[Geoserver-devel] Pull request (#841) / GeoServerFeatureSource constructor
Jody and I have been discussing an API change in GeoServerFeatureSource that is in my pull request for cascaded stored query support.
https://github.com/geoserver/geoserver/pull/841#discussion-diff-21494311
The reasoning behind the change is to pass all metadata supplied for a feature type to the FeatureSource. This allows GeoServer to pass the configuration required for cascaded stored queries to the actual data store. The pattern is generic so it should be usable in other cases as well.
Jody was looking for more feedback, especially from Andrea, regarding this.
Sampo
Sampo Savolainen
R&D Director, Spatineo Oy
sampo.savolainen@anonymised.com
+358-407555649
Linnankoskenkatu 16 A 17, 00250 Helsinki, Finland
www.spatineo.com, twitter.com/#!/spatineo
www.linkedin.com/company/spatineo-inc
This message may contain privileged and/or confidential information. If you
have received this e-mail in error or are not the intended recipient, you
may not use, copy, disseminate, or distribute it; do not open any
attachments, delete it immediately from your system and notify the sender
promptly by e-mail that you have done so.
I don’t want to hold up the pull request on this one, should be a 5 mins conversation.
Andrea are these constructor arguments holding up?
Quick fix:
public GeoServerFeatureSource(source, schema, definitionQuery, declaredCRS, srsHandling, linearizationTolerance){
this( source, schema, definitionQuery, declaredCRS, srsHandling, linearizationTolerance, null );
Longer term:
// for backwards compatibility (deprecate or remove to force compile failure)
this( source, new Settings( schema, definitionQuery, declaredCRS, srsHandling, linearizationTolerance) );
GeoServerFeatureSource(source, schema, Settings settings ){
Where “GeoServerFeatureSource.Settings” is a parameter object we can add fields to over time:
static class Settings {
SimpleFeatureType schema = null;
Filter definitionQuery = null;
CoordinateReferenceSystem declaredCRS = null;
int srsHandling = null;
Double linearizationTolerance = null;
Map<String, Object> metadata = null;
On 11 December 2014 at 00:16, Sampo Savolainen <sampo.savolainen@anonymised.com> wrote:
Sampo
Sampo Savolainen
+358-407555649
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=164703151&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Jody Garnett
On Thu, Dec 11, 2014 at 6:59 PM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
I don't want to hold up the pull request on this one, should be a 5 mins
conversation.
Sorry, I'm busy enough that I don't know what day it is anymore these days
You mean you want to introduce a parameter object to avoid growing the
constructor?
Sure, pretty standard refactoring I'd say.
I have no idea what these new metadata things are though
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea, that is all we need. The new metadata thing was part of the pull request from Sampo (hopefully with a parameter object we can get a good javadoc explaining what it is for).
Jody
On 11 December 2014 at 10:24, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Thu, Dec 11, 2014 at 6:59 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Sorry, I’m busy enough that I don’t know what day it is anymore these days
You mean you want to introduce a parameter object to avoid growing the constructor?
Sure, pretty standard refactoring I’d say.
Ing. Andrea Aime
@geowolf
Technical Lead
I’ve added the Settings class in my pull request branch.
https://github.com/sampov2/geoserver/commit/623381f29cc8f5a7123a4c16e1b444fb449f2ff8
Sampo
On Thu, Dec 11, 2014 at 8:32 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Sampo Savolainen
sampo.savolainen@anonymised.com9…
+358-407555649
Thanks Sampo, let me know when I can review again.
On 19 December 2014 at 01:22, Sampo Savolainen <sampo.savolainen@anonymised.com> wrote:
Sampo
Jody Garnett
Jody
Sampo Savolainen
sampo.savolainen@anonymised.com3889…
+358-407555649
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
You can go ahead and review again at your convenience.
Sampo
On Fri, Dec 19, 2014 at 9:35 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Sampo
Jody
Sampo Savolainen
+358-407555649
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Sampo Savolainen
sampo.savolainen@…3889…
+358-407555649
