Attending
Torben Barsballe
Ian Turton
Andrea Aime
Nuno Oliveira
Jukka Rahkonen
Agenda- OSGeo budget
OSGeo code sprint - JAI
CITE tests
Release Volunteers for 2.14.2, 2.15-RC
Miscellaneous jenkins / repo follow-up
QA work
Style conversion in GeoServer UI
Actions from Last Meeting- [Andrea] Ask on list for 2.13.4 release volunteers [DONE]
Actions- AA: ask for 2.15
Torben: Try rebooting Jenkins to help with file limit
Torben: Add email notifications to the Java11 jenkins builds [DONE]
OSGeo Budget- Jody suggestion: OSGeo code sprint to work on JAI. GeoSolutions & Astun participation in Minneapolis unlikely.
CITE tests, most pressing for Andrea and Ian (Andrea wondering about not participating to other code sprints until it’s done)
Deprecated code removal, so that we can add a rule to disallow it and stop people from deprecating without removing call points to the newly deprecated stuff.
Removing EMF and replacing with normal javabeans? (and update the XSD bindings… btw, fast reflection using invokedynamic here: https://medium.freecodecamp.org/a-faster-alternative-to-java-reflection-db6b1e48c33e )
GeoWebCache to have a proper release build on Jenkins?
GeoWebCache pimp up, add features to give the project some life and make more people familiar with the codebase
2.14.2: Torben volunteers
2.15-RC: No feedback on M0 so far, push back one week, and then release 2.15 in Feb as planned. Ian to release GT/GS, Andrea to help with GWC
Module Maintainers
Try to generate a list of module maintainers from pom.xml and module proposals. This will allow us to keep track of status of modules as people come and go from the projects.
Jenkins / Travis / Repo
Travis: Failing on gt-opengis (?) with 10 minute timeout, gt-opengis starts working and never installs while other modules keep on running in the other builder (T2). Andrea has made some changes to the travis.yml, hopefully it will help, keep an eye on it.
Jenkins: Too many open file - nofile to 2048 helped a little, reboot Jenkins?
Reminder that repo.boundless.com is going offline for maintenance this weekend, see list message last week.
QA work
PMD / ErrorProne. Questions, concerns? You can also follow up on list.
And yes, if one introduces a failure, Travis build is going to complain, and Jenkins notifications are going to be enabled too (by Torben).
SLD → CSS conversion incoming thanks to “Flat”, non cascading mode.
So, idea, unlock the dropdown for style conversion for existing styles when supported, and notify the user that nothing will be saved. Or use the copy action? Maybe both.
