GeoTools / GeoServer PMC meeting - 2022-05-10Attending
Torben Barsballe
Stacy Acosta
Jody Garnett
Andrea Aime
Jukka Rahkonen
Actions from prior meetings:
AA: review Jody’s Log4j PR
AA: setup HTTPS and www.geoserver.org (AA to talk with SAC)
Agenda
1.
GeoServer Domain
2.
Build server care and feeding and upgrade
3.
GeoServer 2.21-RC
4.
GeoServer 2.21.0 release
5.
FeatureCollection.query(Query)
6.
GeoTools Extra Samples
Actions
andrea: email devel list for release volunteer
torben and jody: try and clean up a committed m2 repo
GeoServer Domain
Action follow-up for setup HTTPS and www.geoserver.org (AA to talk with SAC)
We require zone records to do this - follow-up with Planet again.
Also would like geowebcache domain
Ran out of disk space, see gitter for troubleshooting
each workspace is taking 1-2G in space (including doc builds)
2.21-M0 tag includes an m2 repo - making every git checkout massive
Force push on a tag (so not terrible rewrite of history)
action: torben and jody to try the above out (breakout session)
Jody proposed AX101 machine for new build server
Jeroen and Simone have offered to split costs
New Machine AX101 below proposed:
€65 AX61-NVME <https://www.hetzner.com/dedicated-rootserver/ax61-nvme>
CPU: AMD Ryzen 3900 12 cores / 24 threads
RAM: 128 GB DDR4 ECC
Disk: 2x 1.92 TB NVMe SSD
Bandwidth: 1 Gbits, Unlimited
€115 SYS-6-SSD-256 <https://www.soyoustart.com/it/offerte/2201sys062.xml>
CPU: AMD Epyc 7351p 16 cores / 32 threads
RAM: 256GB DDR4 ECC 2400MHz
Disk: SoftRAID 2x512GB NVME SSD
Bandwidth: 250 Mbps Unlimited
€113 AX101 <https://www.hetzner.com/dedicated-rootserver/ax101>
CPU: AMD 5950X 16 cores / 32 threads
Disk: 2x 3.84 TB NVMe SSD
€136 SYS-7-SSD-128 <https://www.soyoustart.com/it/offerte/2201sys070.xml>
CPU: AMD Epyc 7451 24 cores / 48 threads
RAM: 128GB DDR4 ECC 2400MHz
Disk: SoftRAID 2 x 512GB NVME SSD
€165 AX161 <https://www.hetzner.com/dedicated-rootserver/ax161> (was €131
base + €33 for disk)
CPU: AMD 5950X 32 cores / 64 threads
Bandwidth: 1 Gbits
€168 SYS-7-SSD-256
GeoServer 2.21-RC
Release Candidate is out
https://geoserver.org/announcements/2022/05/09/geoserver-2-21-RC-released.html
broken link noticed (new WPS and KML output settings, external output
directory)
we want to thank implementer / customer for the final announcement
please take care with issue FixedFor and provide any indication of what
was fixed
Asked the user list to test, need some testing please
This is a really good release, love feature type customization.
We need a volunteer
https://github.com/geoserver/geoserver/wiki/Release-Schedule
This is just a normal release, all the work for new branches is the RC
Andrea is asking the devel list for a release manager
Round up of known issues:
Dispatcher is willing to log request body? And the new request header
settings duplicate this functionality. Joseph is going to make a PR to fix
before release
Anything else? Please test log4j configurations
A couple hard coded fonts in the UI to cleanup
GeoTools has some hooks for optimizations:
Propose FeatureCollection.query(Query)
Feature collection has optimizations for Filter, Sort (single
attribute), …
intended to be a fluent api for production of an internal query
Most of the wrappers are doing one thing in memory, and lose track of
the query.
Andrea will make a proposal, the goal is the ability to pass
FeatureCollection around.
GeoTiff Extra Samples
GeoTiff extra samples field bug (PR pending)
https://osgeo-org.atlassian.net/browse/GEOT-6452
Stacy working on creating a test case
The only currently available data source that reflects the issue is
internal proprietary data and not suitable for inclusion in a test case.
Consider using gdal_create can often be used for creating a test file that
is alike from the essential parts but with dummy contents
https://gdal.org/programs/gdal_create.html
An “easy” method would be to use option -if for "input file" to copy the
structure of a source file
The extra samples flag is a Tiff tag - we could also use -mo
{TAGNAME}=VALUE to add a TIFFTAG_EXTRASAMPLES tag to a test file manually.
EULA sent to jody, he could agree to access the sample data, and then
process as above.
Would that be sufficient for the Planet team? The new file would only
contain the tiff tags …
The issue appears to be due to the pixel data, rather than just the
metadata.
Extra pixel with RGB information, not part of A, extra data that must be
present and remain 0 (not part of RGB / A).
Follow-up on the prior discussion as to location of the fix - it actually
needs to be in imageio-ext
Chit Chat
Niels proposal is stuck:
Has two options, get a signed CLA, or proceed without one (the module
then has some more restrictions as found code). Not a big deal …
Code sprint?
Bolsena! Invitation is open
Want to do a CITE sprint? or rebook CITE sprint … (was proposed as thurs
for a month)
Blocked on build server …
GeoConnections:
Opportunity sent to email list by Peter Rushforth, good candidate for
ogcapi, MapML, …
Java 11 as the minimum supported version?
Some concerns …
Java 8 lasts longer 2026
Java 11 lasts until Java 2024
Java 17 lasts until 2026
Jakarta? Adjacent concern …
ImageN - may needed for Java 17 (replacing JAI)
Many libraries already switching to Java 11 minimum
Wicket, google libraries, etc …
Spring framework is hanging back at Java 8
Expect we will need to do this this year …
Propose switching 2.22.x in september
(so main will would be switching .. now)
