Hi dev list,
I would like to propose a new community module : a web UI page for the edition of the FreeMarker templates.
This is an old project of mine, that hadn’t gone through the community module step and got buried at some point.
Some people from the geOrchestra community have expressed a keen interest in this module and had me resurrect it. This is why I would like to bring it back to life and have it as community module.
It is a simple UI, almost simplistic. The editor is a plain TextArea. But it allows to easily manage the templates’ inheritance system (from default to workspace to store to layer) and have an easy view of where the current template files are taken from. On the authentication level, it is available for whomever has the admin rights on a workspace (no need to belong to admin group).
It is working fine on master. The code is on my repo, ready to be pulled in. I have written a documentation page too. I already have signed an individual contributor licence agreement with OSGeo.
I hope you will like it,
Best,
Jean
Jean Pommier – pi-Geosolutions
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr
Sounds great indeed.
Can’t give you the go-ahead though.
Gabriel Roldán
Looks like a good idea +1
Ian
Ian Turton
Gabriel, Ian, Andrea, thank you.
Then, if I read correctly the instructions to get promoted to community extension, I just need approval by at least one member of the PSC, so it is a deal, right ?
Next step would be to get git access to the repo ?
my git ID is jeanpommier
Thanks for the support,
Jean
Le 29/06/2022 à 10:55, Andrea Aime a écrit :
+1 here too
Ian
On Fri, 24 Jun 2022 at 20:09, Jean Pommier <jean.pommier@anonymised.com> wrote:
Hi dev list,
Best,
Jean
Geoserver-devel mailing list
Ian Turton
Andrea Aime
== GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions Group phone: +39 0584 962313
mob: +39 333 8128928
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail
Hi Jean,
we are a bit more careful about giving out commit access since most of the work can be done
via PRs anyways (we should probably update the docs). Can you make a PR to integrate the module in GeoServer to get
started?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Hi Andrea,
Yes, sure !
I must admit I was a bit surprised you would give direct commit access ;o)
Which branch(es) should I target ? main, of course, but should I also submit a PR on latest release for instance ? Or 2.21.x branch ?
Jean
Le 04/07/2022 à 10:49, Andrea Aime a écrit :
Hi Jean,
started?
On Wed, Jun 29, 2022 at 11:17 AM Jean Pommier <jean.pommier@anonymised.com> wrote:
Jean
+1 here too
Ian
Hi dev list,
Best,
Jean
Ian Turton
Andrea Aime
Andrea Aime
As you said, the main branch for sure.
About the other branches, it’s really up to you.
Personally I try to stay on main for as long as I can, less overhead with backports and the like, but
it also means less users interested in trying out the module since that’s the development series
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Thanks Andrea.
Well, since it’s relying on stuff that haven’t changed much recently, I believe it’s 100% compatible at least with GS 2.18+.
And since some geOrchestra people want it, I’ll target the 2 latest versions of geOrchestra, I think (means GS 2.18+)
I’ll PR soon. Thanks !
On Tue, Jul 5, 2022 at 12:08 PM Jean Pommier <jean.pommier@anonymised.com> wrote:
Hi Andrea,
Yes, sure !
Jean
Hi Jean,
started?
Jean
+1 here too
Ian
Hi dev list,
Best,
Jean
Ian Turton
Andrea Aime
Andrea Aime
Andrea Aime
