one thing tha bothers me about the new UI is that all
the ajax-y action give the user no actual feedback on
the fact the call is running, doing something.
Then I stumbled into this blog:
http://blog.ehour.nl/index.php/archives/18
(see the very bottom of it).
Long story short, it's not hard to show a spinning
animated GIF somewhere in the UI (maybe play an
animation with the very GeoServer logo?).
But we'd have to provide a GeoServer specific subclass
for links and buttons that adds the callback
decorator and replace the usage in all the UI
code.
What do you think?
Andrea Aime
OpenGeo - http://opengeo.org
Seems worth the work to me. This would apply to any AjaxLink we link we use? I know that there is code that uses AjaxLink vs AjaxButton and vice versa. Would this apply to both? Or do need to choose one over the other?
Andrea Aime wrote:
code.
What do you think?
Justin Deoliveira
It would apply to both. Actually, to anything that has an ajax behavior
attached to it.
Andrea Aime
attached to it.
Cool, i would say open a jira and file it under the usability and improvements issue?
Justin Deoliveira
Hi Andrea,
I do very much share the concern. Yet, earlier this month I tried another way of doing so (you gave me the link to the example), which I accidentally committed and then reverted. So we have a diff:
<http://fisheye.codehaus.org/changelog/geoserver/?cs=12533>
Look at the diff, the only thing needed would be to replace the "<h1>Can't touch this</h1>" by the actual animated "processing" icon.
Now, this is a lot less work, but I'm not sure how the other approach might be better. Perhaps you know since you're the one that got to both solutions?
Gabriel
Andrea Aime wrote:
code.
What do you think?
Gabriel Roldan
These are the direct links to the changes:
<http://fisheye.codehaus.org/browse/geoserver/trunk/src/community/web2/core/src/main/java/org/geoserver/web/GeoServerBasePage.html?r1=12532&r2=12533>
<http://fisheye.codehaus.org/browse/geoserver/trunk/src/community/web2/core/src/main/java/org/geoserver/web/GeoServerBasePage.java?r1=12532&r2=12533>
Gabriel Roldan wrote:
Hi Andrea,
Gabriel
Andrea Aime wrote:
code.
What do you think?
Gabriel Roldan
Gabriel Roldan ha scritto:
Hi Andrea,
Actually I thought the one I gave you the link for was setting a veil
on top of the ajax component, did not realize it was working also
page wide.
So yeah, it looks like a winner
Andrea Aime
