[Geoserver-devel] Publishing geocss jars to the local maven repo
Hi David,
I have a question about interactively testing changes I may be making to geocss.
Of course I do start with some kind of test, but eventually I’d like to see the new
jar also be used by GeoServer, and it seems that sbt out of the box can only
publish to the local Ivy repo.
Normally how do you make the GeoCSS jars available to a GeoServer running
either in the IDE or to a command line maven build?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Tue, Aug 20, 2013 at 5:56 PM, Andrea Aime
<andrea.aime@anonymised.com>wrote:
Hi David,
geocss.
Of course I do start with some kind of test, but eventually I'd like to
see the new
only
Ah, another weird detail: the sbt publish-local command builds a 0.8.1 jar,
and
yet geoserver css depends on version 0.8.2
However, I'm sure I have an up to date checkout...
information.
Ing. Andrea Aime
@geowolf
Technical Lead
I just alter the build file (project/Build.scala) and change the publishTo setting on line 15.
@@ -12,7 +12,7 @@ object GeoScript extends Build {
scalaVersion := “2.10.0”,
scalacOptions ++= Seq(“-feature”, “-deprecation”, “-Xlint”, “-unchecked”),
javacOptions ++= Seq(“-source”, “6”),
  • publishTo := Some(Resolver.file(“file”, file(“release”)))
  • publishTo := Some(Resolver.file(“file”, new File(Path.userHome.absolutePath+“/.m2/repository”)))
val common =
With this modification in place I run the ‘sbt publish’ command and the jars and a generated pom are placed into the maven cache.
Sometimes rather than make changes I don’t want to commit, I instead run the ‘sbt publish’ command with the normal setting and rsync the results into the maven repo instead.
On Tue, Aug 20, 2013 at 11:56 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi David,
Ing. Andrea Aime
@geowolf
Technical Lead
Introducing Performance Central, a new site from SourceForge and
AppDynamics. Performance Central is your source for news, insights,
analysis and resources for efficient Application Performance Management.
Visit us today!
http://pubads.g.doubleclick.net/gampad/clk?id=48897511&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
It appears I have some unpushed changes. I should be able to update the github repo later today. In the meantime, you can include any setting you like at the command line, like:
sbt ‘set version := “0.8.2”’ publish
On Tue, Aug 20, 2013 at 12:02 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Aug 20, 2013 at 5:56 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Visit us today!
Hi David,
Ah, another weird detail: the sbt publish-local command builds a 0.8.1 jar, and
However, I’m sure I have an up to date checkout…
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Aug 20, 2013 at 6:03 PM, David Winslow <dwinslow@anonymised.com> wrote:
setting on line 15.
       scalaVersion := "2.10.0",
       scalacOptions ++= Seq("-feature", "-deprecation", "-Xlint",
"-unchecked"),
       javacOptions ++= Seq("-source", "6"),
- publishTo := Some(Resolver.file("file", file("release")))
+ publishTo := Some(Resolver.file("file", new
File(Path.userHome.absolutePath+"/.m2/repository")))
   val common =
With this modification in place I run the 'sbt publish' command and the
Sometimes rather than make changes I don't want to commit, I instead run
the 'sbt publish' command with the normal setting and rsync the results
Wondering, any way to pass a variable from the sbt build command into that
scala file, so that we can publish to the local m2 repo without
altering the build files?
Something like sbt publish-local -Dtarget=m2_local
information.
Ing. Andrea Aime
@geowolf
Technical Lead
