[Geoserver-devel] Proposal for official docker GeoServer image
Hello everybody,
i finally found the time to add a proposal for an official docker GeoServer image:
https://github.com/geoserver/geoserver/wiki/GSIP-192
(also added it here https://github.com/geoserver/geoserver/wiki/Proposals)
There are no implementations yet and next week i'll be on vacation (and not available for discussions). But in August i should find more time to push this forward.
Best regards,
Nils
Hi Nils,
quick feedback.
The official production instructions are outdated, I would say use OpenJDK, it keeps on being released and
it will be for the foreseeable future.
The rest looks generally good, I would love to see a bit more details about the extension management,
other than a link to an existing dockerfile.
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
thanks for your quick feedback. I adjusted the proposal (use OpenJDK instead of Oracle, in fact this was a copy/paste from the instructions).
Regarding the extension management: Currently it is indeed only the “idea” (as you suggested in the meeting).
But as soon as i will start with the implementation after my vacation, i am pretty sure that i can provide more details on this.
Nils
Am 24.07.20 um 14:33 schrieb Andrea Aime:
Hi Nils,
quick feedback.
On Fri, Jul 24, 2020 at 1:52 PM Nils Bühner <buehner@anonymised.com> wrote:
Hello everybody,
GeoServer image:
There are no implementations yet and next week i’ll be on vacation (and
push this forward.
Best regards,
Nils
Geoserver-devel mailing list
Geoserver-devel@anonymised.coms.sourceforge.net
Looks good, the java considerations page has been updated, I would recommend OpenJDK 8 (with Marlin as you already describe) and “Unlimited Strength Jurisdiction Policy Files” if they are not already provided by the Ubuntu OpenJDK 8 distribution.
I had a question about storage of:
  • GEOSERVER_DATA_DIR
  • GEOWEBCACHE_CACHE_DIR
I see these assigned in different locations on each of the Dockerfile examples provided. One makes the GeoServer data directory a volume (I suspect to make backups and updates easier).
I think this is worth discussion!
Jody Garnett
Hello,
i finally found some time to make some initial steps on the proposed docker image:
https://github.com/geoserver/docker/pull/1
Any feedback is appreciated and i plan to continue work on this in the next weeks.
Best regards,
Nils
Am 24.07.20 um 13:50 schrieb Nils Bühner:
Hello everybody,
Best regards,
Nils
   Nils Bühner
   - Anwendungsentwickler -
   terrestris GmbH & Co. KG
   Kölnstraße 99
   53111 Bonn
   Tel: +49 (0)228 / 96 28 99 -54
   Fax: +49 (0)228 / 96 28 99 -57
   Email: buehner@anonymised.com
   Web: https://www.terrestris.de
   Amtsgericht Bonn, HRA 6835
   Komplementärin: terrestris Verwaltungsgesellschaft mbH
   vertreten durch: Torsten Brassat, Marc Jansen
      Informationen über Ihre gespeicherten Daten finden Sie auf
   unserer Homepage unter folgendem Link:
   https://www.terrestris.de/datenschutzerklaerung/
Nils:
I think I added a few comments to the PRs, but noticed that my opinions will not match always match others (example Java 8 vs Java 11).
As the person doing the work you get the choice :slight_smile:
I would recommend merging, and publishing this for the most recent 2.18.0 release, and asking for feedback from people running it.
Jody Garnett
