[Geoserver-devel] PSC meeting notes, January 21st 2020
GeoTools / GeoServer PMC meeting - 2020-01-21### Attending
Kevin Smith
Andrea Aime
Jody Garnett
Jukka Rahkonen
Actions from last meeting- Jody: Ask on user/devel Should we move Import Data to the tools page? [DONE]
  • Jody: Ask on user list for someone to test windows URL validity [DONE]
  • Torben: Remove ImageMosaic test workarounds for Mac [DONE]
  • Andrea: Updated release schedule - 2.17.0 in march [DONE]
  • Jody: Propose GSIP 184 MB Style to list
  • All: Vote on GSIP 185 Web Resource
  • Fernando Miño: Start email thread for voting on GSIP 183 [DONE]
Agenda- Proposal review
  • Maven Repo Clean up
  • Release update
  • Downgrading ArcSDE to community module
  • More GitHub actions/builds
  • Chatter
Actions- All: Please reply to MBStyle Graduation geotools thread
  • Jody: will tighten up the javadocs “SimpleFeatureCollection house rules”
  • Andrea: to clean up the 22.3 artifacts from the OSGeo repository (may need a follow-up on Boundless repo though)
  • Gabriel: move ArcSDE to unsupported
Proposal review
Review of:
Retyping extension for ResourcePool: upgrade to GSIP?
  • Jody sent email
CLA relaxation rules GSIP needs to be written.
Maven Repo Clean up
Jody / Andrea ssh access to clean up:
  • 22.2-mistake (cleaned)
  • 23.0 - accidentally released
Release update
Please test!
web-app jar size - see email (jody and gabriel have ideas)
Three problems:
  • Build plugin build-helper-maven-plugin is broken:
  • Uploading war twice → as JAR and WAR
  • JAR is empty (wanted for downstream web-apps)
  • WAR is deployed (we did not want to take up the space)
GEOS-9462, Gabriel volunteered
Needs to be done in GeoTools as well.
AppVeyor build to be removed if the GitHub one works better.
OSX/Windows builds available on GeoServer as well.
Bonus: Integration build GT → GWC → GS
https://github.com/geotools/geotools/pull/2761
  • github action only able to restart in case of failure
Chatter
Code freeze …. one month away.
Jody/Andrea discussing DefaultFeatureCollection requiring:
  • SimpleFeatureCollection requires getSchema() to document all contents
  • Javadoc: Access to “simple” Feature content where each feature has the same SimpleFeatureType.
  • A new base class is needed for mixed content
  • GenericFeatureCollection - copy the code to implement FeatureCollection
  • Allows mixed content
  • Only attribute name based access
  • DefaultFeatureCollection extends this to implement SimpleFeatureCollection
  • Adding column index access
  • Action: Jody will tighten up the javadocs “SimpleFeatureCollection house rules”
Ian working on:
  • GeoJSON improvements
  • GML2/GML3
  • See axis order audit here axis ordering
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Maven Repo Clean up
After the meeting Andrea was able to clean up the geotools repo, I manually cleaned up repo.boundlessgeo.com this evening.
