GeoTools / GeoServer PMC meeting - 2021-02-02Attending
Torben Barsballe
Jody Garnett
Kevin Smith
Jukka Rahkonnen
Nils Bühner
Andrea Aime
Alessandro Parma
Actions from last meeting:
[IDone] Torben: Write dependency backport details a bit more clearly in
our developer guide
Agenda
1.
Module graduation GSIPs
2.
Terrestris graduation to “experienced provider”
3.
Docker image
4.
QA effort update
5.
Java 11 indriya upgrade
Actions
https://github.com/geoserver/geoserver/wiki/Proposals
GWC-S3: https://github.com/geoserver/geoserver/wiki/GSIP-193
Docs look good!
Keep in mind download directive when migrating docs to extension.
Params-extractor module:
https://github.com/geoserver/geoserver/wiki/GSIP-194
Q: Does this get added as a service page (under WMS?) or an extra tab
on the WMS service page?
A: Not clear for docs, … okay it shows up in settings
Incoming: WPS download
https://docs.geoserver.org/stable/en/user/community/wps-download/index.html
Discussion on download animation etc...
Incoming: WMTS multidim:
https://docs.geoserver.org/stable/en/user/community/wmts-multidimensional/index.html
Keep in mind:
When graduating PR and moving docs to extension, change from
`download_community` to `download_extension` directive (which adjusts link
between latest/stable/maintenance), see config.py for details
<https://github.com/geoserver/geoserver/blob/master/doc/en/user/source/conf.py#L117-L119>
OGC API Modules - Graduation Discussion (Maybe for GS 2.20?)
How to fulfil criteria of 3 production sites?
Waive this requirement since this is new functionality? No.
Not many people are using these modules yet, and not in production
Wait until someone is actually using these in production; re-evaluate
in the future
Clients for ogc-api-features?
Ian started one, ogr started something ...
Reference: http://geoserver.org/support/
Email: has a solid list of activities, ...
Q: What is an experienced provider?
Jody is of the strong opinion that must contribute to sustainability
(not only user / customer focus).
Andrea: points out this is not clear on our website ...
Actions:
Jody: Propose clarification of definition, and contact existing
experienced providers
Q: What contribution have they made to GeoServer / GWC or GeoTools?
Goal with experienced providers is to recognize folks that have been
through the GSIP or proposal process to contribute functionality to the
code-base (rather than just consulting on setup GeoServer and understand
how to use it).
Community module:
https://docs.geoserver.org/latest/en/user/community/geostyler/index.html
https://github.com/geoserver/geoserver/pull/3607
https://github.com/geoserver/docker/pull/1
Can this go to extension? No, does not really look maintained. See
history:
https://github.com/geoserver/geoserver/commits/master/src/community/geostyler/src/main
https://www.terrestris.de/en/openstreetmap-wms/ demo?
502 Bad Gateway!
Aside: This would be great opportunity for osgeo.org website (which
needs a map done by osgeo software)
Q: Can bug fixes count?
Perhaps … links?
Q: Security maintenance signup?
Yep that is a solid
Docker image updates
Two PRs for docker image, how do we want to continue?
Different focuses, dockerfile to extend adjust vs docker image to use right
away.
Q: Maybe it’s possible to merge them?
Perhaps as a build option?
Please start with one, and ship to the public!
And then improve over time
March 1st Release Candidate ← opportunity !
Discussion:
Discuss on pull request, or issue
Perhaps make a wiki page or github issue to compare the two approaches
Docker wiki page is empty : https://github.com/geoserver/docker/wiki
QA effort update
gt-http client is merged (yay) so pmd fixes can go ahead…
1000+ files modified <https://github.com/geotools/geotools/pull/3311>,
merged yesterday
Varargs: https://github.com/geotools/geotools/pull/3317
We have very few array of primitives (only real problem around)
Jody really likes the readability / usability improvement here
anonymous inner class migration to lambdas:
https://github.com/geotools/geotools/pull/3318
https://github.com/geoserver/geoserver/pull/4656
Mixed: when it is good it is good, when it is bad it is confusing
Feature visitors is much better
File filters / filename filters / Runnables also great
Wicket tend to almost more confusing
Bradh: This looks like it never worked
Two modules removed:
gt-arcsde
gt-validation
Note:
gt-graph was a lot of work to update, is it still used now that
gt-validation is removed? …
Graph visitors look better with lambdas
This work can be done, .. but is hard to find time.
https://github.com/geotools/geotools/pull/3232
https://github.com/unitsofmeasurement/indriya/pull/317
Fixe is merged, waiting on release
These unit libraries are not always setup to be extended (why not?)
To prevent this kind of error, can we set up java 11 docs to use the module
system?
This would catch most of the problems?
Maven “toolchains” can also be setup to run tests with different JDK
versions in a single build
https://github.com/AdoptOpenJDK/jsplitpkgscan-maven-plugin
