[Geoserver-devel] Proposal for official GeoServer Docker image
Hello everybody,
I plan to submit a proposal for an official GeoServer Docker image in the near future (see notes on Tuesday's session). The issue was already raised in September last year, but not much has happened since then (see http://osgeo-org.1560.x6.nabble.com/GeoTools-GeoServer-PMC-meeting-2019-09-17-td5416490.html).
I would like to ask for ideas and thoughts on this topic that could be included in the proposal.
A key point is certainly the handling of extensions. Since not everyone needs the same set of extensions in their GeoServer, the current idea is that a user-defined set of extensions could be downloaded and included on container startup (before the tomcat actually starts).
Best wishes,
Nils
   Nils Bühner
   - Anwendungsentwickler -
   terrestris GmbH & Co. KG
   Kölnstraße 99
   53111 Bonn
   Tel: +49 (0)228 / 96 28 99 -54
   Fax: +49 (0)228 / 96 28 99 -57
   Email: buehner@anonymised.com
   Web: https://www.terrestris.de
   Amtsgericht Bonn, HRA 6835
   Komplementärin: terrestris Verwaltungsgesellschaft mbH
   vertreten durch: Torsten Brassat, Marc Jansen
      Informationen über Ihre gespeicherten Daten finden Sie auf
   unserer Homepage unter folgendem Link:
   https://www.terrestris.de/datenschutzerklaerung/
Thanks for taking on this activity, I hope some of the other parties that expressed interest will join you.
I am sure all my input is obvious (follow the install instructions, open port 8080).
Jody Garnett
just thinking out loud, it would be nice to have an automated way to just give a list
of extension names (without the version) and have the system download them
for you. Maybe it does not have to be in the docker image itself, could be an external script that downloads
the extensions and puts them in the right folder for the docker image to pick them up, “pimpMyGeoserver.sh” :smiley:
(kidding about the name!!).
You know, so that on upgrade, one can just change the image name and go.
Oh, the data directory should probably be allowed to live outside of the docker image too?
And maybe the GWC tiles directory as well (can grow and become huge).
Just thinking out loud, as long as the docker image has a maintainer, one can start small and add improvements
later.
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Speaking of which, this might offer some ideas:
https://github.com/geosolutions-it/docker-geoserver
(I’m not involved in it directly mind)
I like this idea and am in full support.
I suspect that the best approach would be to look at existing geoserver docker images such as kartoza/geoserver, winsent/geoserver, oscarfonts/geoserver, geodocker/geoserver etc and see what are the good and bad points of these images.
I like Andrea’s suggestion of a list of extensions and a script to process it (that could be a useful general tool).
Ian
Ian Turton
Thanks for all the input. I'll collect all the information and incorporate them into the proposal. Hopefully I will find time for that in the coming week.
Nils
Am 25.06.20 um 09:48 schrieb Nils Bühner:
Hello everybody,
Best wishes,
Nils
   Nils Bühner
   Kölnstraße 99
   53111 Bonn
I’d like to add that it would be good to include some mechanism to configure the Docker container using environment variables (or ConfigMaps in case you’re running on Kubernetes). I made an example for last year’s proposal in that you might want to explore as well: https://github.com/boonen/docker-geoserver/
Also, I’d be happy to discuss the proposal and contribute where needed.
Jan
Geodan
Buitenhaven 27-A
5211 TP 's-Hertogenbosch (NL)
T +31 (0)73 - 692 5151
M +31 (0)6 - 2395 1191
E jan.boonen@anonymised.com
www.geodan.nl | disclaimer
Unfortunately i have a lot of things to do this week, so I won't find time for the proposal until next week at the earliest. But be sure that it will come :wink:
Best regards,
Nils
Am 30.06.20 um 15:58 schrieb Nils Bühner:
Nils
Hello everybody,
Best wishes,
Nils
   Nils Bühner
   Kölnstraße 99
   53111 Bonn
