Currently, the biweekly PMC meeting happens at 16:30 UTC
Now that both NA and EU have switched back from Daylight Savings time, do we want to shift the PMC meeting forward an hour so that it happens at the same time it used to for everyone in their local timezones?
Either time works for me - does anyone have specific constraints that make one time better (or worse) than the other?
Seems like we never heard from Ian on this, huh.
I rather like the idea of fixing this to follow a timezone local to some of the attendees, I’ll tinker with the time and date link on this week’s reminder to see how that might work, and we can discuss further tomorrow.
Given that I’ve seen no dissent, and enough of the usual suspects have +1’d, we’ll move to 17:30 UTC for the next meeting.
