[Geoserver-devel] providence review - three issues remaining
With a bit of encouragement from Andrea I have knocked over a lot of the issues that turned up during review. The most significant change was referencing the Apache 2.0 and Apache 1.1 license from our documentation (and adding a license section to our developers manual).
Here is what is left on the GeoServer Provenance Review page:
Just focusing on whacky licenses here is what has been fixed up:
validation
  • extension/validation/src/main/java/org/vfny/geoserver/config/validation/ArgumentConfig.java (GEOS-5426)
  • extension/validation/src/main/java/org/vfny/geoserver/config/validation/ValidationConfig.java (GEOS-5426)
  • extension/validation/src/main/java/org/vfny/geoserver/global/GeoValidator.java (GEOS-5426)
imagemap
  • extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/Decimator.java - modified from GeoTools LGPL (GEOS-5416)
wps
  • extension/wps/wps-core/src/main/java/org/geoserver/wps/ppio/JAIToolsRangeConverterFactory.java - GeoTools LGPL Header (GEOS-5469)
  • extension/wps/wps-core/src/main/java/org/geoserver/wps/resource/CoverageResource.java - missing header
  • extension/wps/wps-core/src/main/java/org/geoserver/wps/resource/GridCoverageResource.java - missing header
gwc
  • gwc/src/main/java/org/geoserver/gwc/dispatch/package-info.java - missing header
main
  • main/test/org/vfny/geoserver/config/ValidationTest.java - GEOS-5455
  • main/src/main/java/org/vfny/geoserver/global/xml/NameSpaceElement.java - GEOS-5455
  • main/src/main/java/org/vfny/geoserver/global/xml/GMLSchemaTranslator.java - GEOS-5455
  • main/src/main/java/org/vfny/geoserver/global/xml/XMLSchemaTranslator.java - GEOS-5455
  • main/src/main/java/org/vfny/geoserver/global/xml/NameSpaceTranslatorFactory.java - GEOS-5455
  • main/src/main/java/org/vfny/geoserver/global/xml/NameSpaceTranslator.java - GEOS-5455
  • main/src/main/java/org/vfny/geoserver/filters/SetCharacterEncodingFilter.java - Apache License Version 2.0 (GEOS-5470)
  • main/src/main/java/org/geoserver/jai/JAIInfo.java - seems fine?
  • main/src/main/java/org/geoserver/filters/GZIPFilter.java GEOS-5460
  • main/src/main/java/org/geoserver/filters/GZIPResponseWrapper.java GEOS-5460
  • main/src/main/java/org/geoserver/filters/GZIPResponseStream.java GEOS-5460
ows
  • ows/src/main/java/org/geoserver/ows/util/RewindableInputStream.java GEOS-5454
  • ows/src/main/java/org/geoserver/ows/util/UCSReader.java GEOS-5453
release
  • release/installer/mac/console/src/main/java/org/geoserver/console/Browser.java GEOS-5456
rest
  • rest/src/test/java/org/geoserver/rest/FormatTest.java.patch - um that looks like an accident (removed file)
wcs
  • wcs/src/main/java/org/geoserver/wcs/CoverageCleanerCallback.java - missing header
wcs1_1
  • wcs1_1/src/main/java/org/geoserver/wcs/xml/v1_1_1/bindings/TimeSequenceTypeBinding.java GEOS-5459
  • wcs1_1/src/main/java/org/geoserver/wcs/xml/v1_1_1/bindings/TimePeriodTypeBinding.java GEOS-5459
web core
  • web/core/src/test/java/org/geoserver/web/ComponentBuilder.java - empty header
wfs
  • wfs/src/main/java/org/geoserver/wfs/xml/NameSpaceElement.java (GEOS-5455)
  • wfs/src/main/java/org/geoserver/wfs/xml/GMLSchemaTranslator.java (GEOS-5455)
  • wfs/src/main/java/org/geoserver/wfs/xml/XMLSchemaTranslator.java (GEOS-5455)
  • wfs/src/main/java/org/geoserver/wfs/xml/NameSpaceTranslatorFactory.java (GEOS-5455)
  • wfs/src/main/java/org/geoserver/wfs/xml/NameSpaceTranslator.java (GEOS-5455)
  • wfs/src/main/java/org/geoserver/wfs/JoinExtractingVisitor.java - missing header
wms
  • wms/src/test/java/org/geoserver/wms/WMSFilterMosaicTestSupport.java - missing header
  • wms/src/test/java/org/geoserver/wms/decoration/ScaleRatioDecorationTest.java - GeoTools LGPL header (GEOS-5468)
  • wms/src/test/java/org/geoserver/wms/map/quantize/ColorIndexerTest.java - GeoTools LGPL header (GEOS-5468)
  • wms/src/test/java/org/geoserver/wms/wms_1_1_1/LayerGroupWorkspaceTest.java - missing header
  • wms/src/main/java/org/geoserver/wms/map/quantize/ColorIndexerCRIF.java - GeoTools LGPL header (GEOS-5468)
  • wms/src/main/java/org/geoserver/wms/map/quantize/ColorIndexerOpImage.java - GeoTools LGPL header (GEOS-5468)
  • wms/src/main/java/org/geoserver/wms/map/quantize/ColorIndexerDescriptor.java - GeoTools LGPL (GEOS-5468)
Jody Garnett
I stand corrected …
Ben can you tell me where the test data for data/app-schema comes from?
https://github.com/geoserver/geoserver/tree/master/data/app-schema-tutorial
I have been creating a README.rst to capture this information, just so we have something readable in github to point to.
Jody Garnett
On Sun, Nov 18, 2012 at 3:56 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Do we have a list of those files? Wondering if we can just rewrite them so that we don’t
have a source code base with mixed licenses, or anyways we if we can find some library
providing them
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
providing them
Sure - the files were referenced on that page - here they are…
Apache 2.0:
GEOS-5470 SetCharacterEncodingFilter provided under Apache License 2.0
GEOS-5454 RewindableInputStream borrowed from Xerces
Apache 1.1:
GEOS-5453 Use of Apache License Version 1.1, need Apache license in jar and docs
And one odd duck:
GEOS-5460 GZIPResponseStream freely use commercially and non-commercially
Jody Garnett
Btw… I would let providence alone, seems like a good gal that does not need review.
Provenance, on the other side… :-p
Ing. Andrea Aime
@geowolf
Technical Lead
Jody, there are three data files:
(1) data/app-schema-tutorial/workspaces/tut/tut_RoadSegment/tut_RoadSegment.properties (added by Rob Atkinson)
is identical to GeoTools modules/extension/app-schema/app-schema/src/test/resources/test-data/RoadSegments.properties . It also looks very similar to GeoServer src/main/src/test/java/org/geoserver/data/test/RoadSegments.properties, having different fields and types but similar values. In both projects try:
find . -name "*.properties" -exec grep -H "Dirt Road by Green Forest" {} \;
I am pretty sure the GeoTools version is older and, as LGPL, can be included in GeoServer without problem. I do not know the original authorship. Rob Atkinson, can you comment?
(2) data/app-schema-tutorial/workspaces/gsml/gsml_GeologicUnit/gsml_GeologicUnit.properties and
(3) data/app-schema-tutorial//workspaces/gsml/gsml_MappedFeature/gsml_MappedFeature.properties
are derived from a test data set provided by GeoScience Victoria, a branch of the Department of Primary Industries of Victoria, Australia. This is the same source as the refdataset jar deployed by Victor on the osgeo maven repo and used in app-schema-test online reference data tests (but not distributed with GeoServer). As a derived product:
"The only requirement is that you acknowledge the Victorian Department of Primary Industries as the source of data from which the product was constructed." (Linda Bibby, Manager, Geoscience Information, GeoScience Victoria, Department of Primary Industries)
We do not do this for the tutorial as it uses only a minuscule, much-edited subset of an older version, but as a matter of principle we should credit DPI Vic with something like:
"Derived from data provided by the Victorian Department of Primary Industries."
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
On Mon, Nov 19, 2012 at 8:54 AM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
(1)
Mumble… wondering, wasn’t this part of the OGC CITE WMS test data set?
Ing. Andrea Aime
@geowolf
Technical Lead
Perfect Ben can you add that to a Readme.rst and we can get on with life :slight_smile:
Jody
Sent with Sparrow
(1)
find . -name “*.properties” -exec grep -H “Dirt Road by Green Forest” {} ;
(2)
and
(3)
“The only requirement is that you acknowledge the Victorian Department
constructed.” (Linda Bibby, Manager, Geoscience Information, GeoScience
“Derived from data provided by the Victorian Department of Primary
Industries.”
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com4…>
Software Engineer
<Ben.Caradoc-Davies@anonymised.com <mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
     > Ben can you tell me where the test data for data/app-schema comes
    from?
    (1)
Mumble... wondering, wasn't this part of the OGC CITE WMS test data set?
Thanks! You are correct. I'll add that to the app-schema-tutorial README.rst.
Kind regards,
Software Engineer
Done:
Software Engineer
