This community module will allow entering specific request parameters as URL path fragments (REST like URLs) instead of using the query string.
For example, we want to be able to apply a cql_filter using a URL in the following form:
http://:/geoserver//**//**ows?service=WMS&version=1.3.0&request=GetMap
As a simple example of usage, if the is something like:
cql_filter=seq=‘K140M’
the URL would become:
http://:/geoserver///K140M**/**ows?service=WMS&version=1.3.0&request=GetMap
and the proposed community module will translate the URL to this new one:
http://:/geoserver///ows?service=WMS&version=1.3.0&request=GetMap&cql_filter=seq=‘K140M’
This community module could be used to enable REST like URLs for clients that are not able to consume OGC protocols directly.
This module is configured by a set of rules that will allow us to select the URLs that should be transformed and describe the transformation to be applied:
The match attribute contains a Java Regular Expression that is used for two proposes:
selecting the URLs that should be transformed
extract the pieces of information (groups) than can be used to describe the transformation.
The parameter attribute defines the parameter that should be added to the query, in this case the ‘cql_filter’ parameter.
The remove attribute must reference a valid group of the match expression (typically the must external one) which will be removed from the original URL.
The transform attribute defines the parameter value content. The transform string can reference any valid group of the match expression.
This module can be implemented as Servlet Filter which will give us total control over when it should be executed (regarding the filters chain), but this will make it harder to implement a “plug and play” behavior.
Another option is to implement this module as a filter that extends the GeoServerFilter and ExtensionPriority interfaces, this will make very easy to implement the “plug and play” behavior but the filter will be executed by the
SpringDelegatingFilter filter which is executed only after the AdvancedDispatchFilter filter and I’m not sure to understand all the implications of this.
Any feedback on this is welcome.
Best regards,
Nuno Oliveira
