GeoTools / GeoServer Meeting 2018-02-20
## Attending:Torben Barsballe
Andrea Aime
Jody Garnett
Agenda- Moving meeting time
OSX build server
GSIP-166 (WMS time nearest match)
Java jigsaw Compatibility
Previous Meetings Actions:
Ben: ask on mailing list for volunteer for 2.11.5. (DONE)
Torben: propose GeoTools migration steps and refactoring for supporting Java “jigsaw” and future. (DONE - https://github.com/geotools/geotools/wiki/Java-9-Compatibility)
Moving meeting time
Just Andrea and Torben this morning, early time for BC.
Should we move it one hour later? No objections here
OSX build server
The mail “GeoServer releases: no more OSX installers?” on the list pretty much sums it up.
First, note, had to move dead GSIPs out of the way:
https://github.com/geoserver/geoserver/wiki/Proposals
Proposals moved to deferred/rejected:
Nearest match proposal: https://github.com/geoserver/geoserver/wiki/GSIP-166
Discussion, walkthrough, … (see proposal and get back to list)
Quick turn around time, take to email
Proposal listing the various bits, broken up into smaller items: https://github.com/geotools/geotools/wiki/Java-9-Compatibility
Action:
- Take this to a technical debt page, it is not acting like a proposal
Notes:
GeoTools supports Java 9, with documented command line options
Road map planning:
Java 9 is currently out, next (GeoTools) release has a way to support it
Java 10 is out in march! “Java 18.3”
Java 11 is out in september ← “Java 18.9” this is the LTS we’re targeting for GeoServer
real minimal, one projection with bbox filter
OSGeo code sprint Jody
cannot start on module system until dependencies are not modules, or it uses jar name (so it would change each time we update the jar version).
we can work on refactoring core library so no duplicate packages
foss4gna code sprint anyone?
idea: mass format all the branches - it will hide history but github for example has nice way of going back on blame
checkstyle maven profile for build server / travis?
could run the check in parallel on the build server?
skip emf auto-generated modules
need a proposal for this one
inspiration: QGIS has formatting built into their build process
jai-ext / raster processing engine
Q: could we just relicense the JAI interfaces + planar images?
Anything to focus on for testing:
Nice UI improvements
GWC change proposal is in the beta, make this a priority for release announcement
Any issues to fix for release:
- none known
