GeoTools / GeoServer PMC meeting - 2022-09-13Attending
Torben Barsballe
Jukka Rahkonnen
Kevin Smith
Jody Garnett
Andrea Aime
Actions from prior meetings:
Volunteers for maintenance and RC releases [maintenance underway, RC
pending]
Jody: Home Page GSIP available as 2.22-M0 - send to user list for
testing [Feedback received, still needs to be addressed and merged]
Torben: Switch GS + GT docbuild to new server - [GS swapped over, GT not
yet].
Agenda
1.
Docs
2.
Welcome Page
3.
Release Planning
4.
GWC Discussion
5.
PR Roundup
Actions
Docs
https://docs.geoserver.org/ - has a list of links to prior docs that are
broken?
Torben is thinking of bulk download from SF and unzip?
Just drop links to prior release?
action: Jody has done this now (can be a temporary measure).
Link to the SF downloads for docs of prior versions? Quick search and
replace with regex (so not quick at all actually…)
https://github.com/geoserver/geoserver/blob/main/doc/en/index.html
main doc build will "publish" this
Welcome Page
Feedback:
Reload the entire page? Yes I am sorry perhaps improve later
But the URL changes so that is nice to link to workspace service
Service URLs not quite right
WMTS Capabilities bugs found?
Address feedback and merge?
Release Planning
2.20.6 release
Underway!
GT (you are here) → GWC → GS
blocked on regression: https://osgeo-org.atlassian.net/browse/GEOS-10636
Login is broken after upgrade to 2.22-M0 and 2.21.1
2.22-RC
volunteer still needed
blocked on welcome page above
GWC Discussion
WMTS
Turn off global services → boom!
mapped to global wms, not workspace wms so not working
URLs manglers
WMTS not respecting CATALOG hide mode
Did you enable security integration? No I did not ← ha ha ha
Can this be on by default?
PR Roundup / Proposals
pgraster
license example?
https://github.com/geoserver/geoserver/tree/main/src/community/gsr
LICENSE.md It is a BByA license?
NOTICE.md is the the actual license file
OAuth2 Bearer Tokens
https://github.com/geoserver/geoserver/pull/6167 OAuth access tokens
Anyone else want to review? Marco/Alessio …
Ask to run tests before merging (there are other tests extracting
credentials)
Proposal / Java 8
https://github.com/geoserver/geoserver/wiki/GSIP-215
Most were fine with changing GeoServer 2.23-RC in Feburary
Revisit after 2.22 branches off
User list feedback … replied to Jody directly. Teams using Java 8 do not
have any showstopping reason preventing Java 11
CSS Cleanup
https://github.com/geoserver/geoserver/wiki/GSIP-213
No update, will check-in, …
Vector Mosaicing Data Store
https://github.com/geotools/geotools/pull/3998
Discussion on the RnD topic
