the GeoTools proposal mentions changing existing date ranges.
Kind regards,
Director
New Zealand
Thanks for proposal. Added my +1.
If it gets approved, I am willing to do the pull request / editorial work for
this if you don't already have it.
Brad
for
I don't have changes ready, your help is much appreciated :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
+1
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Sat, Jun 25, 2016 at 10:57 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
+1.
modified
Kind regards,
Ben.
header management:
Director
New Zealand
I would vote +0 currently (preferring to wait until we have solid feedback from OSGeo legal council). As GeoTools project officer I can vouch that an funds have been allocated and that the treasure has sent the initial inquiry.
Jody Garnett
On Sat, Jun 25, 2016 at 4:27 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Sorry, had to update the link: https://github.com/geoserver/geoserver/wiki/GSIP-147
Ing. Andrea Aime
@geowolf
Technical Lead
this proposal and GeoTools one, which is mostly to remove copyright
It says nothing, idea is to do nothing further to headers. You can see the
resulting developers guide here:
http://docs.geotools.org/latest/developer/conventions/code/style.html#but-what-about-the-header
Not a voting member, but I think this is a good idea
+1
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@...3926...
(attachments)
this if you don’t already have it.
I don’t have changes ready, your help is much appreciated :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
I don't have any specific problem but I feel my familiarity with legal
stuff is weak and I don't find the existing system particularly onerous
so +0.
Kevin Michael Smith
<smithkm@anonymised.com>
+1 for me
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
