GeoTools / GeoServer PMC meeting - 2021-03-30### Attending
Torben Barsballe
Andrea Aime
Kevin Smith
Jody Garnett
Alessandro Parma
Actions from last meeting:- [DONE] Move meeting time discussion to mailing list
Agenda1. CITE Activity
Docker Update?
foss4g presentation reminder
POM and XML formatting update
Commercial Support Categories
Actions-
CITE Activity
So exCITEing!
Andrea is reviewing from the point of view of running the tests locally.
GeoServer from IDE, Docker from PR, and test -
Builds are up and running https://build.geoserver.org/view/testing-cite/
Mandatory ones (from before) are there
The new nice-to-have ones are created, but it is a new design so we are not sure how to run
Q: osgeo repo upload?
- Discussion on managing gsbuild credentials for repo
Discussion on how the jobs are shown?
A single pass/fail job is not so useful (as we expect some protocols to fail until we have budget to address)
We would like result for each protocol being tested
About team engine source code:
Fork repository for the docker image for the team engine? Where to put it …
There is already a fork in the geoserver group https://github.com/geoserver/teamengine - wrong repo, need teamengine-docker
Action: Try and contribute upstream … (we can fork as a backup plan)
Docker Update?
Any 2.19.0 docker ready to go?
https://github.com/geoserver/docker is still empty?
Attempt to compare resulted in … no discussion
It seems like some good ideas in each one so a “merge” is going to happen!
Q: Can you make a 2.19.0 with release, and then merge in new features?
No comfortable calling it official until merge …
Deadline extended to April 18th
Submitted quite the number of presentations already
State of GeoWebCache! ← anyone else want to co-present? Kevin
Jody has a few more to submit … “geoserver orientation”
Gabe is presenting “cloud first geoserver”
Another week, another new pom formatter?
No:
GeoServer: landed on active branches!
Main geotools: please check PR preview https://github.com/geotools/geotools/pull/3422
Main geowebcache: please check PR preview https://github.com/GeoWebCache/geowebcache/pull/940
Jody this look much better!
Tentative PR for acegi to preserve the white lines: https://github.com/acegi/xml-format-maven-plugin/pull/31 - waiting on feedback (none so far).
Revelc bug report: https://github.com/revelc/formatter-maven-plugin/issues/433
QA activities discussion:
From InilliJ nearing an end! Congrats Andrea! (not finding more checks that can be coupled with a PMD/Checkstyle rule, in general, an automated on)
StringBuilder or StringBuffer (good in a loop) vs concatenating strings (JVM decides, better for simple concats, not in a loop)
Gabe proposed looking at method length. ← any update Gabe?
Other fixes are just work and checking our own API:
Jody would like to address startup warnings
Layer Preview is filling up the logs …
See https://github.com/geoserver/geoserver/wiki/GISP-199
Discussion on community participation, make sure it is covered. Changed to “sustained community participation”
Action: Jody to send this GSIP to the email list!
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
