Hey all,
In order to simplify deployment of OpenLayers applications on top of
GeoServer, I would like to create a community module on trunk that
mimics the proxy.cgi script that is often used with OpenLayers.
Basically, this script accepts a URL as a query parameter and forwards
the request to another server, allowing OpenLayers applications to load
feature data and other resources from servers other than the one hosting
the application. The script would eventually allow for host-based and
mimetype-based filtering of proxied requests to help admins prevent
abuse.
If there are no objections I'd like to get this into SVN later today.
David Winslow
OpenGeo - http://opengeo.org/
No objections here. +1
David Winslow wrote:
Hey all,
abuse.
David Winslow
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited
royalty-free distribution of the report engine for externally facing server and web deployment.
http://p.sf.net/sfu/businessobjects
Geoserver-devel mailing list
Justin Deoliveira
David Winslow ha scritto:
Hey all,
abuse.
No objections, but one curiosity. How is this better than the "www" folder provided in the data dir (that allows for static file publishing?)
Andrea Aime
The proxy is not for hosting the application itself, but allowing it to
circumvent the same-origin policy imposed on JavaScript applications by
web browsers (JavaScript applications cannot make HTTP requests to
domains other than the one hosting the page they run in). This is only
needed for OpenLayers applications that need to read XML data from
third-party servers.
For the curious, more on the same-origin policy:
http://en.wikipedia.org/wiki/Same_origin_policy
David Winslow
> Hey all,
> abuse.
Okay, a basic proxy restlet has hit trunk. I had to make a few
modifications to the rest module to get it to compile, but have not
committed these. A patch is attached if someone (jdeolive, maybe?)
would care to review. I guess I'll need to update the code anyway when
the changes from 1.7.x are ported forward anyway so perhaps it's not
that important that this compiles right now.
David Winslow
David Winslow
> > Hey all,
> > abuse.
> Cheers
> Andrea
(attachments)
rest.patch (3.49 KB)
I am curious as to how these compile? I guess you had to add dependencies on all the service modules? On 1.7.x the W*SConfig classes were all in main, but in trunk the W*SInfo classes are in the respective service modules.
David Winslow
David Winslow
Hey all,
abuse.
Justin Deoliveira
That patch includes all the changes I needed to get things to compile in
eclipse and with maven. I guess the service modules get pulled through
some dependency?
David Winslow
service modules.
> David Winslow
>> David Winslow
>>>> Hey all,
>>>> abuse.
>>> Cheers
>>> Andrea
>> _______________________________________________
>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
I just skimmed through it, and maybe I am missing something. But it sounds and looks like by default it allows anyone to go anywhere?
I realize we will not be shipping this by default, but I don't think that's a good idea anyway. We should include a regex filter from the start (can be simple, set in an environment variable) and have the default configuration deny all requests. Otherwise we will be tempting spammers and script kiddies, and if you pay for excessive bandwidth it can get ugly quite fast.
-Arne
Hey all,
abuse.
David Winslow
You're not missing anything, the proxy service I committed yesterday is
a completely open proxy (well, it only allows GET requests to anonymous
users, but that's more or less an accident with the default permissions
on restlet extensions). Alan will be starting work on regex whitelists
for hostname- and mimetype-based filtering later this week.
David Winslow
On Wed, 2009-06-17 at 12:17 -0500, Arne Kepp wrote:
-Arne
> Hey all,
> abuse.
> David Winslow
