I'm seeing a lot of local build failures with the above error - can any one
tell me what I'm missing? They don't seem to be affecting travis so I guess
I'm missing something locally.
Ian
Ian
Hi Ian,
this is part of new imageio-ext-1.3.3.
GT and GS master should depend on it since yesterday.
Any chance that you have some mixed out of sync jars?
Please, let me know.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
