[Geoserver-devel] proposal: LDAP UserGroupService
Hello,
I was waiting to make this proposal for after the release:
https://github.com/geoserver/geoserver/wiki/GSIP-144--
Basically: There is no LDAP UserGroupService yet. Some people might want one. For example, to use the integrated geofence with ldap, because the integrated geofence relies on a UserGroupService.
Please vote / provide feedback.
Thanks
Niels
Added my +1
On Mon, May 2, 2016 at 10:46 AM, Niels Charlier <niels@anonymised.com> wrote:
Hello,
https://github.com/geoserver/geoserver/wiki/GSIP-144–
Thanks
Niels
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Geoserver-devel mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
+1
The proposal is not _tremendously_ detailed but I think this is a
feature that is needed.
If you can just elaborate a little on the proposal itself that would be great.
As an instance, do you intend to put same caching in between GS and
LDAP to avoid LDAP sloweness slowing down request serving?
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Mon, May 2, 2016 at 12:20 PM, Christian Mueller
<christian.mueller@anonymised.com> wrote:
Added my +1
Hello,
Thanks
Niels
Manager
tiers of
of
I tried the link below and it wound up on a "Create new wiki" page. Removing the -- at the end resulted in
This page did open.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
-----Original Message-----
Sent: Monday, May 02, 2016 2:46 AM
To: Geoserver-devel <geoserver-devel@lists.sourceforge.net>
Subject: [Geoserver-devel] proposal: LDAP UserGroupService
Hello,
Thanks
Niels
Hi
@Simone, GeoServer uses caching already. Its the same as if you are using a user group store based on JDBC. No need to implement a special LDAP cache for serving requests.
On Mon, May 2, 2016 at 4:53 PM, Chris Snider <chris.snider@anonymised.com> wrote:
I tried the link below and it wound up on a “Create new wiki” page. Removing the – at the end resulted in
This page did open.
Chris Snider
From: Niels Charlier [mailto:niels@anonymised.com918…]
Hello,
Thanks
Niels
Ciao Christian,
I did not know that :slight_smile:
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Mon, May 2, 2016 at 5:29 PM, Christian Mueller
Hi
wrote:
This page did open.
Chris Snider
Hello,
Thanks
Niels
Manager
tiers of
Manager
tiers of
of
Thanks, Simone.
Extra information:
It would be implemented in an analogue way to the RoleService. The different method implementations would execute LDAP search queries to retrieve the requested user information and translate the data to user/group objects. Configuration would also be similar to the RoleService and AuthenticationService but slightly more extended: users could choose between providing filters for retrieving all/specific users/groups or simply provide the necessary attribute names (where the filters are automatically created).
Regards
Niels
On 02-05-16 16:50, Simone Giannecchini wrote:
+1
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Added my +1
Hello,
Thanks
Niels
Manager
tiers of
of
Hi Niels
The jdbc implementation uses a propterty file for all sql statements
./main/resources/org/geoserver/security/jdbc/usersdml.xml
Do you plan something similar to the ldap implementation.
The nice thing is that users can adjust the queries to their environment.
On Mon, May 2, 2016 at 6:08 PM, Niels Charlier <niels@anonymised.com> wrote:
Thanks, Simone.
Extra information:
Regards
Niels
+1
The proposal is not tremendously detailed but I think this is a
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
Added my +1
Hello,
Thanks
Niels
Manager
tiers of
of
Hello Christian,
The appropriate queries will all be configurable, yes.
Regards
Niels
On 05/03/2016 06:30 AM, Christian Mueller wrote:
Hi Niels
Thanks, Simone.
Extra information:
Regards
Niels
+1
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Added my +1
Hello,
Thanks
Niels
Manager
tiers of
of
Hi Niels,
from a quick read:
  • Is it really targeted to 2.11, and not to 2.10? :slight_smile: Are you considering a backport to 2.9?
  • You are making a proposal for it, so it’s going to be part of core, with the UI in web/security/ldap? (no problems with it, but the proposal should say so)
  • The configurable portions should be mentioned in the proposal (your answer to Christian)
How about longer term maintainership? Core stuff is officially maintained by the PSC, so do you expect
to drop off after the proposal and have the PSC handle community fixes and bug reports?
On Mon, May 2, 2016 at 10:46 AM, Niels Charlier <niels@…2918…> wrote:
Hello,
Thanks
Niels
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Andrea,
Answers inline.
On 03-05-16 09:52, Andrea Aime wrote:
- Is it really targeted to 2.11, and not to 2.10? :slight_smile:
Fixed
This is not necessary for me.
- You are making a proposal for it, so it's going to be part of core, with the UI in web/security/ldap? (no problems with it, but the proposal should say so)
Done
- The configurable portions should be mentioned in the proposal (your answer to Christian)
I had already added that.
The implementation is very much in line with / integrated with the rest of the sec-ldap module. I know it quite well now and I am willing to assist with supporting the module in the longer term. Only recently I tested it thoroughly with openldap after the spring upgrade.
Kind Regards
Niels
Can I get a couple more +1 :slight_smile:
On 03-05-16 10:14, Niels Charlier wrote:
Andrea,
Answers inline.
Fixed
Done
and bug reports?
Kind Regards
Niels
Sorry for the delay … very busy days :frowning:
I’m interested on this proposal, here is my +1
On Thu, May 5, 2016 at 10:00 AM, Niels Charlier <niels@anonymised.com> wrote:
Andrea,
Answers inline.
    Fixed
    Done
    and bug reports?
Kind Regards
Niels
Best Regards,
Alessio Fabiani.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
mob: +39 331 6233686
+1
Jukka Rahkonen
Lähettäjä: Niels Charlier
Lähetetty: ‎5.‎5.‎2016 11:03
Vastaanottaja: geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] proposal: LDAP UserGroupService
Andrea,
Answers inline.
    Fixed
    Done
    and bug reports?
Kind Regards
Niels
+1, though I would like to see recognition that this will need documentation
(ideally a tutorial) on application and limitations.
Brad
Drea Brad,
good point, I was kind of assuming that a brief section in the
documentation will be produced as part of this work since it
introduces new functionality.
Not sure this should be made explicit in the proposal.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Brad
On Thu, May 5, 2016 at 12:10 PM, Simone Giannecchini <
simone.giannecchini@anonymised.com> wrote:
Drea Brad,
Does not hurt to be explicit about it though... tests have been mandatory
for a long time,
documentation is kind of implied but not always requested for new core
functionality so far...
Maybe we should make a proposal in this direction to clarify it?
Anyways, +1 on this proposal under the condition there are also docs
(reference ones for a minimum, a tutorial would be great but not required)
Ing. Andrea Aime
@geowolf
Technical Lead
+1.
Please fix the links at the bottom of the GSIP page. They are still boilerplate.
Kind regards,
Ben.
On 02/05/16 20:46, Niels Charlier wrote:
Hello,
Thanks
Niels
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Hi Niels,
Since we funded this feature, I would of course +1 this (if this is allowed, I don’t know if the vote is open to everyone).
We are already using the service on a 2.8.x instance successfully.
Kind regards,
Pierre Mauduit
Ingénieur développement
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 58 48 20 24
Fax : +33 4 58 48 20 10
Mail : pierre.mauduit@anonymised.com757…
http://www.camptocamp.com
The proposal has been accepted.
The PR is ready to be reviewed at https://github.com/geoserver/geoserver/pull/1540 by someone with the authority to approve it at their earliest convenience.
Kind Regards
Niels
On 09-05-16 15:07, Pierre Mauduit wrote:
Hi Niels,
    might want
    because the
Since we funded this feature, I would of course +1 this (if this is allowed, I don't know if the vote is open to everyone).
Kind regards,
Pierre Mauduit
Mail : pierre.mauduit@anonymised.com <mailto:pierre.mauduit@anonymised.com>
http://www.camptocamp.com/&gt;
