GeoTools / GeoServer PMC meeting - 2024-02-27Attending
Peter Smythe
Jody Garnett
Torben Barsballe
Andrea Aime
Jukka Rahkonen
Kevin Smith
Actions from prior meetings:
[Done] Peter: create a sed script to fix email addresses in sourceforge
lists export
[Blocked] Jody: setup a github workflow to use dependency submission API
<https://docs.github.com/en/code-security/supply-chain-security/understanding-your-software-supply-chain/using-the-dependency-submission-api>
Agenda
Discourse
2.25-RC Release coordination
Markdown migration update
Coordinated Vulnerability Disclosure stuffs
WFS GetFeatureResponse API change
Making ENTITY_RESOLUTION_ALLOWLIST default
Actions
Discourse
Peter was able to send an updated mbox to Vicky, we await a test instance.
Wider OSGeo response has been:
finally!
huh why I like lots and lots of email
Jody is set to release this week - thanks for everyone reviewing.
Anything waiting:
Jody owes Niels a review
Gabe large catalog load improvement is almost ready:
https://github.com/geoserver/geoserver/pull/7421
Entity Resolution Allow below
Stream of MapML pull-requests coming including vector tiles coming in
Q: Is the mkdocs change needed for the release candidate?
A: It would be nice to complete this and push out along side 2.25.0 release.
Q: Can alex help?
A: Release candidate is a poor introduction, but Jody will ask for help
writing the release announcement.
Status and collaboration opportunities here:
https://docs.google.com/spreadsheets/d/1HMqUpTirEwwSQfeNYikPjU0aFMl0-W4Xj44cg8V_VJA/edit#gid=0
List-table issue, Jody working on it. Looking good according to Andrea:
https://jodygarnett.github.io/geoserver/data/raster/imagemosaic/configuration/#index-and-configuration-file-creation
If you want to see markdown check branch (not a space for collaboration,
just a way to check the current progress in markdown syntax):
Checkout:
https://github.com/jodygarnett/geoserver/tree/mkdocs-preflight-test
Follow instructions here
https://jodygarnett.github.io/translate/translate/migrate/
todo: Jody can un gitignore the docs folder so people can see
Peter needs access to the vulnerabilities page (done)
Set to announce alongside 2.25.0 release.
See https://github.com/geoserver/geoserver/pull/7444
Jody would like this for release, contains update instruction note.
https://github.com/geoserver/geoserver/pull/7428
Andrea has some feedback:
if you do not return the supplier the api change will be minimal
