[Geoserver-devel] PSC meeting notes, August 18th 2020
GeoTools / GeoServer PMC meeting - 2020-08-04Attending
Andrea Aime
Ian Turton
Gabriel Roldan
Jody Garnett
Kevin Smith
Actions from last meeting:
   [Done] Andrea: Ask on devel list for 2.16.5 release manager
   [Done] Torben: Ask Tom again about domain name transfer
Agenda
   Cloud Native GeoServer
   2.16.5 Release
   2.18-RC release
   OSGeo AGM slides
Actions
   Jody: AGM slides for GT, GS and GWC
   Andrea: 2.18-RC release reminder, Sept 1st
RnD into:
   demo of a “microservices” approach
      split into individual components without extra spring definitions
      example: wms depends on wfs (for GML output format)
   spring-boot
   filesystem-less approach:
      jdbcconfig/jdbcstore
   catalog change events - to drop caches etc..
      jms-clustering module: considered
      spring cloud bus: project wrapper around ...
Results:
   Basic architecture working
   Next step: going to write up docs / architecture to share
   Work with community on where to work
      community modules
      perhaps a new repo in the geoserver github group
Q: Can spring cloud bus use aws events?
A: Perhaps: https://cloud.spring.io/spring-cloud-aws/spring-cloud-aws.html
Q: Stratus had a significant fork of GWC to store configuration into Redis?
How about this ...
A: No approach yet for GWC, focused on what could working with core OWS
services
Q: Web ui?
A: Thinking of using spring-session?
   Note this is not enough, wicket has its own session handling, … in memory
   Need to think wicket storage session, … not as easy as it seems :stuck_out_tongue:
   UI on single node: a reasonable approach …
OSGeo AGM Slides
Details:
   Annual General Meeting (AGM)
   Thursday September 10th 2020 from 18 UTC till 20 UTC
Slides:
   OSGeo AGM 2020
   <https://docs.google.com/presentation/d/1C6llSnWZ28c2aWQgttPiOnoo6dttdqKg07ugU_yr6Uc/edit#slide=id.p4&gt;
   (slides)
   1 min per project!
Updates:
   ogcapi improvements
   cite test efforts, underway ....
   announce cite test passing effort for … Q4?
   migration os osgeo nexus repository
   migration to build.geoserver.org instance
Actions:
   Jody: GeoServer Slides
   Jody: GeoTools slides
   Kevin: GeoWebCache
2.16.5 Release
Ongoing. 22.5 released.
   underway
   note: No gwc changes?
      Ensure GeoServer does not pick transitive dependency
      Try it and double check the jars ...
2.18-RC release
Jody setup on the Release Schedule
   September 1st!
   note: Remove documentation assembly workarounds from release scripts now
   that 2.16.x is EOL.
Discussion:
   Cancel button is not a button? Yes it is styled like a link now on
   purpose to make it more “visually distinct”
PR we want in:
   [GEOS-9672] consistent use of ok and apply for WPS configuration
   <https://github.com/geoserver/geoserver/pull/4384&gt;
      useful for consistent strong visual update :slight_smile:
   GeoJson cleanup? Ian is considering it
   GeoTools warning cleanup? Won’t be ready in time ...
Action:
   Andrea: Send a “last call” message to the email list!
