Hi Andrea,
It seem like there might be some confusion with the different oracle issues floating around. The oracle version(https://jira.codehaus.org/browse/GEOT-4912 ) issue has nothing to do with the patch Lingbo is suggesting on implementing. However to clear up the confusion, I have advised Lingbo to create appropriate Jira task and submit a proposal instead so that the issue can be discussed accordingly around the proposal instead.
Thanks
Victor
Sent: Wednesday, 11 March 2015 12:49 PM
To: Tey, Victor (Mineral Resources, Kensington)
Subject: FW: [Geoserver-devel] [ExternalEmail] Re: Propose to add an option for latLongBoundingBox range checking before database query.
From: andrea.aime@…403… [mailto:andrea.aime@…403…] On Behalf Of Andrea Aime
Sent: Wednesday, 11 March 2015 1:50 PM
To: Jiang, Lingbo (Digital, Marsfield)
Cc: Rahkonen Jukka (MML); Jody Garnett; Geoserver-devel
Subject: Re: [Geoserver-devel] [ExternalEmail] Re: Propose to add an option for latLongBoundingBox range checking before database query.
On Sun, Mar 8, 2015 at 11:53 PM, <Lingbo.Jiang@…254…> wrote:
Hi Everyone,
I am working a patch on the “Honour the configured BBOX” with geoserver wms module. And we found that the number of database queries could reduce significantly with the BBOX to filter out the useless query. And it do improve the performance lots.
Hem… you found that it helps a lot in a particular Oracle version (according to other comments) and had the suggestion from two
core developers and PSC members to try and do the fix in the Oracle data store.
Sorry to pull seniority here, but you cannot just ignore the comments you don’t like and go on your merry way, whatever
comes out of a discussion needs an agreement to move on with code.
So could you please share why you think this must be done in a general way, as opposed to inside the Oracle store?
So far, I am trying to put this BBOX application option into the configuration file. I noticed that there are few choice:
ApplicationContext.xml.
Wms.xml
Global.xml
Could someone suggest that which one will better to suit and what’s best way to add this option. A code snippet will be even great.
Neither of them, this kind of setting would have to go in resource.xml as it would be a per layer one, not all layers
in an installation would be Oracle, or would have to be locked to a bbox (wfs-t layers definitely do not, poeple will add
data out of the bbox you configured.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
