I will try and break down points of concerns and address them.
- We have previously had trouble integrating JAX-B XML stack, in particular with GML content which is often more flexible then the JAX-B code generation cycle.
VT: High source have done this for us. Furthermore we are only using sos 2.0 implementation
- I am weary of the thought of two copies of the core OGC schemas lurking in our code base.
VT: No xsds will be added. HighSource have provide the class files for the schemas
- Adding more dependencies should be done quite carefully
This will be a community module and I don’t expect the size of it to be big. There also won’t be a dependency from core to this module and dependency of this module should be relatively small since we are only using the SOS 2.0 schema binding.
Below are some examples from http://confluence.highsource.org/display/OGCS/Reference
To use the wms binding,
org.jvnet.ogc
wms-v_1_3_0-schema
1.0.0
Unmarshalling
// Create JAXB context for WMS 1.3.0
JAXBContext context = JAXBContext
.newInstance("net.opengis.wms.v_1_3_0");
// Use the created JAXB context to construct an unmarshaller
Unmarshaller unmarshaller = context.createUnmarshaller();
// GetCapabilities URL of the Demis WorldMap WMS Server
String url = "http://www2.demis.nl/wms/wms.asp?REQUEST=GetCapabilities&VERSION=1.3.0&wms=WorldMap";
// Unmarshal the given URL, retrieve WMSCapabilities element
JAXBElement<WMSCapabilities> wmsCapabilitiesElement = unmarshaller
.unmarshal(new StreamSource(url), WMSCapabilities.class);
// Retrieve WMSCapabilities instance
WMSCapabilities wmsCapabilities = wmsCapabilitiesElement.getValue();
// Iterate over layers, print out layer names
for (Layer layer : wmsCapabilities.getCapability().getLayer()
.getLayer()) {
System.out.println(layer.getName());
**Creating Objects:**
private net.opengis.wms.v_1_3_0.ObjectFactory objectFactory =
new net.opengis.wms.v_1_3_0.ObjectFactory();
private WMSCapabilities createWMSCapabilities() {
final WMSCapabilities wmsCapabilities = objectFactory
.createWMSCapabilities();
wmsCapabilities.setService(createService());
wmsCapabilities.setCapability(createCapability());
return wmsCapabilities;
private Service createService() {
final Service service = objectFactory.createService();
service.setName("WMS");
service.setTitle("Dummy WMS service");
service.setOnlineResource(createOnlineResource("http://localhost"));
return service;
private Capability createCapability() {
final Capability capability = objectFactory.createCapability();
capability.setRequest(createRequest());
capability.setException(createException());
capability.setLayer(createLayer());
return capability;
Marshalling:
// Construct the WMS capabilities object
WMSCapabilities wmsCapabilities = ...;
// Create a JAXB context
// Create a marshaller
Marshaller marshaller = context.createMarshaller();
// Set a property for the formatted (indented) output
marshaller.setProperty(Marshaller.JAXB_FORMATTED_OUTPUT, Boolean.TRUE);
// Marshal capabilities to the system out
marshaller.marshal(wmsCapabilities, System.out);
Sent: Wednesday, 26 September 2012 2:34 PM
To: Tey, Victor (CESRE, Kensington)
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Proposed solution for SOS 2.0
I generally like the approach when compiling a one off client to work with a specific server.
In your case you may indeed be successful since you are targeting WaterML specifically. I am weary of the thought of two copies of the core OGC schemas lurking in our code base.
Can you review how the recent work on CSW makes use of XML binding (rather than JAX-B) and let us know what you think.
Jody Garnett
On Tuesday, 25 September 2012 at 7:14 PM, Victor.Tey@…254… wrote:
Hi, I have drafted out a proposed solution based on JAX-B. Highsource have put in great effort in binding ogc schemas to jax-b and have added support for sos 2.0 and om 2.0. They are recommended by ogcnetwork.
Please do take a look and give your opinion.
We intend to create sos as a webservice on Geoserver, something similar to the recent work on CSW
The proposed solution in delivering the service are documented here
https://www.seegrid.csiro.au/wiki/SISS4BoM/SOSProposedModule
Proposed Solution for SOS 2.0 Development:## Introduction
This page is a description of a proposed solution to deliver SOS 2.0. A summary of the main functional criteria for this project are as follow:
- Easy to configure for most/basic usage
- Support multiple databases
- Modular enough to support evolutions of schemas
- For the current project we aim to support sos 2.0 with WaterML? but code should be extensible to support other result type such as SWE
- Deliver valid SOS 2.0 service.
Overview
Diagram: GetObservationResponse? example
Explaination
The solution to this implementation lies on the use of jax-b framework. There are currently an existing community that have taken the effort to create all the xjc binding for most of the ogc schemas.
http://www.ogcnetwork.net/jaxb4ogc
and SOS 2.0 with OM 2.0 have recently been added to their development trunk.
Based on the diagram, that boils our work down to the following
- Create a user UI to map configuration to om:observation
- Create a user UI to map database field to WaterML? schema
- Identify the JAX-B entity classes to populate for marshalling the class out as response.
- Integrate to GeoServer
WorkFlow#### GeoServer? workflow
Workflow for GeoServer? is simple. Detect community module for SOS support. If found, load the sos config tab else resume normal GeoServer? Interface.
User workflow
Note: we are currently still designing how the UI will look like but the WaterML? model configuration UI will be similar to the simple feature UI except it will have a addtional drop down box alongside to map the database field to the right schema element.
We are restricting the users to certain models that we support for om:result. eg. WaterML?. If the user decide to use predefined model there are certain advantage and disadvantage
Advantage:
- faster performance on filtering since filtering will be performed on the database prior to parsing into a Document.
- Easier to use and manage since configuration are done via UI
- Other model for the om:result can be support by adding the right UI for them (might be possible to auto generate via reflection or custom annotation)
Disadvantage:
- WaterML are confined to a a single table in the database. Multi tables per model is not support (use app-schema if necessary but should be avoided)
- WaterML mapping are fixed therefore user lose the flexibility.
Alternatively if the configuration is something even more complex, user can opt for app-schema but bare the cost of performance and configuration learning curve.
Summary
Currently we used GetObservationResponse? as an example but the same architecture will apply to other domain such as getCapabilities etc.
Outstanding issues- How will this service be intergrated into GeoServer? as a web service. (Currently investigating)
- I am unsure how SOS 3.0 , om 3.0 will affect this architecture but it really depend on how big the changes are. Do we abstract out the sos 2.0 entites class and try to make it work with 3.0 or do we redo what we have done as a seperate module reusing common code as libraries.
Victor Tey
Software Engineer
ASRDC
CSIRO Earth Science and Resource Engineering
Phone: +61 8 6436 8944
Victor.Tey@…254… | www.csiro.au |
Address: Australian Resources Research Centre, 26 Dick Perry Avenue, Kensington WA 6151
PLEASE NOTE
The information contained in this email may be confidential or privileged. Any unauthorised use or disclosure is prohibited. If you have received this email in error, please delete it immediately and notify the sender by return email. Thank you. To the extent permitted by law, CSIRO does not represent, warrant and/or guarantee that the integrity of this communication has been maintained or that the communication is free of errors, virus, interception or interference.
Please consider the environment before printing this email.
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
Geoserver-devel mailing list
(attachments)
